    Horrible print quality since upgrading
    29
    5.7k
    • totalitarianundefined
      totalitarian
      BTW, I reduced the steps to 1/8 but it made no difference. The diagonal lines had the same frequency 😞
      • botundefined
        bot
        Is there any way to revert to the original extruder setup, so that you can isolate the variables?
        *not actually a robot
          totalitarian
          Sure, i'll refit my old titan this evening and do some more test prints
          • DjDemonDundefined
            DjDemonD
            This type of motor works for me for both flex3drive/nimble and titan:
            https://www.omc-stepperonline.com/hybrid-stepper-motor/nema-17-bipolar-18deg-13ncm-184ozin-1a-35v-42x42x20mm-4-wires-17hs08-1004s.html
            Its lightweight, and has enough torque to drive a geared extruder.
            Long/large motors are needed when you need to achieve high holding torque, or to move a large heavy load such as a large 3 leadscrew bed etc.. for turning an extruder with gearing like 40:1 or 30:1 requires almost no torque at all. What more important is can you spin it up quickly and reverse it quickly.
            The image with the cube above, does show what appears to be pulsing of the extruder, maybe this is the effect of the drive cable tightening and loosening as it turns. Grease it up and look at the path it takes to see if you can keep it from having to go around a tight radius.
            www.precisionpiezo.co.uk
              totalitarian
              Yeah i'm not convinced I have the optimal route for the cable worked out yet. I've also noticed that the cable doesn't spin concentrically at the motor end. Not sure if this makes a difference or not or how I would fix this
              https://photos.app.goo.gl/lTdTj8taKpn6q29Z2
              The only other stepper I have kicking around is the one recommend for the titan
              https://e3d-online.com/nema17-slimline-stepper-motor
              but this is 0.9deg.
                T3P3Tony administrators
                I agree with bot, if its possible to split the issue to isolate the issue(s). I know people on this forum have had good success with flexible drives but minimising the number of variables changing at once can help to find the problem quicker.
                  totalitarian
                  OK I switched back to my E3D titian extruder. Not good news. Constantly skipping and then my x axis started stuttering too!
                  https://photos.app.goo.gl/MGCq8oO2NUPvVVIT2
                  Here is my config for the titian
                  [[language]]
                  M569 P0 S0 ; Drive 0 goes backwards
                  M569 P1 S0 ; Drive 1 goes backwards
                  M92 X80 Y80 Z400 E800 ; Set steps per mm
                  M350 E16 I1 ; Configure microstepping with interpolation
                  M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
                  M566 X300 Y300 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
                  M203 X30000 Y30000 Z600 E300 ; Set maximum speeds (mm/min)
                  M201 X500 Y500 Z100 E250 ; Set accelerations (mm/s^2)
                  M906 X800 Y800 Z800 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  And here is my M112
                  M122
                  [[language]]
                  Used output buffers: 3 of 32 (8 max)
                  RepRapFirmware for Duet WiFi version 1.19 running on Duet WiFi 1.0
                  Board ID: 08DGM-95BNL-MGPSJ-6J1F8-3SD6T-1KZ3W
                  Static ram used: 21176
                  Dynamic ram used: 95960
                  Recycled dynamic ram: 1648
                  Stack ram used: 1304 current, 4840 maximum
                  Never used ram: 7448
                  Last reset 00:02:17 ago, cause: software
                  Last software reset reason: User, spinning module GCodes, available RAM 3232 bytes (slot 2)
                  Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
                  Error status: 0
                  Free file entries: 10
                  SD card longest block write time: 0.0ms
                  MCU temperature: min 18.9, current 19.4, max 20.6
                  Supply voltage: min 11.5, current 11.5, max 11.7, under voltage events: 0, over voltage events: 0
                  Driver 0: stalled standstill
                  Driver 1: standstill
                  Driver 2: stalled standstill
                  Driver 3: stalled standstill
                  Driver 4: standstill
                  Date/time: 2017-11-10 23:38:33
                  Slowest main loop (seconds): 0.004425; fastest: 0.000034
                  MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                  Bed compensation in use: none
                  Bed heater = 0, chamber heater = -1
                  Heater 1 is on, I-accum = 0.0
                  Segments left: 0
                  Movement lock held by null
                  http is idle in state(s) 0
                  telnet is idle in state(s) 0
                  file is idle in state(s) 0
                  serial is idle in state(s) 0
                  aux is idle in state(s) 0
                  daemon is idle in state(s) 0
                  queue is idle in state(s) 0
                  Code queue is empty.
                  Network state is running
                  WiFi firmware version 1.19
                  WiFi MAC address 2c:3a:e8:0b:07:75
                  WiFi Vcc 3.02, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 38904
                  WiFi IP address 192.168.1.56
                  WiFi signal strength -37dBm
                  HTTP sessions: 2 of 8
                  Socket states: 2 0 0 0 0 0 0 0
                  Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                    Was that M122 report produced after a print, or before? The power supply voltage is a little low, and if it drops further when the heaters are on then you could be getting motor driver dropout due to the voltage going too low. OTOH if that M122 report is the first one you did after a print, then the minimum voltage is OK and there are no under-voltage events reported.
                      totalitarian
                      It was after, i'll boost it up a little
                      • Dougal1957undefined
                        Dougal1957
                        Have you got anywhere with solving the issues with the prints yet it would be interesting to know.
                        Doug
                        • MrBlomundefined
                          MrBlom
                          I had similar problems with my drive shaft extruder
                          it was like long waves
                          the solution for me was to make a more solid mount for the e3d/heatsink
                          i was using the normal e3d heatsink with a clamp at the top
                          but i guess the cable made it "swing a little" making this long waves
                          after changing to the aero heatsink (it has 2 screw holes , so it can be screwdown very tight)
                          this problem vent a way
                          may not be your problem but try to add some straps or something to test if that's your problem
                            totalitarian
                            @MrBlom:
                            You know it may have been that. I was using a piezo probe / mount. I did return the drive in the end as i'm afraid I had projects that needed to be completed by Christmas, so reinstalled my old extruder. I must say, the flex3drive creator was very helpful in supporting me but unfortunately I never got to the solution. I know other users who run a similar setup to me without issues. I can only assume it was a combination of the drive cable and my mount.
                            • Mutleyundefined
                              Mutley
                              Just to update on this. I received the parts back to assess what might have been the cause given that this patterning was highly unusual from a Flex3Drive. Not seen before, anomaly!
                              Returned unit was fitted to a machine. Printed perfectly, Found deformation on plastics due to heavy over tightening of bolts. Was able to recreate the issue to confirm s thats good.. Steps taken to prevent recurrance.
