    WiFi disconnect errors
    79
    12.1k
    • peirofundefined
      peirof
      I think I've sent my Duet3D WiFi to England, because of symptoms very similar to those described …
      I hope not....
        @peirof:
        I hope not....
        Yours was different, it wouldn't upload new wifi firmware.
        • peirofundefined
          peirof
          i hope….
          • zlowredundefined
            zlowred
            So I was able to reproduce the disconnect. Below is the full log. Note that I temporarily disabled M552 S1 in the config.g so that full log is captured.
            I issued M122 after the disconnect in case it contains something useful.
            RepRapFirmware for Duet WiFi Version 1.20beta8 dated 2017-11-17
            Executing config.g...HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            Done!
            Network disabled.
            RepRapFirmware for Duet WiFi is up and running.
            M111 S1 P14
            Debugging enabled for modules: WiFi(14)
            Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13)
            ok
            M552 S1
            ok
            WiFi:
            WiFi:  ets Jan  8 2013,rst cause:2, boot mode:(3,7)
            WiFi:
            WiFi: load 0x4010f000, len 1384, room 16
            WiFi: tail 8
            WiFi: chksum 0x2d
            WiFi: csum 0x2d
            WiFi: v00007fff
            WiFi: ~ld
            WiFi module started
            WiFi: mode : sta(ec:fa:bc:02:1e:41)
            WiFi: add if0
            WiFi: scandone
            WiFi: sleep enable,type: 2
            WiFi: scandone
            WiFi: state: 0 -> 2 (b0)
            WiFi: state: 2 -> 3 (0)
            WiFi: state: 3 -> 5 (10)
            WiFi: add 0
            WiFi: aid 3
            WiFi: cnt
            WiFi:
            WiFi: connected with Lrrr, channel 1
            WiFi: dhcp client start...
            Wifi module is connected to access point Lrrr, IP address 192.168.1.102
            WiFi: ip:192.168.1.102,mask:255.255.255.0,gw:192.168.1.1
            WiFi: pm open,type:2 0
            WiFi: p->ref == 1
            WiFi: p->ref == 1
            WiFi: p->ref == 1
            WiFi: p->ref == 1
            WiFi: p->ref == 1
            WiFi: p->ref == 1
            WiFi: p->ref == 1
            WiFi: p->ref == 1
            WiFi: p->ref == 1
            WiFi: p->ref == 1
            M122
            Used output buffers: 1 of 32 (8 max)
            RepRapFirmware for Duet WiFi version 1.20beta8 running on Duet WiFi 1.0
            Board ID: 08DDM-9FAM2-LW4S8-6JTDD-3SJ6P-9MXBY
            Static ram used: 15488
            Dynamic ram used: 99624
            Recycled dynamic WiFi:
            ram: 3672
            Stack ram used: 4328 current, 5324 maximum
            NeveWiFi: LINK
            r used ram: 6964
            Last reset 00:02:07 ago, cause: power up
            Last software reset reason: User, spinning module GCodes, available RAM 6960 bytes (slot 4)
            Software reset code 0x0003, HFSR 0x00000000, CFSRWiFi: 	xmit: 0
             0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
            Error status: 0
            Free file entries:WiFi: 	recv: 0
             10
            SD card longest block write time: 0.0ms
            MCU temperature: min 31.5, current 34.8, max 35.0
            Supply voltage:WiFi: 	fw: 0
             min 0.3, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0
            Driver 0: ok
            Driver 1: ok
            Driver 2: ok
            Driver 3: okWiFi: 	drop: 0
            Driver 4: ok
            Date/time: 2017-11-18 11:55:08
            Cache data hit count 436514026
            Slowest main loop (seconds): 0.099160; fastest: 0WiFi: 	chkerr: 0
            .000034
            MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
            Bed compensation iWiFi: 	lenerr: 0
            n use: none
            Bed heater = 0, chaWiFi: 	memerr: 0
            mber heater = -1
            Heater 1 is on, I-accum = 0.0
            Segments left: 0
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in stateWiFi: 	rterr: 0
            (s) 0
            file is idle in state(s) 0
            serial is ready with "M122" inWiFi: 	proterr: 0
             state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            Network state is running
            Failed mWiFi: 	opterr: 0
            essages: pending 0, notready 0, nWiFi: 	err: 0
            oresp 0
            WiFi firmware version 1.20b9
            WiFi MAC address ec:fa:bc:02:1e:41
            WiFi Vcc 3.35, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 25224
            WiFi IP address 192.168.1.102
            WiFi signal strength -58dBm, reconnections 0, sleep mode WiFi: 	cachehit: 0
            modem
            HTTP sessions: 1 of 8
            Socket states:  0 0 0 0 0 0 0 0
            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
            ok
            WiFi:
            WiFi: ETHARP
            WiFi: 	xmit: 4
            WiFi: 	recv: 2
            WiFi: 	fw: 0
            WiFi: 	drop: 39
            WiFi: 	chkerr: 0
            WiFi: 	lenerr: 0
            WiFi: 	memerr: 0
            WiFi: 	rterr: 0
            WiFi: 	proterr: 39
            WiFi: 	opterr: 0
            WiFi: 	err: 0
            WiFi: 	cachehit: 1605
            WiFi:
            WiFi: IP
            WiFi: 	xmit: 1614
            WiFi: 	recv: 1892
            WiFi: 	fw: 0
            WiFi: 	drop: 1
            WiFi: 	chkerr: 1
            WiFi: 	lenerr: 0
            WiFi: 	memerr: 0
            WiFi: 	rterr: 0
            WiFi: 	proterr: 0
            WiFi: 	opterr: 0
            WiFi: 	err: 0
            WiFi: 	cachehit: 0
            WiFi:
            WiFi: IGMP
            WiFi: 	xmit: 4
            WiFi: 	recv: 1
            WiFi: 	drop: 0
            WiFi: 	chkerr: 0
            WiFi: 	lenerr: 0
            WiFi: 	memerr: 0
            WiFi: 	proterr: 0
            WiFi: 	rx_v1: 0
            WiFi: 	rx_group: 0
            WiFi: rx_general: 1
            WiFi: rx_rmit: 1174
            WiFi: 	recv: 1831
            WiFi: 	fw: 0
            WiFi: 	drop: 0
            WiFi: 	chkerr: 0
            WiFi: 	lenerr: 0
            WiFi: 	memerr: 0
            WiFi: 	rterr: 0
            WiFi: 	proterr: 0
            WiFi: 	opterr: 0
            WiFi: 	err: 0
            WiFi: 	cachehit: 0
            The "WiFi: p->ref == 1" messages appeared around every few seconds or so, and the "AJAX error" appeared after the last "WiFi: p->ref == 1" message. I waited for another 10 minutes, but didn't see these messages after the "AJAX error"
              Thanks. Did the p->ref==1 messages start appearing as soon as you connected, or not until shortly before the disconnection message?
              • zlowredundefined
                zlowred
                First message is seconds after I connected. Others are at irregular intervals between few seconds and somewhere around a minute between each other.
                In the meanwhile, I've replaced the wifi module with ESP-07S with external antenna, and it didn't change anything, e.g. behaviour is exactly the same.
                  I've never seen those p->ref==1 messages on my test systems. I suspect they are related to the disconnections. Please do a few more tests, to establish how many p->ref messages you get, before they start appearing every few seconds and the disconnection occurs.
                  Edit: those p->ref == 1 messages indicate an assertion failure within the TCP/IP stack, so they are definitely indicative of something going wrong.
                  • zlowredundefined
                    zlowred
                    Sure, I'll collect more data and post it here
                    In the meanwhile – I can build the firmware myself, so if you need me to build it with maybe some additional debug flags, or quickly test some changes without releasing the new beta version – feel free to ask.
                      Thanks. Those debug messages come from the firmware on the wifi module, so it's that firmware that is likely to contain the fault.
                        Please can anyone else who is still getting WiFi disconnections even though the RSSI is good do the following:
                        1. Upgrade to the just-released DuetWiFiFirmware 1.20beta8 and DuetWiFiServer 1.20beta9.
                        2. Connect a PC via USB and send M111 S1 P14 to enable the new WiFi debugging feature. If you have already started wifi, send M552 S-1 and then M552 S1 to restart it. You will get some WiFi debug messages during startup and connection to your router, similar to the following:
                        WiFi:
                        WiFi: ets Jan 8 2013,rst cause:2, boot mode:(3,6)
                        WiFi:
                        WiFi: tail 8
                        WiFi: chksum 0x2d
                        WiFi: csum 0x2d
                        WiFi: v00007fff
                        WiFi: ~ld
                        WiFi module started
                        WiFi: mode : sta(a0:20:a6:19:28:23)
                        WiFi: add if0
                        WiFi: scandone
                        WiFi: scandone
                        WiFi: add 0
                        WiFi: aid 2
                        WiFi: cnt
                        WiFi:
                        WiFi: connected with ********, channel 6
                        WiFi: dhcp client start…
                        Wifi module is connected to access point ********* IP address 192.168.1.123
                        WiFi: ip:192.168.1.123,mask:255.255.255.0,gw:192.168.1.254
                        3. Load DuetWebControl in your browser.
                        4. If/when the wifi disconnects unexpectedly, look at the console on the PC to see whether any more debug messages have been displayed, and report what you find.
                        • zlowredundefined
                          zlowred
                          Hi David,
                          So I was able to reproduce few more times. Here are my observations:
                          • (obvious one) I didn't see any debug messages including p->buf==1 while DWC page is not opened
                          • these p->buf==1 messages always (or most of the time) come out in pairs
                          • there are no regular intervals between these messages, sometimes I see few per second, sometimes I don't any for 10-15 minutes
                          • they are not getting more often before the disconnect
                          • I feel that messages are coming much more often when printer is printing (compared to the idle) - suspect it may be related to some timings, e.g. CPU is busy with something and can't send some command or data to the WiFi module in time. Or maybe noise in power line due to heaters PWM. My power supply is able to provide enough current, so it's not under-voltage, but maybe some noise…
                          I'll post here if I get more data
                            Thanks. Please can you install this DuetWiFiServer.bin file twice (the second time you can just send M997 S1 to install it again from the existing SD card file). It will provide a slightly more detailed debug message.
                            • zlowredundefined
                              zlowred
                              Sure, will do. I wonder if there is anything of interest to you in the debug message showing when I do M552 S0 after such disconnect:
                              WiFi: state: 5 -> 0 (0)
                              WiFi: rm 0
                              WiFi: pm close 7
                              WiFi: tcp_pcb_purge: pcb->state == SYN_RCVD but tcp_listen_pcbs is NULL
                              Wifi module is idle
                              WiFi: del if0
                              WiFi: usl
                              WiFi: mode : null
                              Not sure if these pcb->state checks are ok
                                Yes, those are interesting too, in particular the tcp_pcb_purge messages.
                                • zlowredundefined
                                  zlowred
                                  I did additional M997 S1 and then reproduced disconnect once again, but it didn't result in any additional messages in the log.
                                    There shouldn't be additional messages, but some of the messages should have additional detail.
                                    • zlowredundefined
                                      zlowred
                                      I had to revert to 1.20beta6 for now because starting from 1.20beta7 it resets every now and then and I have lots of failed prints because of that. I'm still running the latest 1.20beta9 WiFi firmware though.
                                      • JohnOCFIIundefined
                                        JohnOCFII
                                        @dc42:
                                        1. Upgrade to the just-released DuetWiFiFirmware 1.20beta8 and DuetWiFiServer 1.20beta9…
                                        I'll upgrade tomorrow morning (US Central time) and start testing.
                                        John
                                          JohnOCFII
                                          OK - Firmware updated, WiFi debugging turned on. We'll see what happens. Here's the startup debug so far:
                                          [[language]]
                                          Connecting...
                                          RepRapFirmware for Duet WiFi Version 1.20beta8+1 dated 2017-11-18
                                          Executing config.g...Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 594C.
                                          FTP is disabled
                                          TELNET is disabled
                                          Done!
                                          RepRapFirmware for Duet WiFi is up and running.T:20.7 /0.0 B:20.1 /0.0
                                          Printer is now online.
                                          >>>M111 S1 P14
                                          SENDING:M111 S1 P14
                                          >>>M552 S-1
                                          SENDING:M552 S-1
                                          WiFi module stopped
                                          >>>M552 S1
                                          SENDING:M552 S1
                                          WiFi:
                                          WiFi:
                                          WiFi: tail 8
                                          WiFi: chksum 0x2d
                                          WiFi: csum 0x2d
                                          WiFi: v00007fff
                                          WiFi: ~ld
                                          WiFi module started
                                          WiFi: mode : sta(a0:20:a6:16:eb:66)
                                          WiFi: add if0
                                          WiFi: scandone
                                          WiFi: scandone
                                          WiFi: add 0
                                          WiFi: aid 7
                                          WiFi: cnt
                                          WiFi:
                                          WiFi: connected with Aloha, channel 7
                                          Wifi module is connected to access point Aloha, IP address 192.168.62.118
                                          WiFi: ip:192.168.62.118,mask:255.255.255.0,gw:192.168.62.1
                                          WiFi: p->ref == 1
                                          WiFi: p->ref == 1
                                            JohnOCFII
                                            Ok - just finished a two hour print without disconnects. I am seeing many of the WiFi: p->ref == 1 messages. I also added an M122 diagnostic at the end.
                                            Here's the full log so far. I'll keep the machine on.
                                            [[language]]
                                            Connecting...
                                            FTP is disabled
                                            TELNET is disabled
                                            Done!
                                            >>>M111 S1 P14
                                            SENDING:M111 S1 P14
                                            >>>M552 S-1
                                            SENDING:M552 S-1
                                            WiFi module stopped
                                            >>>M552 S1
                                            SENDING:M552 S1
                                            WiFi:
                                            WiFi:
                                            WiFi: tail 8
                                            WiFi: chksum 0x2d
                                            WiFi: csum 0x2d
                                            WiFi: v00007fff
                                            WiFi: ~ld
                                            WiFi module started
                                            WiFi: add if0
                                            WiFi: scandone
                                            WiFi: scandone
                                            WiFi: add 0
                                            WiFi: aid 7
                                            WiFi: cnt
                                            WiFi:
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            Calibrated 6 factors using 10 points, deviation before 0.213 after 0.036
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            Done printing fileFinished printing file Models/JoelBot_Repaired_70p_KMR3.gcode, print time was 2h 18m
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            WiFi: p->ref == 1
                                            >>>M122
                                            SENDING:M122
                                            Used output buffers: 3 of 32 (9 max)
                                            RepRapFirmware for Duet WiFi version 1.20beta8+1 running on Duet WiFi 1.0
                                            Board ID: 08DAM-999TL-MQ4S8-6JKDJ-3SJ6K-16BVW
                                            Dynamic ram used: 99336
                                            Recycled dynamiWiFi:
                                            c ram: 3960
                                            Stack ram used: 4328 current, 9428 maximum
                                            Never used ram: 2860
                                            Last reset 02:39:14 ago, cause: power up
                                            Last software reset reason: User, spinning module GCodes, available RAM 3192 bytes (slot 1)
                                            Software reset code 0x0003, HFSR 0x00000000, CFWiFi: LINK
                                            SR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0WiFi: 	xmit: 0
                                            xffffffff
                                            Error status: 0
                                            Free file entries: 10
                                            SD card longest block write time: 543.3ms
                                            MCU temperature: min 29.3, current 38.3, max 41.0
                                            Supply voltWiFi: 	recv: 0
                                            age: min 0.6, current 12.3, max 12.5, under voltage events: 0, over voltage events: 0
                                            DWiFi: 	fw: 0
                                            river 0: standstill
                                            Driver 1: standstill
                                            Driver 2: standstill
                                            Driver 3: standstill
                                            Driver 4: standstill
                                            Date/time: 2017-11-19 11:59:58
                                            SlWiFi: 	drop: 0
                                            owest main loop (seconds): 0.544757; fastest: 0.000033
                                            MaxReps: 6, StepErrors: 0, FreeDm: 240, MinFreeDm 120, WiFi: 	chkerr: 0
                                            MaxWait: 1524274909ms, Underruns: 0, 0
                                            Bed compensation in use: none
                                            Bed probe heights: 0.300 WiFi: 	lenerr: 0
                                            0.175 0.153 0.075 0.295
                                            Bed heater = 0, chamber heater = -1
                                            Heater 0 is on, I-accum = 0.0
                                            Heater 1 is on, I-accum = 0.7
                                            SegmeWiFi: 	memerr: 0
                                            nts left: 0
                                            WiFi: 	rterr: 0
                                            telnet is idle in state(s) 0
                                            serial is ready with "M122" in state(s) 0
                                            autWiFi: 	proterr: 0
                                            opause is idle in state(s) 0
                                            Network state is runniWiFi: 	opterr: 0
                                            ng
                                            WiFi MAC address a0:20:a6:16:eb:66
                                            WiFi Vcc 3.37, reset reason Turned on by main processorWiFi: 	err: 0
                                            WiFi flash size 4194304, free heap 27640
                                            WWiFi: 	cachehit: 0
                                            iFi IP address 192.168.62.118
                                            WiFi signal strength -58dBm, reconnections 0, sleep mode modem
                                            HTTP sessions: 2 of 8
                                            WiFi:
                                            WiFi: ETHARP
                                            WiFi: 	xmit: 4
                                            WiFi: 	recv: 1203
                                            WiFi: 	fw: 0
                                            WiFi: 	drop: 6803
                                            WiFi: 	chkerr: 0
                                            WiFi: 	lenerr: 0
                                            WiFi: 	memerr: 0
                                            WiFi: 	rterr: 0
                                            WiFi: 	proterr: 6803
                                            WiFi: 	opterr: 0
                                            WiFi: 	err: 0
                                            WiFi: 	cachehit: 40018
                                            WiFi:
                                            WiFi: IP
                                            WiFi: 	xmit: 40128
                                            WiFi: 	recv: 6877
                                            WiFi: 	fw: 0
                                            WiFi: 	drop: 0
                                            WiFi: 	chkerr: 0
                                            WiFi: 	lenerr: 0
                                            WiFi: 	memerr: 0
                                            WiFi: 	rterr: 0
                                            WiFi: 	proterr: 0
                                            WiFi: 	opterr: 0
                                            WiFi: 	err: 0
                                            WiFi: 	cachehit: 0
                                            WiFi:
                                            WiFi: IGMP
                                            WiFi: 	xmit: 2
                                            WiFi: 	recv: 94
                                            WiFi: 	drop: 0
                                            WiFi: 	chkerr: 0
                                            WiFi: 	lenerr: 0
                                            WiFi: 	memerr: 0
                                            WiFi: 	proterr: 0
                                            WiFi: 	rx_v1: 0
                                            WiFi: 	rx_group: 0
                                            WiFi: rx_genert 62171
                                            WiFi: 	recv: 62198
                                            WiFi: 	fw: 0
                                            WiFi: 	drop: 0
                                            WiFi: 	chkerr: 0
                                            WiFi: 	lenerr: 0
                                            WiFi: 	memerr: 0
                                            WiFi: 	rterr: 0
                                            WiFi: 	proterr: 0
                                            WiFi: 	opterr: 0
                                            WiFi: 	err: 0
                                            WiFi: 	cachehit: 0
