Filament Monitor Disbaled for First layer only
Filament Monitor
458
    selva_tvi
    Hi all,
    We are using Duet 3D Filament Monitor for our IDEX machine,
    Board - Duet 6 XD.
    When we start the print, sometimes for the first layer we need to give baby stepping. Before giving the baby stepping itself, the Filament monitor shows as runout and it pauses the print.
    Is there any way to disable the FRS for the 1st layer and enable from 2nd layer?
    Thanks
      jay_s_uk
      maybe something like this in daemon.g
      if job.layer = 0
      M591 D0 P0
      else
      M591 D0 P1 C"e0stop"
      or whatever your filament monitor is
      undefined 1 Reply Last reply 24 Apr 2023, 13:21 Reply Quote 0
        selva_tvi @jay_s_uk
        @jay_s_uk said in Filament Monitor Disbaled for First layer only:
        if job.layer = 0 M591 D0 P0else M591 D0 P1 C"e0stop"
        I tried adding the below lines in daemon.g
        if job.layer = 0
        M591 D0 P0
        M591 D1 P0
        else
        M591 D0 P3 C"121.io1.in" E5 S1 R10:190 ; Filament Runout Sensor for tool 0
        M591 D1 P3 C"122.io1.in" E5 S1 R10:190 ; Filament Runout Sensor for tool 1
        Disabled these lines from config.g
        Before starting the print, it shows No Filament present.
        As soon as I hit the print button, the filament monitors are enabled.
        'M591 D1
        Duet3D rotating magnet filament monitor v4 on pin 122.io1.in, enabled'
        undefined undefined 2 Replies Last reply 24 Apr 2023, 13:25 Reply Quote 0
          jay_s_uk @selva_tvi
          @selva_tvi sorry, i meant job.layer = 1 not 0.
          They will be activated the rest of the time.
          We could always expand it a bit to only run when the printer is processing.
          if job.layer = 0 & state.status = "processing"
          M591 D0 P0
          M591 D1 P0
          else
          Don't forget they need to be indented accordingly
            dc42 administrators @selva_tvi
            @selva_tvi I suggest you disable the filament monitor in either the slicer start GCode or in your start.g file. Then enable it either in the slicer layer change script or in daemon.g when the layer number reaches 1 or 2.
            undefined 1 Reply Last reply 24 Apr 2023, 15:53 Reply Quote 0
              selva_tvi @dc42
              @dc42 @jay_s_uk Thanks for the support.
              I tried giving M591 D0 P0 at the start and after Layer 2 enabling as M591 D0 P3.
              But that didn't work.
              Then I enabled FRS in config.g as usual, then rewrote daemon.g as below:
              if job.layer = 1 & state.status = "processing"
              M591 D0 S0
              M591 D1 S0
              else
              M591 D0 S1
              M591 D1 S1
              For the first layer, both were disabled and then after 2nd layer it was enabled.
              undefined 1 Reply Last reply 24 Apr 2023, 22:20 Reply Quote 2
              • undefined Phaedrux marked this topic as a question 24 Apr 2023, 18:21
              • undefined Phaedrux has marked this topic as solved 24 Apr 2023, 18:21
                @selva_tvi said in Filament Monitor Disbaled for First layer only:
                That's not what I meant. Configure the filament monitor in config.g as usual. Then use M591 D0 S0 at the start of the job or in start.g to disable it, and M591 D0 S1 at layer 2 to enable it.
                undefined 1 Reply Last reply 25 Apr 2023, 06:14 Reply Quote 0
                  selva_tvi @dc42
                  @dc42 Yes, I have configured the FRS as usual in config.g.
                  Then in the daemon.g as below:
                  M591 D0 S0
                  M591 D1 S0
                  else
                  M591 D0 S1
                  M591 D1 S1
                  When the print starts, it shows both the FRS is disabled at layer 1.
                  Then from Layer 2, it shows as enabled.
                  By the way, may I know the difference in keeping the above commands in daemon.g vs start.g?
                  Thanks
                  undefined 1 Reply Last reply 25 Apr 2023, 07:01 Reply Quote 0
                    OwenD @selva_tvi
                    start.g will be run once before the print starts so it makes sense to disable your filament sensors there.
                    daemon.g will run by default every 10 seconds, so it's probably using resources needlessly in this case, but it's not going to hurt anything albeit that there's a possible 10 second delay between your layer starting and the sensors beinf enabled.
                    You could use that to enable your sensors or you could just us your slicer's before layer change section.
                    In superslicer or pruser slicer you could use this to only enable the sensors at the start of layer 2
                    {if layer_num == 2}
                    ;enabled filament sensors on layer 2
                    M591 D0 S1
                    M591 D1 S1
                    {endif}
                    Output in Gcode
                    undefined 1 Reply Last reply 25 Apr 2023, 11:19 Reply Quote 0
                      selva_tvi @OwenD
                      @OwenD said in Filament Monitor Disbaled for First layer only:
                      I disabled daemon.g and kept the below contents in start.g
                      M591 D0 S0
                      M591 D1 S0
                      else
                      M591 D0 S1
                      M591 D1 S1
                      But it didnt work. Even at layer 1, it was enabled only.
                      Any change to be made?
                      undefined 1 Reply Last reply 25 Apr 2023, 19:54 Reply Quote 0
                        OwenD @selva_tvi
                        M591 D0 S0
                        M591 D1 S0
                        else
                        M591 D0 S1
                        M591 D1 S1
                        start.g is run before printing starts, so the layer number will be zero
                        Therefore your code would enable the sensor as the layer does not equal one.
                        In start.g just disable the sensors without any if conditions.
                        If you use the slicer layer change code I gave then it puts the enabling commands in the print gcode.
                        Otherwise use daemon.g to do the enabling if you can't use the slicer layer change section
                        5 out of 11
