duet2 get no IP-adresse after firmware update V3.4.4 => V3.4.5
I use a Duet2 with Ethernet.
After updating from V3.4.4 to V3.4.5 Duet2 does not get the IP address anymore.
There are all firmware files in /firmware.
The SD card is ok.
Paneldue works.
USB terminal with cut 5V supply also works.
A M115 via terminal results:
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2022-11-30 19:36:12I am at a loss. Does anyone have any ideas?
regards,
DirkMy config.g:
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 03 2021 02:40:13 GMT+0200 (Mitteleuropäische Sommerzeit) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M555 P2 ; Marlin Mode M550 P"Duet X-Max" ; set printer name ; Network ;M551 P"" ; set password M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; Disable Telnet ; Drives ;M569 P0 S0 ; physical drive 0 goes forwards X Short60 Mod M569 P0 S1 ; physical drive 0 goes forwards X Icarus M569 P1 S1 ; physical drive 1 goes forwards Y M569 P2 S1 ; physical drive 2 goes forwards Z M569 P3 S1 ; physical drive 3 goes forwards E0 M569 P4 S1 ; physical drive 3 goes forwards E1 M584 X0 Y1 Z2:4 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation ;M92 X94.25 Y94.25 Z400.00 E415.00 ; set steps per mm Extruder BMG ;M92 X94.25 Y94.25 Z400.00 E690.00 ; set steps per mm Extruder Icarus M92 X94.25 Y94.25 Z400.00 E690.00 ; set steps per mm Extruder Icarus M566 X300.00 Y300.00 Z120.00 E300.00 ; set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z900.00 E6000.00 ; set maximum speeds (mm/min) M201 X2000.00 Y2000.00 Z15.00 E600.00 ; set accelerations (mm/s^2) ;M201 X800.00 Y800.00 Z15.00 E400.00 ; set accelerations (mm/s^2) M906 X650 Y750 Z400 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X-5 Y-5 Z0 S1 ; set axis minima M208 X300 Y257 Z295 S0 ; set axis maxima ; Endstops M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin xstop M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin ystop M574 Z2 S1 P"!zstop+!e1stop" ; configure active-high endstop for high end on Z via pin zstop M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H10 F600 T3000 A3 R0.5 ; set Z probe type to bltouch and the dive height + speeds ; Set Z probe type/mode 9(BLTouch). ; H=Dive Height. ; F=Speed the bed. ; T=Travel speed to and between probe points (mm/min) ; A=Maximum number of times to probe each point ; R=Z probe recovery time before the probing move M98 P"0:/macros/sys/BLtouchSetDistPos.g" ; set Z probe trigger value, offset and trigger height M98 P"0:/macros/sys/BLtouchSetMeshGrid.g" ; define mesh grid ; Heaters ; heated Bed M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 ;M307 H0 B0 S1.00 ; disable bang-bang mode for bed heater and set PWM limit M307 H0 R0.220 C768.703:768.703 D0.55 S1.00 V24.0 B0 ; disable bang-bang mode for bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C ; Daragon Hotend ;M308 S1 P"spi.cs1" Y"thermocouple-max31855" ; configure sensor 1 as thermocouple via CS pin spi.cs1 M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1 M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 ;M307 H1 B0 R2.592 C165.4:125.4 D7.29 S1.00 V24.1 ; Autotune mit 225°C with PT100 and Dragon HT/60W, without Silikonsock M307 H1 B0 R2.525 C171.0:152.2 D7.05 S1.00 V24.1 ; Autotune mit 225°C mit PT100 und Dragon HT/60W, with Silikonsock M143 H1 S350 ; set temperature limit for heater 1 to 350C ; Chamber Kammerheizung mit PT100 Sensor 2 M308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 2 as PT100 Sensor via CS pin spi.cs2 M950 H2 C"e1heat" T2 Q10 ; create chamber heater output on e1heat and map it to sensor 2 ;M307 H2 B0 S1.00 R0.01 D30 ; disable bang-bang mode for the chamber heater and set PWM limit M307 H2 B1 S1.00 ;Bang Bang for Chamberheaters M141 H2 ; map chamber to heater 2 M143 H2 S65 ; set temperature limit for heater 2 to 65C M570 H2 P20 T15 ; Configure heater fault detection ;Hnnn Heater number ;Pnnn Time in seconds for which a temperature anomaly must persist on this heater before raising a heater fault (default 5 seconds) ;Tnnn Permitted temperature excursion from the setpoint for this heater (default 15C) ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan1 and set its frequency M106 P0 C"F0 Bauteil" B1.0 S0 H-1 L0.08 ; set fan 0 name and value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan0 and set its frequency M106 P1 C"F1 Hotend" S1 H1 T42 ; set fan 1 name and value. Thermostatic control is turned on M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency ;M106 P2 C"F2 Kammer" S0 B2 L0.3 H-1 ; set fan 2 name and value. Thermostatic control is turned off ;M106 P2 C"F2 Kammer" S1 B2 H2 T45 ; Kammerluefter temperaturgeregelt ueber Sensor 2 ;M106 P2 C"F2 Kammer" S1 B1.5 H2 L0.25 X0.5 T60:63 M98 P"0:/macros/sys/Kammerluefter_temp_geregelt.g" ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M564 H0 ; Allow moves without homeing axis M501 ; load saved parameters from non-volatile memory T0 ; select first tool
Can you connect by USB terminal and send M122 and copy and paste the results here?
If you send
M552 S0
M552 S1what does it respond with?
Hello @Phaedrux,
thanks for your answer. Here are the results:
Send: M552 S0 Recv: Network stopped Recv: ok Send: M552 S1 Recv: ok
Any advice?
@Turtletrumpet what do you get if you send the above and then send
M552
@jay_s_uk
I was away for a few days and therefore could not answer. Here now the logs:Send: M552 S0 Recv: Network stopped Recv: ok Send: M552 S1 Recv: ok Send: M552 Recv: Network is enabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0 Recv: ok
Any Idea?
@Turtletrumpet Most likely the WiFi firmware was updated, and the stored SSIDs have been lost. Connect via USB and send M587 to get a list of stored SSIDs. If it is blank, add your SSID. See https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet#h-5-connect-duet-to-network
Hello @droftarts ,
I use an ethernet interface, not a wifi interface. -
Can you flash back to 3.4.4 to see if it resolves?
Can you test a direct connection with your PC?
https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#wired-direct-connection
The error is found. Thank you very much for your effort.
The most unlikely error in my opinion has occurred: The ethernet module is defective.The downgrade to version 3.4.4 did nothing. So I removed the ethernet module from another 3d printer and installed it in my "problem" printer. The printer immediately received an ip address. Problem solved.
When and where did you purchase?
@Phaedrux Hello, I bought here https://www.filafarm.de/
@Turtletrumpet When did you buy the board?
