    [DOC] brew cask` is no longer a `brew` command...
    Documentation
    • danielkrahundefined
      danielkrah
      Hi the documentation on: https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware
      is outdated
      Error: `brew cask` is no longer a `brew` command. Use `brew <command> --cask` instead.
      so you have to use:
      brew install --cask gcc-arm-embedded
      instead.
      Same for the rest
      Greetings
      Daniel
      chrishammundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        @droftarts
          droftarts administrators @Phaedrux
          @Phaedrux I think @dc42 maintains those pages.
          • chrishammundefined
            chrishamm administrators @danielkrah
            @danielkrah @droftarts Thanks, now updated.
            Duet software engineer
              droftarts administrators @danielkrah
              @danielkrah I’ve run through installing Eclipse and getting the firmware to compile on an M2 MacBook Pro on Ventura, and updated the instructions further. I had problems getting Eclipse to recognise CrcAppender; Eclipse doesn’t use the system $PATH by default, and I couldn’t seem to add the path to it in Eclipse. I had to run Eclipse from the terminal for it to use the system path. Can you take a look and comment on your experience?
              • droftartsundefined droftarts marked this topic as a question
              • droftartsundefined droftarts has marked this topic as solved
