    First homing attempts failing.
    12.5k
      Please post the contents of your homing files.
      • sjason1377undefined
        sjason1377 Banned
        The information you requested. Switches were just replaced to these, from the makerbot v1.2 to eliminate all possible failure modes. these are normally closed with no resistor. com and nc connected to outside pins of endstop connectors. individually tested. x drive 10 max endstop. m119 reports x at max when i hold switch triggered. x not stopped when I release. y at min triggered. y not stop when not triggered. Z at min triggered and z not stopped when not triggered. Machine properties console concurs with these results.
        Operation speed:
        Action frequency
        Mechanical:
        Electrical:
        Insulation resistance:
        Contact resistance (initial value):
        Voltage withstanding
        Open contacts:
        Between chassis and contacts:
        Ground & terminal:
        Vibration (button type):
        Shock (button type)
        OF 0.49 N type:
        OF 0.98 N type:
        OF 1.96 N & 3.92 N type:
        Life
        Mechanical:
        Electrical:
        Ambient temperature:
        Humidity:
        Contact material:
        Weight:
        0.1 mm - 1 m/s (button type)
        600 operations per minute
        30 operations per minute
        100mΩ min. (tested at 500 VDC)
        15mΩ maximium
        AC 1000V 50/60 Hz 1 min
        AC 2000V 50/60 Hz 1 min
        10 - 55 Hz, 1.5mm double amplitude
        Under 98 m/s²
        Under 196 m/s²
        Under 294 m/s²
        10,000,000 operations min
        100,000 operations min
        -25°C to +80°C (without frost or condensation)
        Under 85% (about +5 ~ 35)
        AgNi alloy; AgCdO alloy (does not meet RoHS directive)
        6.2 g (button type)
        SPECIFICATIONS
        Household applicances:
        Business appliances:
        Machinery:
        Other:
        Microwave ovens, rice cookers, washing machines, warmers, watering
        troughs, humidiers, disinfecters
        Automats, gaming arcades, electronics, tools, duplicators, shredders
        Haulers, printers, textile machines
        Auto door drive organization, equipment latch-lock mechanisms
        APPLICATIONS
        MICRO SWITCHES
        48621 Warm Springs Blvd Fremont, CA 94539, USA
        Phone:
        Fax:
        www.temcoindustrial.com
        Specications may vary and are subject to change. For certied drawings and specications, please contact a TEMCo representative.
        (510) 490-2187
        (510) 490-1507
        1. High precision action seat.
        Action seat (OP) 14.7 +/1 0.4 mm, prev-travel (PT) max.
        is 1.2 mm (button type shown below as example).
        2. High shock resistance.
        3. High heat resistance.
        Max temperature: 105°C
        4. Many variations to suit your application.
        Current ratings range from 1A to 21 A (silver contact, Ag alloy
        contacts, and silver plated gold contats available).
        TERMINAL TYPE SPECIFICATIONS
        Under
        Terminal
        Terminal
        Dimensions
        Horizontal
        Terminal
        Terminal Type
        #4.8 Solder/Bolt Common Terminal
        4.8 Solder Terminal
        6.3 Bolt Terminal
        Screw Fix Terminal
        Solder Terminals
        Button
        Short Roller Lever
        Roller Lever
        Short Lever
        Lever
        Long Lever
        Curved Lever
        DRIVE TYPE SCHEMATICS
        Contact type
        NC
        NO
        COM
        Change
        NC
        COM
        Close
        NO
        COM
        Open
        15.9 mm
        27.8 mm
        10.3 mm
        Button type
        OP
        PT
        6. CCC Certiied, CE Marked, meets RoHS directive.
        5. Strong, durable shell.
        Plastic shell can bear 6 KGF.CM torque during installation.
        Varied wiring congurations (see Terminal Type Specs chart below).
        OF
        Dierent terminal connector choices available.
        Varied action pressure (OF) types.
        Bolt terminal card
        Electric-shock plastic safeguard socket
        #4.8 Bolt
        #4.8 3 Pole
        MICRO SWITCHES
        Phone:
        Fax:
        (510) 490-2187
        (510) 490-1507
        INSTALLATION HOLE DIMENSIONS (in mm)
        Button
        Drive Lever
        Terminal
        Contact
        Flat Spring
        Body
        STRUCTURAL DIAGRAM
        10.3 +/- 0.1
        22.2 +/- 0.1
        2-3.1 installation hole or M3 screw hole
        MICRO SWITCHES
        Phone:
        Fax:
        (510) 490-2187
        (510) 490-1507
        Now myconfig.g
        ; Configuration file for Duet Ethernet (firmware version 1.19.2)
        ; generated by RepRapFirmware Configuration Tool on Mon Oct 23 2017 18:51:17 GMT-0400 (Eastern Standard Time)
        M111 S0 ; Debugging off
        G21 ; Work in millimetres
        G90 ; Send absolute coordinates…
        M555 P1 ; Set firmware compatibility to look like RepRapFirmare
        M208 X295 Y295 Z207 S0 ; Set axis maxima
        M574 X2 Y1 Z1 E0:1 S1 ; Define active high microswitches
        M558 P5 X0 Y0 Z1 H5 F100 T2000 ; Set Z probe type to BLTOUCH, the axes for which it is used and the probe + travel speeds
        G31 P50 X50 Y10 Z.7 ; Set Z probe trigger value, offset and trigger height
        M557 X50:275 Y50:275 S20 ; Define mesh grid
        M557 R105
        ; tools
        M563 P0 D6:8:9 H1 F2
        G10 P0 S0 R0 X0 Y0
        M569 P10 S1 R0 T2 ; Drive 10 goes forawrds
        M569 P11 S0 R0 T2 ; Drive 11 goes reverse
        M569 P5 S0 R0 T2 ; Drive 5 goes reverse
        M569 P6 S1 R1 T2 ; Drive 6 goes forwards
        M569 P8 S1 R1 T2 ; Drive 8 goes forwards
        M569 P9 S1 R1 T2 ; Drive 9 goes forwards
        M584 X10 Y11 Z5 E6:8:9
        M350 X128 Y128 Z128 E128:128:128 I0 ; Configure microstepping without interpolation
        M92 X800 Y800 Z25600 E640:640:640 ; Set steps per mm
        M566 X1200 Y1200 Z18 E120:120:120 ; Set maximum instantaneous speed changes (mm/min)
        M203 X19000 Y19000 Z280 E1600:1600:1600 ; Set maximum speeds (mm/min)
        M201 X700 Y700 Z430 E350:350:350 ; Set accelerations (mm/s^2)
        M906 X0 Y0 Z0 E0:0:0 ; Set motor currents (mA)
        M84 S0 ; Disable motor idle current reduction
        M143 S260 ; Set maximum heater temperature to 260C
        M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
        M307 H7 A1 C1 D1
        M563 P0 D0:1:2 H1 ; Define tool 0
        M550 Pkathryn printer ; Set machine name
        M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
        M552 P192.168.2.9 S1 ; Enable network static address
        M586 P0 S1 ; Enable HTTP
        M586 P1 S0 ; Disable FTP
        M586 P2 S0 ; Disable Telnet
        M106 P0 S1 I0 F255 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P1 S1 I0 F255 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P2 S1 I F255 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M501 ; Load saved parameters from non-volatile memory
        ; homeall.g
        ; called to home all axes
        ; Relative positioning
        G91
        ; Lift Z
        G1 Z5 F1500
        ; Course home X and Y
        G1 X290 Y-290 F750 S1
        ; Move away from the endstops
        G1 X-10 Y-10 F1000
        ; Fine home X and Y
        G1 X290 Y-290 F250 S1
        ; Absolute positioning
        G90
        ; Go to first bed probe point and home Z
        G1 X50 Y50 F1500
        G30
        ; Uncomment the following line to lift the nozzle after probing
        G1 Z5 F100
        homex.g
        ; homex.g
        ; called to home the X axis
        G91
        G1 Z5 F1500
        G90
        G1 X290 F750 S1
        G91
        G1 X-5 F1000
        G90
        G1 X290 F250 S1
        G91
        G1 Z-5 F1000
        G90
        Homey.g
        ; homey.g
        ; called to home the Y axis
        ; Lift Z relative to current position
        G91
        G1 Z5 F3000
        G90
        ; Move quickly to Y axis endstop and stop there (first pass)
        G1 Y-290 F1000 S1
        ; Go back a few mm
        G91
        G1 Y5 F1000
        G90
        ; Move slowly to y axis endstop once more (second pass)
        G1 Y-290 F250 S1
        ; Lower Z again
        G91
        G1 Z-5 F1000
        G90
        Homez.g
        ; homez.g
        ; called to home the Z axis
        ; bed.g
        ; Clear any bed transform
        ;M561
        M401 ;deployprobe
        G29 S0 ;probebedmesh
        M402 ;retractprobe
        M374 ;save map to file.
        deployprobe.g
        M280 P7 S10
        M280 P7 S90
          Suggestions:
          1. You are using external drivers for X and Y, but you have M350 X128 Y128. You should set X and Y to 16 in that M350 command, even if you are actually using higher microstepping on your external drivers. I'm not sure that using X128 Y128 in M350 will cause a problem, but it might. Leave your M92 steps/mm at 800 if that is correct for the microstep setting on your drivers.
          2. What types of external drivers are you using for X and Y? You may need to extend the pulse width to more than 2us. Try T4 in your M569 P10 and M569 P11 commands until everything is working.
          3. I suggest you test basic motion first. Send G91 to put the printer into relative coordinate mode. Then send these commands and check that the movement is as expected:
          G1 S2 X50 F3000 ; should move the head 50mm in the +X direction
          G1 S2 X-50 F3000 ; should move the head 50mm in the -X direction
          G1 S2 Y50 F3000 ; should move the head 50mm in the +Y direction
          G1 S2 Y-50 F3000 ; should move the head 50mm in the -Y direction
          HTH David
            sjason1377 Banned
            As I stated before, I am requesting answers in the most efficient manner to correct my issues. This benefits both of us. I have 2 years backround in cnc millturn 5 axis setup and control. I already calibrated the machine, once movement happened, by placing it on my mill and following the mills with a feed sensitive probe in spindle. The board produces exact move as advertised. The issue with 128 micro in M350 command much be that way. Otherwise I get 1/8 the travel distance. I know my setup well. this is the 3rd printer board I've tried. Smoothieboard lacked the drive flexibility. Arduino, well you no there limits. I like the Gcode on the fly. Printer worked with 3 other boards. The drivers are kl 5056d they come with software and serial port comm to pc for tuning and calibration. Nothing on my side is causing any of this action. My question is this. Regardless if i am right or wrong, asking someone to look at the files and confirm or direct me is actually a separate request than Diagnosing the total build. I just want to know that my config.g and homing files are in correct. I can play tag for weeks over hardware and calibration, but if it's in the files causing the issue, how many times am I going to check what I know already works. Please understand I total get the switches electrically, mechanically and the moves are spot on. It stops sometimes. Homes 1 axis correct, than doesn't other times. but never all 3 completely as a homeall.g or 1 after the next. I'm not even going to test probing until it's reliable first. To answer the request, I get 6.24903 reading from uccnc off the mill, and 6.25 on duet. again sensor to sensor spindle to nozzle test.
            If I could just receive conformation that I have properly configured those homing files and that config.g is in order as it relates to homing of axis plains I would be very grateful. If I need to correct them I will receive any advice with much thanks!
              deckingman
              @sjason1377:
              If I could just receive conformation that I have properly configured those homing files..........................
              No, you haven't. There is an inconsistency between the homing of Y in homeall.g and the homey.g file (clue - the homeall.g looks wrong). Also, if it were me, I'd home Z at the centre of the bed rather than 50mm from a corner but you seem to have far more experience than me so I'll not argue.
                sjason1377 Banned
                Ok I tested machine with on board drivers and it homed. This board doesn't work with x y z on external drivers like advertised
                  The Duet does work with external drivers for XYZ. However, the drive voltage available on the CONN_LCD connector is 3.3V, and your external drivers may require 5V.
                    sjason1377 Banned
                    what does that have to do with machine not stopping for the endstop switches? this post is about homing not drivers. It want home and you still haven't commented on the files I up loaded. I hit the home x button and slam. Hit home y and slam. S1 is is write in the file. I see the led go out everytime for the axes homing, but slam and stripping the belt. Please just tell me why that is?
                      T3P3Tony administrators
                      G1 X-10 Y-10 F1000
                      ; Fine home X and Y
                      This is wrong if your Y endstop is a minimum one then you are moving negative 290, then trying to move negative 10 it should be +10. As deckingman pointed out this is different in homeall.g from homey.g so you will get a different result depending on how you call homing.
                      Also you have a very different homeZ from homeall.g I would get the individual axes working homing by them selves, then copy those elements into the homeall.g
                        @sjason1377:
                        I have already commented on your files: i pointed out that using M350 to set microstepping on external drivers might be problematic. Ian and Tony have pointed out issues with your homing files.
                        Another issue I can see with your config.g file is that the maximum speed you have configured in the M203 command is much too high to be achievable, especially in view of your high steps/mm. But that shouldn't affect homing because the commanded speeds are much lower.
                        Please provide a link to the datasheet for the external drivers you are using, and tell us how you have connected them to the Duet.
                          sjason1377 Banned
                          wont home x not even attempting to move. instant error on screen with on board drivers. Lets forget external drivers, there are all off. Just the board and steppers now. I can jog and thats it. Used configurator to produce new homing files and tried to home. instant failure message. now m122 reports stand still stalled on x and z. this is as standard of a setup as it get. this board just doesn't work.
                            sjason1377 Banned
                            no external drivers. now its just duet! Failure to home still persist. IF type G1 S2 X100 F3000 machine says busy then nothing. Then 30 sec. later the distance reflects a move that didn't happen. Another 30 seconds and then it takes off and slams an endstop. Not even the axis I commanded. last time i tried, z went up then stopped and x went then stopped. the distance didn't change that time. that was a single linear request. This things just no good. Gonna need the warranty honored here.
                              sjason1377 Banned
                              You wanna know why real cnc companys don't have forum and support groups? Because they don't have 1000s of confused unhappy costumers. If there is an issue the fix it. But it's rare they fail. Look for a Haas machine forum, or a Hurco support group. They don't exist. Because they don't need em. want my money back
                              • lignumaquaundefined
                                lignumaqua
                                I think the many users of the Duet who have had complete success, are very happy with their purchase, and who enjoy the assistance given on this forum would disagree with you.
                                It seems clear from your posts that English is not your first language, so you may have misunderstood some of the Wiki instructions. For the same reason you may also not realize how rude your posts appear to an English speaker. David, Tony, and the other frequent posters here are the most helpful I’ve found on just about any forum. If you would work with them rather than arguing I’m sure you would get things worked out. 🙂
                                  @sjason1377:
                                  What was the failure message: "Homing failed", or something else?
                                  The motor stall indication is not reliable at low speeds, so the "stalled" indication doesn't matter.
                                  Please share the new config.g and homing files that you are now using.
                                    sjason1377 Banned
                                    theres nothing but m105 info now. no esponce from the board at all. not usb or ethernet. sd card is good board is not. Like I said its defective hardware. Filastruder is putting the warranty claim issue on U. They except returns for 30 days. They are not going to honor a return due to warranty. The failures reacted every level of function the board has. There is now way Someone could install these thing T cause every function to behave wrong and than stop responding.
                                      sjason1377 Banned
                                      Ok I got it to move again. Had to reset, erase and reload firmware. Now I'm at a fresh start with all online config tool files. Machine jogs all 3 axis turns, axt power on/off heat on off, but when I try to home a single axis it moves 20mm or so the direction the file says, then back a few stops and reports error g28 yhoming failed. It does this on x,y,z. It's as if it's looking to come off a switch to reset it like my mill will do if the switch is hung up. But the switches checkout. I tried every position active high/ low both ends and a combination of them all. same problem. My homing files request -300 of travel to the switch, but it stops around 10 to 20mm every time. it's just not going far enough. When it does it won't stop "half" the time. I am using all on-board equipment at this point. The switches are just plain n/c contact with rolled lever. "raw switches" wired to the gnd and signal for the endstop connectors. Nothing one the 3.3v supply pin. M122 calls report good data for these switches and I see leds on according to the instructions for when not stopped using n/c and off when stopped. here is the homing file for "Y" I will send just 1 because I want to master 1 at a time.
                                      ; homey.g
                                      ; generated by RepRapFirmware Configuration Tool on Sat Nov 25 2017 12:15:39 GMT-0500 (Eastern Standard Time)
                                      G91
                                      G1 Z5 F6000
                                      G90
                                      G1 Y-300 F1800 S1
                                      ; Go back a few mm
                                      G91
                                      G1 Y5 F6000
                                      G90
                                      ; Move slowly to X axis endstop once more (second pass)
                                      G1 Y-300 F360 S1
                                      ; Lower Z again
                                      G91
                                      G1 Z-5 F6000
                                      G90
                                        I'm sorry to hear that you are still having problems getting homing to work.
                                        You homing files look OK and your earlier config file looked OK too apart from the issues that I and other mentioned. So I am wondering whether your endstop wires are picking up inductive interference from the stepper motor cables, giving rise to false triggering. This is not common because the endstop circuitry on the Duet includes filtering circuitry, but it can still happen if the stepper motor wires and endstop wires run close to each other for a substantial distance, and you are not using twisted pair wiring for either the endstop wires or the stepper motor wires. Is your wiring like this?
                                        If so, then to test whether this is the cause, I suggest that you make up a new temporary cable for one of the endstop switches, keeping it completely separate from the motor cable, and use it in place of the existing cable. Or, temporarily connect a spare microswitch or push button to the endstop switch connector instead of the cable to the endstop switch, and see if you can stop the homing move by pressing that switch.
                                        If that fixes it, then you can still have the endstop switch wires running alongside the stepper motor cables if that is what you need to do, but you should use twisted pair for the endstop switch wires. Twisted pair is resistant to inductive interference pickup.
                                        Also, please confirm that you have two wires running from each endstop switch direct to the outer two pins of the corresponding endstop connector, and you are not using a common ground wire or anything like that.
                                        HTH David
                                          sjason1377 Banned
                                          This is what I used. 1 pair endstops. 3 pair version for stepper drives, when I had them external. 5 pair for a 4 channel relay optccoupler interfaced no longer connected. I assume any triggering of the switch sense curcuit would at least be seen or recorded, would it not? I think the larger issue is it doesn't move. I mean it very slowly lurches toward the switch, hesitates then back up a bit, stops and post an error. It's actually moving and behaving like it's scared to perform. I know it sound crazy, but something before it even tries to move isn't right. It's starting the g28 command on the wrong foot somehow. It also does it from Repitier host over usb, which I only connect to test and remove.
                                          18AWG Instrumentation Cable - Overall Shield
                                          Part Number
                                          Number
                                          of Pairs
                                          AWG
                                          18AWG Instrumentation Cable - Overall Shield Specifications
                                          Conductor Gauge & Stranding
                                          18AWG Class B 7 stranded bare copper per
                                          ASTM B-3 and B-8
                                          Print Legend*
                                          CCI ROYAL 18 AWG XX SHIELDED PAIRS PVC/PVC TYPE
                                          PLTC/ITC E176494 (UL) 105C SUN RES FT4/IEEE 1202
                                          –- SEQUENTIAL MARKING
                                          Voltage Rating
                                          300V
                                          Flame Rating
                                          Passes FT4/EEE 1202 Flame Test
                                          Passes IEEE 383 Flame Test (70,000btu)
                                          Jacket Material
                                          Sunlight resistant black PVC (polyvinyl
                                          chloride)
                                          Applicable Standards
                                          UL Standard 13 Type PLTC
                                          UL Standard 2250 Type ITC
                                          EPA 40 CFR, Part 26, Subpart C, heavy metals per Table 1,
                                          TCLP method
                                          NEC Article 725 (Type PLTC)
                                          NEC Article 727 (Type ITC)
                                          Hazardous Locations:
                                          NEC Article 504 (Intrinsically Safe Systems)
                                          Conductor Insulation
                                          PVC
                                          Pair Lay Length
                                          1.25 twists per inch
                                          Resistance
                                          6.60
                                          Ω
                                          /1000’ @ 20°C per conductor
                                          Conductor Markings
                                          Black / White; Alpha-numeric print;
                                          alternate & inverted @ 2.5 inch intervals
                                          Temperature Rating
                                          -30°C to 105°C (-22°F to 221°F)
                                          Shield and Drain Wire
                                          Overall aluminum polyester foil shield with
                                          a tinned copper drain wire
                                          Communication Wire**
                                          22AWG PVC (orange)
                                          Min. Bend Radius
                                          10x diameter
                                          Overall Shield
                                            sjason1377 Banned
                                            Endstop connections. Raw switch side N/C to pin 1 to J33 connector = x
                                            to J32 connector = y
                                            to J19 connector = z
                                            Raw switch side com. to pin 3 to J33 connector =x
                                            to J32 connector =y
                                            to J19 connector =z
