Motedis 2020 i-type drop in t-nuts
1.6k
    jannisj
    I followed dc42's build guide for kossel build, and got 2020 i-type extrusions from Motedis.
    I ordered t-nuts (m3,m4 and m5) from Robotdigg, but it seems they dont fit the Motedis extrusions.
    Where can I find t-nuts that work?
    -Jannis
      Moremetall
      http://www.motedis.se/shop/table_cats.php?table_id=19&layer=232
      Br
      Micael
        jannisj
        @Moremetall:
        No other place to get them?
        Motedis do not ship to Norway, so I had to get it shipped to a different country, and pick it up there.
        It was ok for the extrusions, due to the huge save in cost, but the t-nuts will be pretty expensive unless I can get them elsewhere.
        -Jannis
          Jimborr
          These should work too, but the can be a pain sometimes since there is no spring on them
          https://www.ebay.co.uk/itm/60pcs-2020-aluminum-Extrusion-T-Slot-nuts-Aluminum-profiles-Nut-M3-M4-M5-Nuts/252397788683?hash=item3ac4149e0bⓂmmgQhJtXQHn8lXc1JzergPw
            Jimborr
            Or here..
            https://www.ebay.co.uk/itm/M3-M8-Steel-ball-T-Slot-Nuts-Aluminum-Accessories-For-20X20-30-40-45-Series/112320385722?hash=item1a26d112baⓂm38cKecNc9nTnsZvvf6qREg
              jannisj
              Thanks!
              -J
                jannisj
                @Jimborr:
                These are the ones I got that's for B-type and not I-type.
                B-type = 6mm, I-type = 5mm.
                Eg. they wont turn in the slot unfortunately
                -J
                  DADIY
                  @jannisj:
                  -Jannis
                  If you have access to a 3d printer you could print your own t nuts. There are various types on thingiverse.
                    number40fan
                    If you have anything but 6mm t slots, give up. I could never find anything either. Why it is even made, I don't know. Even the company in the states (8020.com) doesn't list any for their own extrusions.
                      The nuts in this listing https://www.ebay.co.uk/itm/M3-M8-Steel-ball-T-Slot-Nuts-Aluminum-Accessories-For-20X20-30-40-45-Series/112320385722?hash=item1a26d112baⓂm38cKecNc9nTnsZvvf6qREg look the same as the Motedis ones. But what you really need to know is the slot width that they are designed for.
                      I have some Motedis nuts left over, but probably not as many as you need.
                      7 out of 10
