    asking again, Duet 3 6hc running Klipper?
    Using Duet Controllers
    klipper duet3 duet36hc
    12
    28
    3.3k
    • b3lmansundefined
      b3lmans @oliof
      @oliof Thanks a lot!
      • gnydickundefined
        gnydick
        Not sure if anyone is tracking this thread. I recently converted 6hc to klipper and got everything working until it came time to connect the tool distribution board and tool boards. As far as I can tell, that setup is not supported whatsoever.
        I also didn't know how, if possible, to connect to the SBC with the ribbon cable.
        • oliofundefined
          oliof @gnydick
          @gnydick Klipper's CAN implementation does not hold water to RRF's CAN-FD one. Most klipper people I know use USB to connect their secondary MCUs and toolboards, which seems to be better supported on klipper (see https://os.ratrig.com/blog/no-you-dont-want-to-use-can/ for a rant against CAN on klipper). You won't be able to use the 1LC board since the efforts to port klipper to it died from lack of interest.
          gnydickundefined oliofundefined 2 Replies Last reply Reply Quote 2
          • gnydickundefined
            gnydick @oliof
            @oliof yeah, i learned that the hard way. I got my entire machine converted, sans the tool boards, and then came the pain. converted it all back.
            • oliofundefined
              oliof @oliof
              I have just been told that development of klipper for the 1LC toolboards has been resumed. So lets see where that goes. People would still need to add a separate accelerometer since klipper does not support LIS3DH ... (edit https://github.com/Klipper3d/klipper/pull/6009/ -- currently misses any documentation about how to get it flashed etc.)
              Wulfsta opened this pull request in Klipper3d/klipper
              closed atsamd: Add support for SAMC21 #6009
              Wulfstaundefined 1 Reply Last reply Reply Quote 0
                A Former User
                This post is deleted!
                oliofundefined 1 Reply Last reply Reply Quote -1
                • oliofundefined
                  oliof @A Former User
                  @Herve_Smith I would prefer a constructive and friendly tone in this forum. Especially since you seem to agree that CAN on Klipper is not a good idea.
                  A Former User? 1 Reply Last reply Reply Quote 3
                    A Former User @oliof
                    oliofundefined 1 Reply Last reply Reply Quote -2
                    • oliofundefined
                      Trust me, your post does reflect badly on this community.
                      A Former User? 1 Reply Last reply Reply Quote 2
                        oliofundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote -3
                        • oliofundefined
                          @Herve_Smith And a good day to you you, too!
                            T3P3Tony administrators @A Former User
                            @Herve_Smith the issue with your post is not that you believe the problems with klipper's can bus usage are due to the implementation, rather than the underlying architecture. The issue is the personal attacks: "raving idiot" , along with the overly aggressive tone.
                            As @oliof has already pointed out, there is no place on this forum for this behaviour. Please use a constructive and friendly tone, even when you disagree with an opinion.
                            • Wulfstaundefined
                              Wulfsta @oliof
                              @oliof I posted a script to flash 1LC boards using OpenOCD and a Pi elsewhere on the forum.
                              oliofundefined 1 Reply Last reply Reply Quote 1
                              • oliofundefined
                                oliof @Wulfsta
                                @Wulfsta this one I presume https://forum.duet3d.com/topic/29857/raspberry-pi-4-to-toolboard-1lc-with-openocd/14?_=1682879698520
                                Wulfstaundefined 1 Reply Last reply Reply Quote 1
                                • Wulfstaundefined
                                  Wulfsta @oliof
                                  @oliof yeah, that’s it. Huge pain to figure that out. I’ll add docs to klipper eventually, but it’s not my priority at the moment. Meanwhile it should be easy enough to figure out by looking at the schematics.
