Solved printer prints the job mirrored
Although everything looks correct in the slicer (Cura) in the preview, theCCR10_KettenaufnahmeV1.gcode printer prints the job mirrored,
what can be the reason?
Attached is the g code -
Usually this happens when you have one axis going the wrong direction.
The slicer assumes you have -x to the left, +x to the right, -y to the front, +y to the back. Can you confirm that?
@axiom what kind of motion system isnyiur printer using?
@Phaedrux yes, i could confirm that
@Phaedrux With negative values, the y-axis moves to the left in the direction of the starting point. the x axis with negative values also to the left in the direction of the starting point. But the question is what to understand as front and rear
@Phaedrux with a little delay i now understand what is meant... i exchanged the x and y axes and endstops on the board and also in the code and now everything seems to be ok... thank you very much!
