    Tweaking my firmware for a better print.
    • mendeleviumundefined
      mendelevium
      I have a 3d printer which I produced. The X and Y movements are with a 2.5mm pitch x 16mm ball screws.
      I am not so happy with the print quality and get various blobs... I have looked around and tweaked but still not happy with the print quality. The same printer produced impeccable prints with just a Ramps/Arduino board but I believe it must be some adjustments I need to make in the firmware. Now some commands are placed in the 3d Slicer. I use simplify 3D and I have pasted the startup and end script. Any suggestions by you experts with duet 3D welcome. what I am not happy most is that I get a lot of blobs all over. I have checked the interpolation steps and they are as suggested in the forum. Many thanks in advance.
      M81 ; Pin PS ON (State is normally on but just in case it was put off by M code M80)
      ; PRESSURE ADVANCE
      ;M572 D0:1 S1.50:1.50
      ;placed pressure advance command in simplify 3d start script
      ; GENERAL PREFERENCES
      M550 P"MENDELEVIUM 3D HULK TWIN TOOLS" ; set printer name
      ; NETWORK SETTINGS
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      ; NOTE DRIVES S0 FORWARD S1 REVERSE
      ;DRIVES ORIENTATION
      M569 P0 S1 ; X physical drive 0 goes backwards
      M569 P1 S1 ; Y physical drive 1 goes forwards
      M569 P2 S1 ; Z physical drive 2 goes backwards
      M569 P3 S0 ; E0 physical drive 3 goes backwards
      M569 P4 S1 ; E1 physical drive 4 goes backwards
      M584 X0 Y1 Z2 E3:4 ; set drive
      ;MAPPINGS
      ;M350 X16 Y16 Z16 E16:16 I1 ; configure
      ;MICROSTEPPING WITH INTERPOLATION SETTINGS
      M92 X160 Y160 Z400.00 E297.80:297.80 ; set steps per mm
      ;SETTING OF INSTANTANEOUS MAXIMUM SPEED CHANGES IN MM/MIN
      M566 X1000.00 Y1000.00 Z100.00 E750.00:750.00
      ;MAXIMUM SPEEDS IN MM/MIN
      M203 X4000.00 Y4000.00 Z2000.00 E2400.00:2400.00
      ;SET ACCELERATION IN MM/SEC SQUARED
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00
      ;MOTORS MAXIMUM CURRENT
      ; NOTE 60 mm steppeprs max current 2.1A
      ; NOTE Board max current 2.4A
      M906 X2100 Y2100 Z2100 E1200:1200 I30
      ;SET IDLE TMEOUT
      M84 S30
      ;AXIS LIMITS OF MINIMUM TRAVEL
      M208 X0 Y0 Z0 S1
      ;AXIS LIMITS OF MAXIMUM TRAVEL
      M208 X345 Y301 Z261.05 S0
      ; ENDSTOPS
      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop
      M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
      M558 P1 I0 C"zprobe.in" H5 R0.2 F1000 X0 Y0 Z100 ; piezo inserted 12/12/22
      ;DEFINITION OF MESH GRID MOVED TO MACRO BED MAPPING
      ;M557 X15:215 Y15:195 S20
      ;CONFIGURATION OF THERMISTORS
      ;HEATBED
      ;HOTENDS 0-e0
      ;Hotend 1-e1
      M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
      ;MAPPING OF HEATER OUT PUT TO SPECIFIC SENSORS
      ;HEATBED
      ;MACHINE HEATERS
      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
      ;AUTOTUNED M307
      ;HEATBED
      M307 H0 R1.058 C224.9 D2.17 S1.0 V24.3 ; autotuned value
      ;HOTEND 0
      M307 H1 R2.407 C189.6:163.8 D4.90 S1.00 V24.3 ; autotuned value
      ;HOTEND 1
      M307 H2 R2.562 C179.0:165.4 D3.60 S1.00 V24.3 ; autotuned value
      ;MAXIMUM HEATER TEMPERATURES
      ;S VALUE IS MAX PERMITTED TEMPERATURE
      ;HEATER 0-BED
      M143 H0 S110 ; set temperature limit for heater 0 to 120C
      ;HOTEND 0
      M143 H1 S310
      ;HOTEND 1
      M143 H2 S310
      HEATBED MAPPING
      ; FANS TO COOL PART ON NOZZLE 1 & NOZZLE 2
      M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
      ;WATER COOLER
      M950 F2 C"fan2" Q500 ; create fan 1 on pin fan1 and set its frequency
      M106 P2 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
      ; Tools as per forum instruction
      M563 P0 S"EXTRUDER 0" D0 H1 F0 ;TOOL 0 USES DRIVE 0 AND HEATER 1
      G10 P0 S0 R0 X-16.5 Y0 ; set tool 0 axis offsets
      M563 P1 S"EXTRUDER 1" D1 H2 F1 ; define tool 1
      G10 P1 S0 R0 X16.5 Y0 ; set tool 1 axis offsets
      ; FILAMENT MONITOR LASER WITH MICROSWITCH
      ; R Values may need setup according to different filaments
      ;TEMPORARY DEACTIVATED FILAMENT MONOTOR
      ;M591 D0 P6 C"e0stop" R1:600 E30 S1
      ;M591 D1 P6 C"e1stop" R1:600 E30 S1
      ; MISCELLANEOUS
      Simplify 3d program startup script;-
      M81 ; AUTO OFF FUNCTION IS SWITCHED OFF AND LATCHING RELAY IS ON (NORMALLY CLOSED)
      G28 Z0 X0 Y0
      M106 P0 S0 H-1
      M106 P1 S0 H-1
      M115 U3.1.0
      M83
      M140 S90 T0 ;BED temp set
      M104 S220 T0 ; EXTRUDER 0 TEMP HEAT
      M109 S220 ; Wait until temperatures stabilize
      M105
      G21
      G90
      M83
      G0 Z299
      G0 Y0 X0 F3000
      G29 S1; APPLY BEDMESH MAPPING
      G0 Z10 F1000
      G1 Z0.15 F1000
      G92 E0
      G1 Y100.0 E25 F400.0
      G1 Y200.0 E20 F800.0
      G1 Y270 E15 F400.0
      G1 Y290 E2 F600
      G1 Z25 F300
      M106 P2 S255 H-1
      M572 D0 S1.25 ; PRESSURE ADVANCE
      G0 Z5
      END SCRIPTS
      G91 ;relative position set
      G1 Z10 F1000
      G1 E-20 F150 ; retarct 20mm of filament to avoid burning
      M140 S0 ; turn off bed
      M104 S0 ; turn off extruder
      M109 S50 ; wait for extruder temp to reach cooldown
      M106 P0 S0 H-1 ;Cooling FAN 0 Switch off
      M106 P1 S0 H-1 ;Cooling FAN 1 Switch off
      M106 P2 S255 H-1 ; WATER COOLING HEAD SWITCHED OFF
      G90 ; Absolute position set
      G28 Z0
      G91 ;realtive mode
      G1 Z-5 F500 ; Z axis lowered 5mm from max
      G90 ; absolute mode returned
      M84 ; disable motors
      M80 ; Auto Off or work ready alarm activated
        Can you share your slicer settings and some photos of what you're actually seeing?
          mendelevium
          These were worse since I already had cleaned off the sides a bit...
            I would say that looks like over extrusion.
            mendeleviumundefined 2 Replies Last reply Reply Quote 0
              mendelevium @Phaedrux
              @Phaedrux the material does not look great but the blob pieces all over are what is bothering me more.
                @Phaedrux have yo taken a look at the slicer settings? the machine has a bowden extruder
                  deckingman @mendelevium
                  @mendelevium Things to try. 1. I have never seen such a high pressure advance setting (S1.25). Are you sure that's right? Try reducing or even disabling it just to see what difference it makes. 2. Do the blobs coincide with retractions? If so,look at your retraction settings but note that there is an interaction between PA and retraction so do the PA first. Using firmware retraction wil enable you to change settings "on the fly". 3. You haven't specified what filament you are using. Have you printed a temperature tower to ascertain the correct value to use for your machine! If not, do so. 4. If the blobs are seemingly random, try another reel of filament but do (3) first. 5. Try an extrusion multiplier of 0.95 or even 0.90 just to see if that helps.
