    New beta firmware release 1.20beta10
    Firmware installation
    18
    59
    7.6k
    • whosrdaddyundefined
      whosrdaddy
      @zlowred:
      WiFi stopped working for me with DuetWiFiServer-1.20beta10
      M552 S1 says:
      Failed to initialise WiFi module, code -10
      Reverting to DuetWiFiServer-1.20beta9 fixes the problem
      I did the M997 S1 twice, and I tried installing Beta10 again after reverting to Beta9 with the same result.
      Debug mode says:
      Debugging enabled for modules: WiFi(14)
      Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13)
      WiFi:
      WiFi:  ets Jan  8 2013,rst cause:2, boot mode:(3,6)
      WiFi:
      WiFi: load 0x4010f000, len 1384, room 16
      WiFi: tail 8
      WiFi: chksum 0x2d
      WiFi: csum 0x2d
      WiFi: v60000100
      WiFi: ~ld
      WiFi module started
      Error: Failed to initialise WiFi module, code -10
      The last line appears after ~30 seconds delay
      Same problem here!
      • DjDemonDundefined
        DjDemonD
        Same for me as zlowered failed to intialise wifi module -code 10 did it via the sd card m997 method. twice.
        Restored to wifiserver 1.20beta9 but it had to do so at 230xxx baud rate after failing at 4xxxxx baud rate.
        www.precisionpiezo.co.uk
        • str8upundefined
          str8up
          Same here as well. Back to wifiserver 1.20beta9.
          • DjDemonDundefined
            DjDemonD
            On the upside, FW 1.20beta10 is working, printing stuff right now.
              I'm sorry, somehow the wrong file got copied to DuetWiFiServer-1.20beta10.bin on github. I have corrected it now.
              • peirofundefined
                peirof
                reflot
                [[language]]
                Added Z probe types 7 (switch connected to Z endstop) and 8 (as type 5 without any filtering, for faster response)
                Bltouch or Míni Differential Ir Sensor, are affected?
                  whosrdaddy
                  Wifi beta 10 is working now!
                    @peirof:
                    reflot
                    [[language]]
                    IR sensor: not affected if you use it in analogue mode as recommended for the Duet. But you could use it in digital mode with the probe type set to 8 if you wish.
                    BLTouch: if you currently have the probe type set to 5, you could try 8. It might give you slightly more reproducible results.
                    Here is what the new mode is about. The ADC on the Duets reads every enabled input channel once every millisecond and feeds the values into averaging filters. When you use a digital output Z probe, the ADC is not used but the Z probe is still sampled every millisecond and fed into an averaging filter. This can be useful for debouncing and rejecting glitches. However, it means that there is a variable delay of up to 1ms before the Z probe signal is recognised. If you are probing at 1000mm/minute (as we suggest with the Smart Effector), then the head will move 16.7um in 1ms. So the 1ms sampling introduces an uncertainty in the trigger point of +/- 8.3um. This uncertainty is avoided when you use mode 8. At lower probing speeds, the uncertainty is lower.
                    • DjDemonDundefined
                      DjDemonD
                      What debounce value would you suggest in G31 for smart effector? Or does this not apply when using p8?
                        Debounce doesn't apply when using P8. Any value between 1 and 1000 should give the same result.
                        • frafaundefined
                          frafa
                          Hi David
                          On Scara I have a strange problem with
                          DuetWiFiFirmware-1.20beta10.bin
                          I have shifts of layers in x / y it does not get well
                          unusable ….downgrade
                          DuetWiFiFirmware-1.20beta8+1.bin
                          DuetWiFiServer-1.20b8.bin
                          result ok ...
                          sorry brooken English ...
                          photo before/after (same file)
                          Scara with DuetWifi => Scarlette3D
                          https://youtu.be/mBF5cO8vGhI
                          • Forgvn77undefined
                            Forgvn77
                            I also have experienced layer "skewing" with 1.20beta10. Printed a gear bearing from Thingiverse and it came out slanted, but more on one side. Strange effect.
                            Velleman K8200, Geeetech G2S Pro (x2), Geeetech Rostock 301 retrofitted with Duet
                            Make A Difference!
                            • frafaundefined
                              frafa
                              yes it's strange about simple shapes square/circles it works
                              while on complex shapes it does not work anymore …
                              • DjDemonDundefined
                                DjDemonD
                                Hmm it seems something odd is going on. Last night I set a tray of parts printing and this morning there was a completed tray but with a nasty layer shift (never seen this happen on this printer before). Assuming it was because I was messing about with probing and might have lowered my motor currents and did not put them back, I started the print again today, same issue despite running all motors at 1.2A/1.68A.
                                I will try again but on a different firmware version, I need to get these parts printed.
                                M122 if it helps: https://1drv.ms/t/s!Apv79JfGbPIwg4QskvIqENNjz_mSWA
                                • Jason Kundefined
                                  Jason K
                                  I had the same issue with the skew.
                                  MaxReps: 130, StepErrors: 123, FreeDm: 240, MinFreeDm 120, MaxWait: 2228747316ms, Underruns: 0, 0
                                  Scheduled moves: 2721, completed moves: 2721
                                  Bed compensation in use: mesh
                                  seems like there are a lot of step errors for 3 layers
                                  • franzelkaundefined
                                    franzelka
                                    Something is definitely odd with this firmware release.
                                    First image 1.20beta10, totally messed up. Second one 1.20beta8, all going well until now!
                                    • DjDemonDundefined
                                      DjDemonD
                                      Mine wasn't as dramatic just a nasty layer shift towards -y (on a delta)
                                      But those were 2 of 16 parts on the build plate, and then I reproduced the same error on the next 16, but cancelled the print as soon as it happened.
                                      Interestingly I'm running the same FW on my corexy no issues so far, is this a delta problem?
                                        Please can those of you who have experienced a layer shift using the latest release do the following:
                                        1. State what machine architecture you are using (Cartesian, Delta etc.)
                                        2. If you have a model that reproduces the issue easily, post a link to it
                                        3. If possible, with 1.20beta10 loaded, connect a PC via USB, and send M111 S1 P4. Then print the model. Each time a step error is recorded, debugging info will be reported via USB. Post 50 or so lines of that debug info in this thread.
                                          franzelka
                                          1. Delta (Kossel Mini T3DP3D)
                                          2. https://www.thingiverse.com/thing:2323213/#files -> Apple-Watch-Phone-Stand_V7.0.stl
                                          3. there are no lost steps. No debugging output from USB logging and M122 didn't show any problems
                                          It seems that after finishing the two solid layers every new layer gets skewed. With 1.20beta8 I could finish the print without any problems.
                                            Thanks, I'll try printing that on my delta. Please share your config.g file.
