How to get DWC to Display what line of Gcode it is on?
@Tinman
Based on @dc42's comments above about the problem possibly being related to the multiple motion systems have you tried- Removing M0 from the file (if a second motion system is getting ahead it may be stopping the job)
- If the above is true, it may also turn off the spindle when it reaches M5, so maybe remove as well
- Liberally sprinkle M400 in the code (say every 100 lines). Do this especially before your tool change.
Can't explain the lifting by 70mm unless that was part of another file that's activated by M0, Tnnn or a trigger
What's in "ManualToolChange.g" ?
@OwenD I previously mentioned that if I delete the last 90% of the file it sails through the trouble section without problem. I suspect it has to do with file length. It seems too simple but I have no other theories.
@Tinman the file length will affect how long to takes the second file reader to find the M0 at the end of the file, or run out of file if there isn't a M0 command.
@dc42 I do have an M0 at the end of the file. Compared to my 3D printer files these cnc files are quite small. Please look at the file I uploaded.
This post is deleted! -
@dc42 Please look at my file and tell me why it crashes the board the way it does? I need to be able to support other makers and users of our Milo cnc mill and this has really got me stuck.
undefined Phaedrux marked this topic as a question
@dc42 I uploaded the file as you requested. Still hoping you can look at it.
@Phaedrux I'm part of the Millennium Mills design team. I'd be happy to show you how our Milo CNC mill works and how this specific problem is affecting efficient toolpath generation. I think you're also in Canada so I could show you live if that works. I've been avoiding further macro generation because I don't want to recommend these methods to our users if this can't be fixed.
@Tinman this is on my list to look at. It slipped below my radar for a while because the thread title doesn't describe the problem, or indeed suggest that there is a problem.
@dc42 Indeed, it started as me trying to troubleshoot the problem myself and I wasn't able to rename it when I couldn't solve it. Please rename the thread if that's possible.
@dc42 I've been wanting to do a video for the group to show "how to" do a job with tool changes but I keep delaying because nobody wants to watch me freeze up my mill. It used to work fine. I have a nagging feeling that it has to do with the extra precision now that I do multi-sampled averaged probing to set the WCS. Perhaps the extra decimal places are confusing the machine.
@Tinman hopefully I can help getting to the cause of the issue. Please can you do 2 things for me:
- Provide you system configuration files & macros so I can try to recreate the issue
- If you don't want to share all the config files then please share the
ManualToolChange.g
as it is used in the.gc
files you uploaded.
- Try removing the
M0
from the end of the files you have uploaded and run them again. Let me know if you still get the same freezing issue
@AndyE3D Really appreciate your time on this. I have attached the manual toolchange file. My macros are admittedly not the prettiest code since they are a work in progress. We will develop final macros when the concepts are proven.
@AndyE3D That macro also calls a macro that determines the tool length:
@AndyE3D And before the job is run a macro is run to set the WCS to the centre top of the workpiece:
@AndyE3D So the order of macros is:
- Centre Workpiece.g is run so that the WCS knows where the top centre of the workpiece is.
- The Tall Axle Insert Whole Job.gc file is run and before milling starts and with each tool change it calls:
a)ManualToolChange.g which then calls
i)ToolZProbe.g
There are two sensors used.
1. a sexbolt sensor which is used to determine xyz probe length as well as tool length
2. an xyz probe mounted in the spindle for the duration of the Centre Workpiece.g processThere is also a global variable defined in config.g which is used to exchange z offset information between the Centre Workpiece.g macro and the ToolZProbe.g macro. You can see it in this file
@Tinman I've had a look through the files and nothing is immediately obvious that would cause the issue. Do you have any
triggers
, adaemon.g
, or any other code that may be running on the Duet/sending commands to the Duet?Also were you able to try the print file without the M0 command at the end?
Another thing I would like you to try is to add
M400
to the start of each of the macros. If it is an issue with the second file reader, this should cause them to resynchronise. -
@Tinman I have been able to reproduce similar symptons to what you have described using a much shorter gcode file. The only differences appear to be that this will cause the Duet to hang consistently at the same line in the file compared to the position changing, and the duet becomes unresponsive to gcode (except estop).
@AndyE3D Thanks for looking at everything. I did try with M0 removed and had the same trouble. I haven't used any triggers or daemon.g or anything fancy. I will try inserting an M400 in the macros.
In my most recent attempt at a multi toolchange file I removed the M0. Early in the job the z axis decided it wanted to dive at top speed into the workpiece. It was alarming.
As before when I take exactly the same job and break it up into individual jobs everything runs fine.
@AndyE3D OK, I think I found out the cause of the problem- at least I have a theory... In my macro I had the z probe macro and xy probe macro making three samples and then averaging them to come up with the final WCS figures. The averaged figures have more decimal places and this seems to mess with the ability of the board to process a longer multi-machining-process file. When I remove the averaging procedures from the probing macros everything seems to run fine.
