    How to configure both Low end and High end enstop for axis
    • SanderLPFRGundefined
      SanderLPFRG
      I am engineering a machine with 2 tools which each have an independent little Z-axis for auto-calibration.
      The little Z axis on the left hotend (V) has a high-end microswitch endstop and on the low end a nozzle-triggered Z probe.
      The little Z axis on the right hotend (W) also has a high-end microswitch endstop. But uses the nozzle 'probe' as a low-end microswitch endstop.
      My goal is to auto-align the Z of both tools with this system
      I plan to do this by first homing V and W to their max (high-end). Then I move V down by 5mm to clear any difference between the tools, probe the bed with the left hotend and set Z=0. Then I move the 2nd tool to the same location as probed, and move the right hotend (W) down until the nozzle touches the bed (W low-end endstop switch).
      However, I cannot find if I connect 2 end-stops for the same axis (W) Any help?
      I have tried this;
      M574 W2 S1 P"1.io4.in"      ; configure switch-type endstop for high end on W via pin 1.io4.in
      M574 W1 S1 P"2.io1.in"      ; configure switch-type endstop for low end on W via pin 2.io1.in
        jay_s_uk @SanderLPFRG
        @SanderLPFRG you can't configure 2 endstops for an axis at the same time.
        you can however remap them on the fly, so just add the appropriate M574 line before using the endstop.
        SanderLPFRGundefined 1 Reply Last reply Reply Quote 0
          SanderLPFRG @jay_s_uk
          @jay_s_uk can you give an example?
            @SanderLPFRG well lets say you want to home to to the top
            G1 H1 W100
            and when you want to home to the bottom
            G1 H1 W-100
            SanderLPFRGundefined 1 Reply Last reply Reply Quote 2
              @jay_s_uk It is working, thanks!
              • droftartsundefined droftarts marked this topic as a question
              • droftartsundefined droftarts has marked this topic as solved
              • SanderLPFRGundefined SanderLPFRG referenced this topic
              • T3P3Tonyundefined T3P3Tony referenced this topic
