    H1 command for an endstop switch (microswitch)
    Using Duet Controllers
    509
      jay_s_uk @axiom
      @axiom so you mean probes and not endstops. That's different, you can have more than one. Just make sure you use the correct K value when using G30 and you'll be fine
        dc42 administrators @axiom
        @axiom it sounds to me that your "endstops" are actually configured as Z probes. You can indeed have more than one Z probe.
        The usual way of homing using a Z probe is to use the G30 command, and you can provide a K parameter with this command to tell it which Z probe to use.
        If the microswitch triggers when the nozzle if 15mm higher than the bed then you should set the G31 Z parameter for that probe to 15. For historical reasons the Z parameter isn't the offset, it's the trigger height (the negative of the offset). Again, use the K parameter of the G31 command to specify which probe that command refers to.
        axiomundefined 1 Reply Last reply Reply Quote 0
        • axiomundefined
          axiom @dc42
          @dc42 I have now made the following entry in cofig.g:
          ; Z-Probe two of them
          M558 K0 P1 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
          M558 K1 P8 A2 S0.2 C"zstop" H5 F80 T3000
          G31 P1000 K0 X-1 Y-61 Z2.3 ; set Z probe trigger value, offset and trigger height
          G31 P1000 K1 X0 Y0 Z15 ; Second Z offset
          M557 X0:740 Y-27:602 S35 ; define mesh grid
          When I first go to z=50 (G1 z50= and enter G30 K1 via the console, I get the message: "Error: Probe already triggered at start of probing move"
            @axiom are you using the normally-open or normally-closed microswitch contacts?
            Your DWC screen shot indicates that Z probe K1 is registered as triggered (the value is 1000). Was that correct?
            • axiomundefined
              axiom @dc42
              @dc42 I don't quite understand that...how do I recognize that?...if I bring the contacts of the microswitch (puck) together (bring them into contact...i.e. nozzle and puck) the display for the probe goes to zero.. .that's actually correct, isn't it?
                P1000 means triggered
                P0 means not triggered
                • axiomundefined
                  axiom @Phaedrux
                  @Phaedrux got it... just had to say "!" put in front of the name of the connection. G30 K1 works. But I would like to read the value and set this value minus the 15mm (height of the puck) as Z=0.
                    Phaedrux Moderator @axiom
                    @axiom said in H1 command for an endstop switch (microswitch):
                    I don't understand what you mean exactly.
                    axiomundefined 2 Replies Last reply Reply Quote 0
                    • axiomundefined
                      axiom @Phaedrux
                      @Phaedrux I would like to use it to automatically measure the z-offset...so I no longer have to put paper underneath it
                      • axiomundefined
                        axiom @Phaedrux
                        @Phaedrux so I need to be able to set the trigger value as z=0.
                          What is the puck you mention? Can you show a photo of your setup?
                          • axiomundefined
                            axiom @Phaedrux
                            The part with the blue cap is the capacitive sensor, the part on the glass plate on the heatbed is the "puck/microswitch". Contact with the printhead triggers it...that works
