    Help!! Didn’t find access point while trying to connect
    Using Duet Controllers
    988
      What IP address did you use?
      You can see what address the Duet is using in the M122 report.
      Your SD card may not have the DWC files in place.
      To be sure, you can extract this zip file into the WWW folder on the SD card.
      https://github.com/Duet3D/DuetWebControl/releases/download/2.0.7/DuetWebControl-SD.zip
      Dillon Brownundefined 1 Reply Last reply Reply Quote 0
      • Dillon Brownundefined
        Dillon Brown @Phaedrux
        @Phaedrux Hmm. Still not working. Should I delete the other files (same names) in the www folder?
          You can delete the entire www folder and re-create it.
          Send a screenshot of the folder structure just to make sure everything is still in the right place.
          What error do you get in the browser when you try and reach the Duet?
          Are you able to ping the Duet IP address from your machine?
          Dillon Brownundefined 2 Replies Last reply Reply Quote 0
            @Phaedrux Screenshot 2023-05-10 at 4.53.27 PM.png Screenshot 2023-05-10 at 4.53.34 PM.png
              This is the error i get in the browser after typing in my IP address.
              I have a sprectrum router that automatically switches between 2.4 and 5ghz. I was able to get a spectrum agent to direct towards 2.4ghz for long enough for my printer to get connected to the wifi and stay connected.
              After typing in M552 S2 i get the message:
              Wifi is providing access point "my network", IP address "my IP"
              I enter the exact same IP address into my browser but neither safari nor chrome will load the page.
              I have also tried http://duettest.local/ and http://myprinter.local/
                Your screenshot looks like it's trying to reach www.192738172 whatever ip address. That definitely won't work. Try http://192.168.1.100 or whatever your ip address is.
                Also, please try using the terminal to ping the ip address to see if your computer can even reach it on the network at all.
                  @Phaedrux Thanks for your patience. IP was entered correctly. How do I ping from the terminal? Is there a code? I sent M122 and the Ip address was the same
                    In the mac terminal, type ping 192.168.1.100 with your duet ip and press enter. Press control-C to stop it.
                      @Phaedrux all i get back is "bad command: ping 192.168.x.x
                      ok"
                        Phaedrux Moderator @Dillon Brown
                        @Dillon-Brown said in Help!! Didn’t find access point while trying to connect:
                        Did you mean M552 S1?
                        Are you trying to have the Duet create an access point that you connect to, or are you trying to connect the Duet to your existing wifi?
                        Where are you sending that command?
                        Do you have a mac or windows PC? That ping command needs to be sent from either the mac terminal program or the windows command prompt.
                        Dillon Brownundefined 3 Replies Last reply Reply Quote 0
                          @Phaedrux I use the app serial tools for Mac. I am able to get the solid blue led from the duet board to come on and serial tools command line responds that wifi module is providing access point "my network", and the correct IP address. Wifi is idle.
                          I just ran the ping command from the terminal app and it responded with (my ip address): 56 data bytes
                          and then request timeouts until i hit control c
                            After typing in http://192.168.x.x/
                            I have disabled firewall and proxies
                              @Phaedrux in terminal i got these statistics after the ping command:
                              38 packets transmitted, 0 packets received, 100.0% packet loss
                              not sure what that means
                                It means it's not reachable from your computer.
                                @Phaedrux said in Help!! Didn’t find access point while trying to connect:
                                This is a very important question. It's the difference between your Duet creating a wifi network that you connect your computer to and the Duet connecting to your home wifi network.
                                  @Phaedrux ahh Bummer. Yea i just ran M552 S1 and still get the dreaded M552 S1
                                    Can you end M587 by itself and report back with what it says?
                                      @Phaedrux
                                      M587: Failed to retrieve network list
                                      ok
                                      Error retrieving Wifi status message: bad reply format version
                                      Wifi module is idle
                                      wifi reported error: no known networks found
                                        Can you send M122 and copy and paste the full reply here?
                                          @Phaedrux trying to, but marked as spam
                                            Give it a minute and try again.
