Sbc wiring problem
331
    JuL
    Hi, I'm trying to wire à duet3 6hc rev 1.02 with à pi4. What I did:
    -removed sd card from duet
    -Wired 24vdc psu to duet power in
    -wired 5vdc psu to duet ext 5v (+5 and gnd, no pson)
    -put a 2 way jumper between ext 5v and ext 5v sel
    -User original 26 to 40 pin ribbon from duet
    When Turn on, duet seem's to start correctly ( 4 led on + statues led blinking) but no power to pi (I tried pi 3 and pi 4, no led activity at all)
    What am I missing?
    undefined 1 Reply Last reply 6 May 2023, 04:30 Reply Quote 0
      jay_s_uk @JuL
      @JuL you can't power the pi from the 6hc any more. You need to provide power to it separately
        JuL
        OK, not what I expected.So, is it possible to
        wake up pi with pson pin?
        undefined 1 Reply Last reply 6 May 2023, 09:28 Reply Quote 0
          jay_s_uk @JuL
          @JuL what do you mean wake it up?
            JuL
            I mean I don't want to unplug and plug my pi each start
            undefined 1 Reply Last reply 6 May 2023, 10:58 Reply Quote 0
              jay_s_uk @JuL
              @JuL then get a 5v power supply to add to your printer to power it
                JuL
                I already have à 5v psu just for that. Was hoping not to have to do my own ribbon cable(I don't want to use the usb c power port on pi). Thx for the help
                undefined 1 Reply Last reply 8 May 2023, 06:42 Reply Quote 0
                  oliof @JuL
                  @JuL you can still use the 5Vin on thr Pi GPIO header, but be aware that bypasses overvoltage protection.
                    JuL
                    I inverted gpio pins 2, 4 and 6 under the pi board (so no more in the ribbon cable) and solder 5v directly on it. Works like I wanted. Thx
                    • undefined JuL marked this topic as a question 18 May 2023, 07:43
                    • undefined JuL has marked this topic as solved 18 May 2023, 07:43
                    9 out of 9
