    Duet2 WiFi generating polygons instead of circles
    Laser Cutters
    1.6k
    • flopesundefined
      flopes @flopes
      Any help on the matter would be greatly appreciated
        T3P3Tony administrators @flopes
        @flopes one option to try would be to setup the config as if the printer was 10* bigger, then set the microstepping to 64 instead of 8, and the steps/mm to an appropriately adjusted value. The idea being that the limit of 0.1mm segments would then be 0.01mm in reality due to the 10x scaling.
        flopesundefined 1 Reply Last reply Reply Quote 0
        • flopesundefined
          flopes @T3P3Tony
          @T3P3Tony
          Scaling 10:1 is how I have been operating. Do you know what is the minimum positioning resolution of the Duet2?
          I know It responds to G21G91G1X0.001 with 1 micron displacement, but would the motion control allow for such fine positioning? Could I laser drill a grid 5micron by 5micron?
          My tests show about 25micron uncertainty on the position of a cut, but once the cut starts, it can be very precise (5micron?)
            @flopes you are limited by the step resolution. If you have been operating at a 10:1 scaling then switch to a 100:1 as a work around for now.
            flopesundefined 2 Replies Last reply Reply Quote 0
            • flopesundefined
              flopes @T3P3Tony
              @T3P3Tony Thanks. I will run a test
              • flopesundefined
                flopes @T3P3Tony
                @T3P3Tony
                It seems to work fine. Polygons are gone at 100X. Error in mispositioning improved as well. May be good enough. Please advise when you will increase board resolution
                Thanks
                Fernando
                • flopesundefined flopes has marked this topic as solved
                  @flopes thanks for the update. I don't have a timescale for changing the arc segmentation resolution right now, possibly it needs to be configurable as while you are controlling motion in the micrometer range, there are other uses working in the meter range!
                  • flopesundefined
                    flopes @dc42
                    Hi
                    Can you instruct me to increase the resolution so it does smaller radiuses? I need 30x more resolution than standard, or 3 micron radius. My machine is super slow, with a small pritable area of 100x100mm, so I am not concerned about the other end of the spectrum. Thanks
                      dc42 administrators @flopes
                      @flopes please can you clarify what are your actual X and Y steps/mm, before you do the x10 or x100 conversion?
                      BTW the reason for the late response is that this thread was marked as "solved" so I was ignoring it. Posting to a thread marked as solved is not a good idea . You should either marked the thread as "unsolved" again (which you can do if you are the thread author) or start a new thread.
                      • dc42undefined dc42 has marked this topic as unsolved
                      • flopesundefined flopes marked this topic as a regular topic
                      • flopesundefined
                        flopes @dc42
                        @dc42 Done. Any tips on where I should start?
                        droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
                          droftarts administrators @flopes
                          @flopes said in Duet2 WiFi generating polygons instead of circles:
                          Not sure what you mean. @dc42 asked you to clarify what are your actual X and Y steps/mm, before you do the x10 or x100 conversion. Maybe post your current config.g and firmware version. As far as I'm aware there has been no change in the arc segmentation resolution in the latest firmware versions.
                            @flopes I've reduced the minimum arc segment length from 0.1 to 0.02mm in 3.5.0-beta.4. Perhaps that will go some way to resolving this for you? I'm still waiting to know what steps/mm you are using.
                            • flopesundefined
                              flopes @droftarts
                              @droftarts Thank you very much for your reply.
                              I am using today (with my 30x version, meaning to cut 1mm, I send a 30mm long cut command)
                              ; generated by RepRapFirmware Configuration Tool v3.3.16 on Wed Jun 14 2023 09:27:16 GMT-0700 (Pacific Daylight Time)
                              M550 P"Laser Cutter" ; set printer name
                              M552 S1 ; enable network
                              M586 P0 S1 ; enable HTTP
                              M586 P1 S0 ; disable FTP
                              M586 P2 S0 ; disable Telnet
                              M350 X8 Y8 Z8 E8 I0 ; configure microstepping without interpolation
                              M92 X53.33 Y53.33 Z53.33 E1.00 ; set steps per mm
                              M566 X660.00 Y660.00 Z660.00 E6.00 ; set maximum instantaneous speed changes (mm/min)
                              M203 X19800.00 Y19800.00 Z19800.00 E6.00 ; set maximum speeds (mm/min)
                              M201 X300.00 Y300.00 Z300.00 E1.00 ; set accelerations (mm/s^2)
                              M906 X1000 Y1000 Z1000 E300 I30 ; set motor currents (mA) and motor idle factor in per cent
                              M84 S1 ; Set idle timeout
                              M208 X0 Y0 Z-600 S1 ; set axis minima
                              M208 X3300 Y3300 Z2265.6 S0 ; set axis maxima
                              M574 X2 S1 P"!^xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !^xstop
                              M574 Y1 S1 P"!^ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !^ystop
                              M574 Z2 S1 P"!^zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin !^zstop
                              M558 P0 H0 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                              M557 X5:100 Y5:100 S5 ; define mesh grid
                              M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                              M563 P0 S"Z Pogo" D0 H1 F0 ; define tool 0
                              G10 P0 X5 Y5 Z5 ; set tool 0 axis offsets
                              M563 P1 S"Laser" F0 ; define tool 1
                              ; Custom settings
                              ;(30x)
                              • flopesundefined
                                flopes @droftarts
                                @droftarts Board: Duet 2 WiFi (2WiFi)
                                Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.4 (2022-10-20)
                                Duet WiFi Server Version: 1.27
                                • flopesundefined
                                  flopes @flopes
                                  @flopes
                                  short answer = 1600steps/mm
                                  • flopesundefined
                                    flopes @dc42
                                    @dc42 Thank you. I will give that a try. that is 5x improvement.
                                      @flopes I hope it helps. I had to guess what resolution to use because when we had to freeze the beta 4 code, I did not know what steps/mm you were using and hence what resolution would be appropriate.
                                      In the future we may adjust the resolution according to the configured steps/mm for the axes concerned.
                                      • flopesundefined
                                        flopes @dc42
                                        @dc42 Hello. The Beta 3.5.0 with segments of 0.02 is sufficient for my aplication at the moment.
                                        We build this custom laser printer cut brain implants and the programs are quite long - 10's of thousands arcs connected together. Usually takes 3 days to cut one batch. During these last 6 motnhs we come up with a series of methods to minimize the offset in position from the first features cut to the last ones. We figured out there is no more mechanical possibilities for this offset to be happening. We even added temperature control on the whole printer.
                                        I believe there may be some rounding going on in the system. We also notice this offset is larger on y axis.0002.png
                                        Do you believe we could benefit from adding encoders to the Nema17 stepper motors?
                                        by the way we use 1600steps/mm
                                        Thanks
                                        • droftartsundefined droftarts referenced this topic
