    SD card doesn't auto mount, Wifi module won't auto start
    378
      Can you share the results of sending M122 from YAT both from a fresh boot up and after having mounted the SD card?
      • Macuaundefined
        Macua
        Fresh boot:
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later
        Board ID: 08DGM-917NK-F2MS4-7J9F6-3S06P-9YSSD
        Used output buffers: 1 of 26 (1 max)
        Static ram: 23836
        Dynamic ram: 74984 of which 12 recycled
        Never used RAM 13248, free system stack 195 words
        Tasks: NETWORK(ready,11.2%,380) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) MAIN(running,87.5%,423) IDLE(ready,1.3%,30), total 100.0%
        Owned mutexes: USB(MAIN)
        Last reset 00:01:12 ago, cause: power up
        Last software reset at 2023-04-20 22:29, reason: User, GCodes spinning, available RAM 13104, slot 2
        Error status: 0x00
        Step timer max interval 0
        MCU temperature: min 13.1, current 18.1, max 18.5
        Supply voltage: min 1.3, current 1.4, max 3.2, under voltage events: 0, over voltage events: 0, power good: no
        Events: 0 queued, 0 completed
        Driver 0: ok, SG min n/a
        Driver 1: ok, SG min n/a
        Driver 2: ok, SG min n/a
        Driver 3: ok, SG min n/a
        Driver 4: ok, SG min n/a
        Driver 5:
        Driver 6:
        Driver 7:
        Driver 8:
        Driver 9:
        Driver 10:
        Driver 11:
        Cache data hit count 3016920628
        Slowest loop: 300.17ms; fastest: 0.14ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 0.3ms, write time 0.0ms, max retries 0
        DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
        === MainDDARing ===
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is ready with "M122" in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty
        === Network ===
        Slowest loop: 99.89ms; fastest: 0.00ms
        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        HTTP sessions: 0 of 8
        = WiFi =
        Network state is disabled
        WiFi module is disabled
        Failed messages: pending 0, notready 0, noresp 3
        ok
        With the SD Mounted:
        M21
        T0:21.2 /0.0 B:19.9 /0.0
        SDHC card mounted in slot 0, capacity 7.86Gb
        ok
        M122
        Used output buffers: 1 of 26 (11 max)
        Static ram: 23836
        Never used RAM 13248, free system stack 193 words
        Tasks: NETWORK(ready,10.4%,380) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) MAIN(running,89.6%,420) IDLE(ready,0.0%,30), total 100.0%
        Last reset 00:02:57 ago, cause: power up
        Error status: 0x00
        MCU temperature: min 18.0, current 19.2, max 19.4
        Supply voltage: min 1.3, current 1.4, max 1.4, under voltage events: 0, over voltage events: 0, power good: no
        Driver 5:
        Driver 6:
        Driver 7:
        Driver 8:
        Driver 9:
        Driver 10:
        Driver 11:
        === Storage ===
        === MainDDARing ===
        === AuxDDARing ===
        Segments left: 0
        Code queue is empty
        === Network ===
        Slowest loop: 1.02ms; fastest: 0.00ms
        = WiFi =
        ok
        Thanks,
        Anthony
          dc42 administrators @Macua
          @Macua thanks. The first M122 report shows that it did read the SD card during startup, so something must have caused it to become unmounted. Are you certain that there isn't a M22 command in config.g? If you send M98 P"config.g" after you have sent M21 to mount the SD card, does it remain mounted?
          • Macuaundefined
            Macua
            Thanks for the reply. There are non M22 commands in the config.g; I used rrf config and not fettled it. If i use the suggested command (M98), it doesn't seem to stay mounted, still has errors if I try to upload a gcode file, or change the config.g and save in DWC. If i refresh DWC, error message saying no files on card. If I M21 in YAT, I can get back on.
            Macuaundefined 1 Reply Last reply Reply Quote 0
            • Macuaundefined
              Macua @Macua
              @Macua
              ; Configuration file for Duet WiFi (firmware version 3.3)
              ; generated by RepRapFirmware Configuration Tool v3.3.16 on Fri Apr 21 2023 15:21:05 GMT+0100 (BST)
              G90                                     ; send absolute coordinates...
              M83                                     ; ...but relative extruder moves
              M550 P"My Printer"                      ; set printer name
              M552 S1                                 ; enable network
              M586 P0 S1                              ; enable HTTP
              M586 P1 S0                              ; disable FTP
              M586 P2 S0                              ; disable Telnet
              M569 P0 S1                              ; physical drive 0 goes forwards
              M569 P1 S0                              ; physical drive 1 goes backwards
              M569 P2 S0                              ; physical drive 2 goes backwards
              M569 P3 S1                              ; physical drive 3 goes forwards
              M584 X0 Y1 Z2 E3                        ; set drive mapping
              M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z200.00 E492.25       ; set steps per mm
              M566 X900.00 Y900.00 Z60.00 E120.00     ; set maximum instantaneous speed changes (mm/min)
              M203 X10000.00 Y10000.00 Z1200.00 E3000.00 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
              M906 X1200 Y1200 Z1200 E1250 I30        ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                 ; Set idle timeout
              M208 X0 Y0 Z0 S1                        ; set axis minima
              M208 X210 Y210 Z205 S0                  ; set axis maxima
              M574 X1 S1 P"!xstop"                    ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !xstop
              M574 Y1 S1 P"!ystop"                    ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !ystop
              M574 Z1 S1 P"!zstop"                    ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin !zstop
              M558 P0 H5 F120 T6000                   ; disable Z probe but set dive height, probe speed and travel speed
              M557 X15:210 Y15:195 S20                ; define mesh grid
              M308 S0 P"spi.cs1" Y"rtd-max31865"      ; configure sensor 0 as PT100 on pin spi.cs1
              M950 H0 C"bedheat" T0                   ; create bed heater output on bedheat and map it to sensor 0
              M307 H0 R0.267 K0.253:0.000 D2.42 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
              M140 H0                                 ; map heated bed to heater 0
              M143 H0 S120                            ; set temperature limit for heater 0 to 120C
              M308 S1 P"spi.cs2" Y"rtd-max31865"      ; configure sensor 1 as PT100 on pin spi.cs2
              M950 H1 C"e0heat" T1                    ; create nozzle heater output on e0heat and map it to sensor 1
              M307 H1 B0 S1.00                        ; disable bang-bang mode for heater  and set PWM limit
              M143 H1 S280                            ; set temperature limit for heater 1 to 280C
              M950 F0 C"fan0" Q500                    ; create fan 0 on pin fan0 and set its frequency
              M106 P0 S0 H1 T28                       ; set fan 0 value. Thermostatic control is turned on
              M950 F1 C"fan1" Q500                    ; create fan 1 on pin fan1 and set its frequency
              M106 P1 S1 H-1                          ; set fan 1 value. Thermostatic control is turned off
              M950 F2 C"fan2" Q500                    ; create fan 2 on pin fan2 and set its frequency
              M106 P2 S1 H1 T45                       ; set fan 2 value. Thermostatic control is turned on
              M563 P0 D0 H1 F0:1                      ; define tool 0
              G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
              G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
              T0                                      ; select first tool
              droftartsundefined dc42undefined 3 Replies Last reply Reply Quote 0
                droftarts administrators @Macua
                @Macua I'd say it sounds like a failing SD card. Is it new? Send M39 to see how much space there is on it, and post the response.
                You could try reformatting it, and copying the files over fresh. Copy your configuration files off it first, then see https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#formatting for formatting, and https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#creating-the-file-structure for recreating the file structure.
                  @Macua if a new SD card doesn't help, please send a close up photo of the soldering of the contacts on the back of the SD card socket. We've seen issues with that in the past, although not for a year or two since we changed the brand of the socket.
                  • Macuaundefined
                    Macua @droftarts
                    @droftarts
                    This is what I get:
                    M39
                    SD card in slot 0: capacity 7.86GB, partition size 7.85GB, free space 7.83GB, speed 20.00MBytes/sec, cluster size 32kB
                    ok
                    No issues with the card in the laptop.
                    Cheers,
                    Anthony
                      Phaedrux Moderator @Macua
                      @Macua said in SD card doesn't auto mount, Wifi module won't auto start:
                      Yes, but do you have another new SD card to try?
                      • Macuaundefined
                        Macua @dc42
                        Thanks for the help everyone.
                        I’ve tried reformatting a few times with no joy. Just ordered a new SD card so will give that a go tomorrow.
                        The duet I got second hand off eBay, so it’s quite possible it’s of the generation that suffers from the connection/soldering issue.
                        My suspicion is that it’s a hardware issue, but new card tomorrow will confirm hopefully.
                        Many thanks,
                        Anthony
                        • Macuaundefined
                          Macua
                          @dc42 said in SD card doesn't auto mount, Wifi module won't auto start:
                          M98 P"config.g"
                          Well, this is very frustrating. I've got a new SD card, and a replacement Duet wifi 2. I have exactly the same problem, the card is not mounting. Its not running config.g or the runonce.g, so the only way i can set a network up is through YAT manually. I am at a complete loss! The firmware was compiled using RFF config tool, correct version selected. Not sure what to do next?
                            Can you put the card in your PC and take some screen shots of the root directory as well as the sys directory?
                            Perhaps the file structure is incorrect.
                            • Macuaundefined
                              Macua @Phaedrux
                              @Phaedrux
                              Thanks for the reply. Turns out it’s all working now with the new duet board! I expected the card to mount and run the runonce.g for the network settings. When it didn’t assumed same issue. However did some Googling and found that file doesn’t work (?) so programmed the network the usual way through YAT. Now all working perfectly.
                              Thanks for all the help. Now I have to tackle the layer shift problem it’s got. No successful prints yet. Does the duet need active cooling?
                                Never hurts. It depends on how it's mounted and if it's enclosed and how many drivers are being used and at what current, but if you have the means to at least blow a fan across the back side of the board along the drivers it's a good idea.
                                • Phaedruxundefined Phaedrux has marked this topic as solved
                                  With motor currents as low as those, you don't need to cool a Duet 2.
                                  Macuaundefined 1 Reply Last reply Reply Quote 1
                                  • Macuaundefined
                                    Macua @dc42
                                    Just to draw a line under this, layer shift was a mechanical problem, nothing to do with Duet3D...which is simply, amazing. I will start another topic on quality of prints though - my 2014 ultimaker original seems to outperform the Duet with the same hardware, not sure if I can tune it out.
