    [3.5beta1+] Duet2WiFi freeze running macro
    Beta Firmware
    554
    • Leonard03undefined
      Leonard03
      Replacing the M291 with an "echo" command in "errorWarning.g" has no effect in this case:
      Movement locks held by File
      File is idle in state(s) 0 0 19, running macro
        dc42 administrators @Leonard03
        @Leonard03 said in [3.5beta1+] Duet2WiFi freeze running macro:
        And now, trying to start a print I got a reset..
        In the original 3.5beta1 announcement thread I posted links to some new firmware binaries to fix that. But you may prefer to wait for beta2 which is due out this week.
        Leonard03undefined 1 Reply Last reply Reply Quote 0
          Leonard03 @dc42
          @dc42 Thank you very much for your answer.
          Right now I flashed the 3.5beta1+ (2023-02-04 17:03:21) (thank you @OwenD ). With tihis version the assertion issue has gone but the macro issue still persists.
          I will wait for the beta2 😁
            Leonard03
            Sadly, even with the beta2 update this RRF gets stuck, but this issue seems to occur only when M25 is called from a macro.
            If I hit "Pause" or send a M25 from DWC or PanelDue from the UI or via console works as expected 😕
            OwenDundefined 1 Reply Last reply Reply Quote 0
            • OwenDundefined
              OwenD @Leonard03
              @Leonard03
              I don't know if it would make a difference, but you don't need the M99 calls at the end of your macros.
                Leonard03
                @OwenD Alredy tried.. in the macros and sending it via DWC and no wffect. DWC shows the command is executing but thats it. M99 and the "abort" command has no effects
                  T3P3Tony administrators @Leonard03
                  @Leonard03 have you tried using M226:
                  https://docs.duet3d.com/User_manual/Reference/Gcodes#m226-synchronous-pause
                  M25 is pause during a print sent from outside the print, M226 is supposed to be a pause embedded in a file.
                    Leonard03 @T3P3Tony
                    @T3P3Tony Thank you for the sugestion. No because of this paragraph: "M25 is intended for use from a different source of GCodes (such as the web interface console, PanelDue or a Macro)" but I'll give it a try now 😁
                      Leonard03
                      I really don't understand why, but this worked! 😁
                      Yhank you very much for the suggestion 😊
                      • Leonard03undefined Leonard03 marked this topic as a question
                      • Leonard03undefined Leonard03 has marked this topic as solved
                      • IndeX4Dundefined
                        IndeX4D
                        I have the same behaviour but when manually press pause button, but 3.5 beta2
                        What can I do?
                        Thanks
