    Help!! Didn’t find access point while trying to connect
    Using Duet Controllers
    988
    • Dillon Brownundefined
      Dillon Brown @Phaedrux
      This is the error i get in the browser after typing in my IP address.
      I have a sprectrum router that automatically switches between 2.4 and 5ghz. I was able to get a spectrum agent to direct towards 2.4ghz for long enough for my printer to get connected to the wifi and stay connected.
      After typing in M552 S2 i get the message:
      Wifi is providing access point "my network", IP address "my IP"
      I enter the exact same IP address into my browser but neither safari nor chrome will load the page.
      I have also tried http://duettest.local/ and http://myprinter.local/
        Your screenshot looks like it's trying to reach www.192738172 whatever ip address. That definitely won't work. Try http://192.168.1.100 or whatever your ip address is.
        Also, please try using the terminal to ping the ip address to see if your computer can even reach it on the network at all.
        Dillon Brownundefined 1 Reply Last reply Reply Quote 0
          @Phaedrux Thanks for your patience. IP was entered correctly. How do I ping from the terminal? Is there a code? I sent M122 and the Ip address was the same
            In the mac terminal, type ping 192.168.1.100 with your duet ip and press enter. Press control-C to stop it.
              @Phaedrux all i get back is "bad command: ping 192.168.x.x
              ok"
                Phaedrux Moderator @Dillon Brown
                @Dillon-Brown said in Help!! Didn’t find access point while trying to connect:
                Did you mean M552 S1?
                Are you trying to have the Duet create an access point that you connect to, or are you trying to connect the Duet to your existing wifi?
                Where are you sending that command?
                Do you have a mac or windows PC? That ping command needs to be sent from either the mac terminal program or the windows command prompt.
                Dillon Brownundefined 3 Replies Last reply Reply Quote 0
                  @Phaedrux I use the app serial tools for Mac. I am able to get the solid blue led from the duet board to come on and serial tools command line responds that wifi module is providing access point "my network", and the correct IP address. Wifi is idle.
                  I just ran the ping command from the terminal app and it responded with (my ip address): 56 data bytes
                  and then request timeouts until i hit control c
                    After typing in http://192.168.x.x/
                    I have disabled firewall and proxies
                      @Phaedrux in terminal i got these statistics after the ping command:
                      38 packets transmitted, 0 packets received, 100.0% packet loss
                      not sure what that means
                        It means it's not reachable from your computer.
                        @Phaedrux said in Help!! Didn’t find access point while trying to connect:
                        This is a very important question. It's the difference between your Duet creating a wifi network that you connect your computer to and the Duet connecting to your home wifi network.
                          @Phaedrux ahh Bummer. Yea i just ran M552 S1 and still get the dreaded M552 S1
                            Can you end M587 by itself and report back with what it says?
                              @Phaedrux
                              M587: Failed to retrieve network list
                              ok
                              Error retrieving Wifi status message: bad reply format version
                              Wifi module is idle
                              wifi reported error: no known networks found
                                Can you send M122 and copy and paste the full reply here?
                                  @Phaedrux trying to, but marked as spam
                                    Give it a minute and try again.
                                      @Phaedrux @Phaedrux sure:
                                      M122
                                      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                                      Board ID: 08DGM-956GU-DGMSN-6J1F0-3S06P-KBQMG
                                      Used output buffers: 1 of 24 (1 max)
                                      Static ram: 25712
                                      Dynamic ram: 93216 of which 0 recycled
                                      Exception stack ram used: 304
                                      Never used ram: 11840
                                      Tasks: NETWORK(ready,1244) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160)
                                      Owned mutexes:
                                        Dillon Brown @Dillon Brown
                                        @Dillon-Brown === Platform ===
                                        Last reset 04:02:15 ago, cause: power up
                                        Last software reset time unknown, reason: Heat task stuck, spinning module GCodes, available RAM 11484 bytes (slot 1)
                                        Software reset code 0x00a3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043380f BFAR 0xe000ed38 SP 0x200049ac Task 0x4e49414d
                                        Stack: 004486cf 0044a266 01001400 00000000 000004d9 00000000 00000000 3331bb4c 41880000 3e178897 3e1cd04f 3c0281fc 3e3a3325 3e638e29 3e924925 3885108c 397d66d2 c0a00000 00000000 60000010 0043db4f 00000062 0043b3bb
                                        Error status: 0
                                        Free file entries: 10
                                        MCU temperature: min 19.4, current 33.1, max 33.4
                                        Supply voltage: min 0.0, current 0.4, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
                                        Driver 0: ok, SG min/max not available
                                        Driver 1: ok, SG min/max not available
                                        Driver 2: ok, SG min/max not available
                                        Driver 3: ok, SG min/max not available
                                        Driver 4: ok, SG min/max not available
                                        Slowest loop: 200.62ms; fastest: 0.05ms
                                        Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                                        === DDARing ===
                                        Segments left: 0
                                        Movement lock held by null
                                        http is idle in state(s) 0
                                        telnet is idle in state(s) 0
                                        file is idle in state(s) 0
                                        serial is ready with "M122" in state(s) 0
                                        aux is assembling a command in state(s) 0
                                        daemon is idle in state(s) 0
                                        queue is idle in state(s) 0
                                        Code queue is empty.
                                        === Network ===
                                        Slowest loop: 8486.38ms; fastest: 0.00ms
                                        HTTP sessions: 0 of 8
                                        • WiFi -
                                          Network state is running
                                          WiFi module is idle
                                          Failed messages: pending 0, notready 0, noresp 1
                                          WiFi firmware version 1.23
                                          WiFi MAC address 84:0d:8e:b2:15:56
                                          WiFi Vcc 3.43, reset reason Hardware watchdog
                                          WiFi flash size 4194304, free heap 23624
                                          === Filament sensors ===
                                          Extruder 0 sensor: no filament
                                          ok
                                          Can you send M997 S1 in the usb terminal? That will force a reflash of the wifi module.
                                            @Phaedrux whats the usb terminal? Just the serial tools app ive been using to communicate?
