6HC - which temperature input uses which ADC bank?
I have a need to compare two temperature sensors and so I want to eliminate as many external variables as possible. I note that the documentation states - quote "Duet 3 Mainboard 6HC and 6XD have two banks of ADC inputs, and sometimes exhibit different errors on different ADC banks". So I'd like to ensure that the sensors are both connected to the same ADC bank but I can't see anything obvious in the documentation which tells me which ADC bank is used by which temperature sensor input.
@deckingman on the 6HC, temp 0/1/2 are on one bank and temp3 is on the other.
@dc42 said in 6HC - which temperature input uses which ADC bank?:
Thanks David.
