    Extruder or Slicer issue? Filament not extruding properly?
    1.8k
    • iamthebest22undefined
      iamthebest22
      Thanks DR8. I use custom profile so it's 1.75mm. Nozzle is indeed 0.4 in custom PLA profile and printer settings. I did figure out my esteps was wrong (imported my friends who uses 0.9 degree motor when I use 1.8 degree motor) and fixed that, but still clicking. I adjusted the knob pressure and it's clicking much less now, still need to figure that out. Motor was at 1200, I've turned it down to 1000 since it was running hot (40C) but I guess I'll turn it back up to 1200 to check.
      Where is the function in Cura to check relative extrusion? o.o I can't find it in 3.0.3 at all. I am considering buying S3D and trying that out.
      The interesting thing about the mid power shut down (and doesn't turn back up) is that it happened near the print, while it didn't happen during the other near finished but failed prints. Gah so close yet so far…. this HEVO xD
      EDIT: Never mind found the relative extrusion under special modes. It is checked, so does that mean I don't need to put M82 in start gcode for the HEVO profile anymore in Cura?
      • burtoogleundefined
        burtoogle
        As mentioned several times already on this forum: Cura 3 onwards supports relative extrusion mode (I think the setting is under special modes but it is enabled by default when the gcode flavour is set to reprap). Relative extrusion will be used for all generated extrudes but before any scripts (start code, end code, tool change code, etc.) are included, the extrusion mode will be set to absolute and then back to relative when the script finishes. So if you want to use relative extrusion mode in a script you have to add M83 yourself to select that. Yes, I know that forcing absolute mode in scripts is dumb but the Cura devs insisted upon it for some reason that I don't really understand. We have to live with that.
          burtoogle
          BTW set relative extrude mode is M83, set absolute mode is M82. This conflicts with what you are using in the scripts above.
            iamthebest22
            Hi burtoogle, yeah i just found it under special modes, had to turn it on to see it.
            OH so it isn't M82 but M83 I should have put in the start gcode, Gosh darn it, everything I've been doing wrong so far has been doing the opposite thing for some reason. However, since I have relative extrusion mode set already in the profile, do I still need that M83 in the start gcode? Or just for safe measures. Thanks
            EDIT: reading your comment in more detail, if I did not misunderstood, so I should put M83 in the start gcode nevertheless, and then M82 in the end Gcode, so it should look like this for start gcode:
            G28 ;Home
            G1 Z15.0 F6000 ;Move the platform down 15mm
            G92 E0
            G1 E-3 F300
            G32 ; ABL for HEVO
            G92 E0
            G1 X5 Y5 Z0.3 ; position for priming
            G1 F200 E11
            M83 ;Must set for Duet to use relative extrusion
            and this for end gcode:
            M104 S0
            M140 S0
            G92 E1
            G1 E-3 F300
            G28 X0 Y0
            M84
            M82 ;Back to exact/absolute extrusion
            correct?
              burtoogle
              Those M82 and M83s are not required but not actually causing a problem because right after those scripts are included, Cura will add the M82 or M83 depending on what mode you are using. You only need to put M83 in a script if you actually want to do some relative extruder move within the script itself. So, for example, the end script I use looks like this:
              M83 ; extruder relative mode
              G1 E-5 F2000 ; retract
              M104 S0 ; turn off extruder
              M140 S0 ; turn off bed
              M106 S0 ; turn off fan
              G28 ; home
              ```It starts with an M83 because I want to do a retract. My start script doesn't include an M83 because that will be added by Cura after the script.
              • DR8undefined
                DR8
                you can leave M82 in the start Gcode. Just enable the relative extrusion function and that's it. do some tests by lowering the flow and see the result. Also try with slic3r.
                The power interruptions may be due to bad power source. I had a friend with exactly the same problem as yours. So buy a new one and do some tests. You can buy 12V 20-25A or 24V at 10 A. Keep us updated. And also make sure you have a good power cord not a chinese one and plug the printer into another socket.
                  iamthebest22
                  Thanks all, seems to work, right now just seems like it's more of a hardware then software now. yeah next time I'm not buying clones or certain items , as I've had to spend so much time on them that buying an authentic one probably would have saved me the time and the money in the long run. Yes my extruder is a TriangleLabs titan clone, nothing but trouble it seems, authentic one on the way but yeah. Seems like it's working properly in Cura though. Some pics:
                  • DR8undefined
                    DR8
                    Change the extruder when arrives and be sure to have qualitative filament, it s really important. Hope everything to be fine. Duet is an awesome electronics, i hope for you to feel the taste soon.
                      iamthebest22
                      Thanks very much for the help once again, I seemed to have solved it, and it was partially me being idiotic. The clone came with also a 3.0 filament part and 2 1.75mm, and I didn't check and that was part of the problem xD installed the correct and adjusted the tension and I don't hear the clicking anymore, at least it's so silent I have to put my ear right onto the clone (literally) to hear like a barely audible click (almost non existent). and it's so far seem to be well. So hopefully that seems to be fine now, but I couldn't finish the print because of another issue, which I'll post here, but it does seem to be hardware related.
                      70% of the cube test print through when I noticed a weird smell, I thought it was the filament, but noticed the smell was coming out of my power supply. No smoke yet, but I immediately stopped the print and once it cooled down, unplugged the power supply. Power supplies shouldn't make a smell right? This is the last time I buy from that aliexpress supplier again….
                      So will this power supply do and be safe? From the reviews it seems like it (has to be amazon.ca since I live in Canada)
                      https://www.amazon.ca/gp/product/B01HTF1Q06/ref=ox_sc_act_title_2?smid=A1WG60CSCAVTUM&psc=1
                      • DADIYundefined
                        DADIY
                        @iamthebest22:
                        I have a similar power supply from eBay and it smelt of electrical burning for a good few hours when it was new, I kept an eye on it and gradually the smell stopped over a couple of days.
