    asking again, Duet 3 6hc running Klipper?
    Using Duet Controllers
    klipper duet3 duet36hc
    12
    28
    3.3k
    • oliofundefined
      oliof @pm7399
      @pm7399 said in asking again, Duet 3 6hc running Klipper?:
      @oliof with all due respect I have never found discord to be the best resource on anything.
      I'm not necessarily disagreeing, but in this case it's more or less the only source.
        droftarts administrators @pm7399
        @pm7399
        I'/m very close to just sending this board back to amazon
        If you bought your Duet on Amazon, most likely it is a clone board. Afaik no genuine reseller sells them on Amazon.
        Keep in mind there's a lot more documentation for every other duet board EXCEPT the 6hc.
        A lot of documentation exists for the Duet 2, because it’s older. I’ve spent the last year updating the wiki for Duet 3. Follow the ‘how to’ guides on the main documentation wiki:
        https://docs.duet3d.com/
        Also there’s a Getting started guide https://docs.duet3d.com/User_manual/Overview/Getting_started_Duet_3_MB6HC and the hardware page https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6HC_Hardware_Overview
        I can make the connectors I even can understand where to put the wires on the main board but macros and pins have me puling my hair out, even with that configurator website.
        To understand and for a description of macros, see the ‘Macros’ section here: https://docs.duet3d.com/en/User_manual/Tuning
        Generally the configuration tool will create the macros you need, based on the numbers you input, and at least initially you are unlikely to need other macros.
        For pins and pin names, RRF uses the physical pin name to define the pin something connects to, and is the same as the pin name on the wiring diagram. Better than a arbitrarily defined number, surely?
        it doesn't let me add a second z axis but I read something about using m583 (or something) to add it later but WHERE?!?! and HOW?!
        It’s M584 you need to edit in your config.g. See https://docs.duet3d.com/User_manual/Connecting_hardware/Motors_configuring#using-more-than-one-motor-on-an-axis-with-a-separate-driver-for-each-motor
          A Former User @pm7399
          This post is deleted!
            Phaedrux Moderator @droftarts
            @droftarts said in asking again, Duet 3 6hc running Klipper?:
            There is one now. 3DMakerWorld.
            • b3lmansundefined
              b3lmans @pm7399
              @pm7399 any luck? I am in the same situation...Can't find a cfg for it
              • oliofundefined
                oliof @b3lmans
                @b3lmans It looks like @Luke-sLaboratory worked on a config https://github.com/Klipper3d/klipper/pull/5818 but it wasn't merged due to some missing cleanup work.
                lukeslaboratory opened this pull request in Klipper3d/klipper
                closed Config: Add Duet3 6hc config #5818
                b3lmansundefined 1 Reply Last reply Reply Quote 0
                • b3lmansundefined
                  b3lmans @oliof
                  @oliof Thanks a lot!
                  • gnydickundefined
                    gnydick
                    Not sure if anyone is tracking this thread. I recently converted 6hc to klipper and got everything working until it came time to connect the tool distribution board and tool boards. As far as I can tell, that setup is not supported whatsoever.
                    I also didn't know how, if possible, to connect to the SBC with the ribbon cable.
                    • oliofundefined
                      oliof @gnydick
                      @gnydick Klipper's CAN implementation does not hold water to RRF's CAN-FD one. Most klipper people I know use USB to connect their secondary MCUs and toolboards, which seems to be better supported on klipper (see https://os.ratrig.com/blog/no-you-dont-want-to-use-can/ for a rant against CAN on klipper). You won't be able to use the 1LC board since the efforts to port klipper to it died from lack of interest.
                      gnydickundefined oliofundefined 2 Replies Last reply Reply Quote 2
                      • gnydickundefined
                        gnydick @oliof
                        @oliof yeah, i learned that the hard way. I got my entire machine converted, sans the tool boards, and then came the pain. converted it all back.
                        • oliofundefined
                          oliof @oliof
                          I have just been told that development of klipper for the 1LC toolboards has been resumed. So lets see where that goes. People would still need to add a separate accelerometer since klipper does not support LIS3DH ... (edit https://github.com/Klipper3d/klipper/pull/6009/ -- currently misses any documentation about how to get it flashed etc.)
                          Wulfsta opened this pull request in Klipper3d/klipper
                          closed atsamd: Add support for SAMC21 #6009
                          Wulfstaundefined 1 Reply Last reply Reply Quote 0
                            A Former User
                            oliofundefined 1 Reply Last reply Reply Quote -1
                            • oliofundefined
                              oliof @A Former User
                              @Herve_Smith I would prefer a constructive and friendly tone in this forum. Especially since you seem to agree that CAN on Klipper is not a good idea.
                              A Former User? 1 Reply Last reply Reply Quote 3
                                A Former User @oliof
                                oliofundefined 1 Reply Last reply Reply Quote -2
                                • oliofundefined
                                  Trust me, your post does reflect badly on this community.
                                  A Former User? 1 Reply Last reply Reply Quote 2
                                    oliofundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote -3
                                    • oliofundefined
                                      @Herve_Smith And a good day to you you, too!
                                        T3P3Tony administrators @A Former User
                                        @Herve_Smith the issue with your post is not that you believe the problems with klipper's can bus usage are due to the implementation, rather than the underlying architecture. The issue is the personal attacks: "raving idiot" , along with the overly aggressive tone.
                                        As @oliof has already pointed out, there is no place on this forum for this behaviour. Please use a constructive and friendly tone, even when you disagree with an opinion.
                                        • Wulfstaundefined
                                          Wulfsta @oliof
                                          @oliof I posted a script to flash 1LC boards using OpenOCD and a Pi elsewhere on the forum.
                                          oliofundefined 1 Reply Last reply Reply Quote 1
                                          • oliofundefined
                                            oliof @Wulfsta
                                            @Wulfsta this one I presume https://forum.duet3d.com/topic/29857/raspberry-pi-4-to-toolboard-1lc-with-openocd/14?_=1682879698520
                                            Wulfstaundefined 1 Reply Last reply Reply Quote 1
