    Horrible print quality since upgrading
    29
    5.7k
    • totalitarianundefined
      totalitarian
      @Shen:
      I'm also had a similar issue. I think it's caused by the non-linearity of micro steps. From my calculation, the pattern is repeating every full step of the stepper motor. I also tried a 0.9 degree stepper motor instead of the 1.8 degree motor I was using, the length of the pattern halved. Stepper motor current does affect micro stepping linearity, you need to find the optimal value. You may also try replacing the extruder motor which worked for me.
      So are you saying it was the motor in the end that was causing the issue? Was it a failing motor?
        totalitarian
        Just noticed this in the wiki
        If using a highly-geared extruder (for example, an extruder that uses a flexible drive cable to transmit the torque from the motor to a worm reduction gear), use a short low-inductance 1.8deg/step motor to drive it.
        I'm not too electrically minded, but this is my motor, is it suitable?
        https://www.amazon.co.uk/gp/product/B01J3IKKHW/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
        Weight: 279g
        Voltage: 3.3V
        Current: 1.5A
        Power: 35W
        Step Angle: 1.8°
        Phases: 2
        Resistance: 5.2Ω±10%
        Inductance: 9.0mH±20%
        Holding Torque: 4.0Kg ·cm
        Detent Torque: 150g·cm
        Insulation resistance: 500VDC 100MΩ
        Insulation class: B
        Rotor inertia: 57g ·cm²
          No. That motor is long and it has high inductance.
          • Shenundefined
            Shen
            @totalitarian:
            @Shen:
            It's not failing, but it might not be the best option for your extruder.
              totalitarian
              @dc42:
              Could you suggest a specific stepper?
                totalitarian
                BTW, I reduced the steps to 1/8 but it made no difference. The diagonal lines had the same frequency 😞
                • botundefined
                  bot
                  Is there any way to revert to the original extruder setup, so that you can isolate the variables?
                  *not actually a robot
                    totalitarian
                    Sure, i'll refit my old titan this evening and do some more test prints
                    • DjDemonDundefined
                      DjDemonD
                      This type of motor works for me for both flex3drive/nimble and titan:
                      https://www.omc-stepperonline.com/hybrid-stepper-motor/nema-17-bipolar-18deg-13ncm-184ozin-1a-35v-42x42x20mm-4-wires-17hs08-1004s.html
                      Its lightweight, and has enough torque to drive a geared extruder.
                      Long/large motors are needed when you need to achieve high holding torque, or to move a large heavy load such as a large 3 leadscrew bed etc.. for turning an extruder with gearing like 40:1 or 30:1 requires almost no torque at all. What more important is can you spin it up quickly and reverse it quickly.
                      The image with the cube above, does show what appears to be pulsing of the extruder, maybe this is the effect of the drive cable tightening and loosening as it turns. Grease it up and look at the path it takes to see if you can keep it from having to go around a tight radius.
                      www.precisionpiezo.co.uk
                        totalitarian
                        Yeah i'm not convinced I have the optimal route for the cable worked out yet. I've also noticed that the cable doesn't spin concentrically at the motor end. Not sure if this makes a difference or not or how I would fix this
                        https://photos.app.goo.gl/lTdTj8taKpn6q29Z2
                        The only other stepper I have kicking around is the one recommend for the titan
                        https://e3d-online.com/nema17-slimline-stepper-motor
                        but this is 0.9deg.
                          T3P3Tony administrators
                          I agree with bot, if its possible to split the issue to isolate the issue(s). I know people on this forum have had good success with flexible drives but minimising the number of variables changing at once can help to find the problem quicker.
                            totalitarian
                            OK I switched back to my E3D titian extruder. Not good news. Constantly skipping and then my x axis started stuttering too!
                            https://photos.app.goo.gl/MGCq8oO2NUPvVVIT2
                            Here is my config for the titian
                            [[language]]
                            M569 P0 S0 ; Drive 0 goes backwards
                            M569 P1 S0 ; Drive 1 goes backwards
                            M92 X80 Y80 Z400 E800 ; Set steps per mm
                            M350 E16 I1 ; Configure microstepping with interpolation
                            M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
                            M566 X300 Y300 Z24 E300 ; Set maximum instantaneous speed changes (mm/min)
                            M203 X30000 Y30000 Z600 E300 ; Set maximum speeds (mm/min)
                            M201 X500 Y500 Z100 E250 ; Set accelerations (mm/s^2)
                            M906 X800 Y800 Z800 E1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
                            M84 S30 ; Set idle timeout
                            And here is my M112
                            M122
                            [[language]]
                            Used output buffers: 3 of 32 (8 max)
                            RepRapFirmware for Duet WiFi version 1.19 running on Duet WiFi 1.0
                            Board ID: 08DGM-95BNL-MGPSJ-6J1F8-3SD6T-1KZ3W
                            Static ram used: 21176
                            Dynamic ram used: 95960
                            Recycled dynamic ram: 1648
                            Stack ram used: 1304 current, 4840 maximum
                            Never used ram: 7448
                            Last reset 00:02:17 ago, cause: software
                            Last software reset reason: User, spinning module GCodes, available RAM 3232 bytes (slot 2)
                            Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
                            Error status: 0
                            Free file entries: 10
                            SD card longest block write time: 0.0ms
                            MCU temperature: min 18.9, current 19.4, max 20.6
                            Supply voltage: min 11.5, current 11.5, max 11.7, under voltage events: 0, over voltage events: 0
                            Driver 0: stalled standstill
                            Driver 1: standstill
                            Driver 2: stalled standstill
                            Driver 3: stalled standstill
                            Driver 4: standstill
                            Date/time: 2017-11-10 23:38:33
                            Slowest main loop (seconds): 0.004425; fastest: 0.000034
                            MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                            Bed compensation in use: none
                            Bed heater = 0, chamber heater = -1
                            Heater 1 is on, I-accum = 0.0
                            Segments left: 0
                            Movement lock held by null
                            http is idle in state(s) 0
                            telnet is idle in state(s) 0
                            file is idle in state(s) 0
                            serial is idle in state(s) 0
                            aux is idle in state(s) 0
                            daemon is idle in state(s) 0
                            queue is idle in state(s) 0
                            Code queue is empty.
                            Network state is running
                            WiFi firmware version 1.19
                            WiFi MAC address 2c:3a:e8:0b:07:75
                            WiFi Vcc 3.02, reset reason Turned on by main processor
                            WiFi flash size 4194304, free heap 38904
                            WiFi IP address 192.168.1.56
                            WiFi signal strength -37dBm
                            HTTP sessions: 2 of 8
                            Socket states: 2 0 0 0 0 0 0 0
                            Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                              Was that M122 report produced after a print, or before? The power supply voltage is a little low, and if it drops further when the heaters are on then you could be getting motor driver dropout due to the voltage going too low. OTOH if that M122 report is the first one you did after a print, then the minimum voltage is OK and there are no under-voltage events reported.
                                totalitarian
                                It was after, i'll boost it up a little
                                • Dougal1957undefined
                                  Dougal1957
                                  Have you got anywhere with solving the issues with the prints yet it would be interesting to know.
                                  Doug
                                  • MrBlomundefined
                                    MrBlom
                                    I had similar problems with my drive shaft extruder
                                    it was like long waves
                                    the solution for me was to make a more solid mount for the e3d/heatsink
                                    i was using the normal e3d heatsink with a clamp at the top
                                    but i guess the cable made it "swing a little" making this long waves
                                    after changing to the aero heatsink (it has 2 screw holes , so it can be screwdown very tight)
                                    this problem vent a way
                                    may not be your problem but try to add some straps or something to test if that's your problem
                                      totalitarian
                                      @MrBlom:
                                      You know it may have been that. I was using a piezo probe / mount. I did return the drive in the end as i'm afraid I had projects that needed to be completed by Christmas, so reinstalled my old extruder. I must say, the flex3drive creator was very helpful in supporting me but unfortunately I never got to the solution. I know other users who run a similar setup to me without issues. I can only assume it was a combination of the drive cable and my mount.
                                      • Mutleyundefined
                                        Mutley
                                        Just to update on this. I received the parts back to assess what might have been the cause given that this patterning was highly unusual from a Flex3Drive. Not seen before, anomaly!
                                        Returned unit was fitted to a machine. Printed perfectly, Found deformation on plastics due to heavy over tightening of bolts. Was able to recreate the issue to confirm s thats good.. Steps taken to prevent recurrance.
