RRF 3.5B2 Error: meta command: unknown variable
Hello all,
I run RRF 3.5B2 on Duet 3 in standalone mode.
I am puzzled by an unexpected "unknown variable error".
Here is an extract from "G103.g":
var uClean = false ... if {var.uClean} G90 G1 H2 Y{125+random(226)} X{var.xForth} U{var.uForth} else G90 G1 H2 Y{125+random(226)} X{var.xForth} if {var.uClean && var.xClean && {global.ioMotV!=null} && {global.ioMotW!=null}} G90 G1 H2 V{var.vDive} W{var.wDive} F{move.axes[4].speed} elif {var.xClean && {global.ioMotV!=null}} ...
And there the extract from the "eventlog.txt":
YYYY-MM-DD HH:MM:SS [warn] Error: in file macro line 7 column 16: meta command: unknown variable 'uClean'
However the "var.uClean" variable is being called (several times in the full "G103g" file) between its declaration line 1 and its call line 7 the error occurs line 7 nonetheless.
Has anybody an idea of the possible reason for this issue?
Thank you in advance for your help.
Regards,
@jp-douarvil-0
I've been having some weird variable issues too (since 3.4 tbh).Try this out and see what happens
var uClean = 0 set var.uClean = false
Did you verify the vars and expressions following 'uClean'? The error message blames 'uClean', but points at the following column.
@Exerqtor
Maybe a problem with type coercion? In line 1, 'uClean' might be set up as an int. To verify that, change line 1 tovar uClean = false
@jp-douarvil-0 please attach your G103.g file to a post in this thread. It might contain a non-printing character; if not then I will try out your file here.
PS - I suspect this is caused by the multiple file readers in RRF 3.5 and is related to https://forum.duet3d.com/topic/31812/3-5b2-macros-called-from-a-job-lose-parameters. I have added it to my list to investigate.
@Exerqtor I've been able to reproduce your example and fixed the underlying bug. Unforunately, I have been unable to reproduce the other two reports so far.
@chrishamm can you provide more details about the actual bug? What versions firmware version did it affect? Only 3.5B2?
I'm asking this because I'm facing something similar and I can't find a way to isolate the issue.
I have a g-file with 20 local vars. and I'm getting aunknown variable
To give you a better idea, here are (simplified) contents of the filevar convertedAstart=0 var convertedAEnd=0 var periodAStartHr=19 var periodAStartMin=0 var periodAEndHr=9 var periodAEndMin=0 set var.periodAStartHrToSec=var.periodAStartHr*3600 set var.periodAStartMinToSec=var.periodAStartMin*60 set var.convertedAstart=var.periodAStartHrToSec+var.periodAStartMinToSec set var.periodAEndHrToSec=var.periodAEndHr*3600 set var.periodAEndMinToSec=var.periodAEndMin*60 set var.convertedAEnd=var.periodAEndHrToSec+var.periodAEndMinToSec while true if (var.convertedAstart<=global.legacyEpochSeconds || global.legacyEpochSeconds<=var.convertedAEnd) ; Do stuff here
And here's the error that I receive:
Error: in GCode file line 45 column 26: meta command: unknown variable 'convertedAstart'
The file is called with
M98 P"<path-to-file>"
This error usually happens when I callM25
,M0
and thenM98 P"<path-to-file>"
to start printing again.ATM rebooting the device solves the issue, ie, after reboot
does not throw any error. -
@AndMaz The problem was that an invalid statement in a macro called by a job file caused the print to abort. The function aborting the print cleared all the variables from the scope of both file readers executing a macro file causing one file reader to output a bad error message.
@Exerqtor please can you confirm if this is fixed for you in 3.5.0-beta4 ?
@T3P3Tony I haven't been able to run beta4 because of the crashing issues i'm having with it for more than one print. But if I remeber correctly this specific issue was fixed.
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
undefined niocio01 referenced this topic
