Orbiter 2.0 stepper motor turns a little, then buzzes.
Hi guys.
I got myself a headscratcher I can't really figure out.My problem is that when I try to extrude, I can extrude about 4mm, and then the motor starts buzzing, and stops extruding/turning. If I then try and retract, I can retract about 4mm and then then the buzzing starts again.
I have this setup
Board: Duet 3 MB6HC (MB6HC)
Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.4 (2022-10-20)The documentation for the Orbiter 2.0 states the following Gcodes needs to be set for Reprap firmware.
I put them last in the config.g file so I'm sure they will be set, in case I accidentally set something above that could overwrite.
The config.g file is also attached in case there is something relevant.config.g
M350 E16 I1
M92 E690
M203 E7200
M566 E300
M201 E10000
M906 E1200 I10
M572 D0 S0.02
M207 S1.5 F7200 Z0.2I have heated the nozzle to 200 and have pla on the spool. I can push some through by hand, when pushing in the lever.
The Orbiter 2.0 didn't come with a connector that was correct for the board, so I had to crimp one myself. I'm fairly certain the order of the wires is correct, because it does move the filament forward when i tell it to extrude, and backwards when I retract (until buzz-stop)
Anybody have an idea, or know what I should read up on?
@imonsei what is the motor model number? 1.2A (M906 E1200) seems high; my Orbiter 1.5 runs on 600mA from memory. Is the motor getting hot? Otherwise, it sounds like something is blocking it. Have you tried running it without filament?
@droftarts
You were correct. I took the motor out of the orbiter and tested. It turned happily when no extruder was attached.
Opened up the planetary gears and did an inspection. Everything looked well lubed and turned easily.
Put it together again, and now it spun as it is supposed to.
Thank youAbout the 1.2A - no, it doesn't get hot. It's in the documentation for the unit, so I hope they know what they are doing.
undefined imonsei marked this topic as a question
undefined imonsei has marked this topic as solved
@imonsei said in Orbiter 2.0 stepper motor turns a little, then buzzes.:
No they don't necessarily. I have a similar motor which is labelled 1.8A/phase, but in reality it works best at 0.8-0.9A
