SecKit Cube wiring with unconvntional port usage
It seems I may have bought the wrong board for my printer.
I have a SecKit Cube and went through the IO of the boards and then bought a mini 5+ but think I may have went a bit too small, but this is how I planned:The X and Y are MKS 42C closed loop stepper and have the following ports:
V+
GND
COM
Engage
Stp
Dirso the mapping for them should be?
Not much space left and not sure it is correct (have not crimped the wires yet), so I would be very thankful if there is an error I should /can fix before doing the wires.
@budhi you'd have to use 1XD boards connected over CAN-FD to drive external drivers
https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Expansion_1XD -
@budhi ignore me as it looks like you can use the 2 driver expansion header in which case it looks like you're right
So I have crimped some adapter to test the wiring and finally do this (life got in the way...)
this is to run MKS S42C closed loop steppers from the external driver pins (if the pins are correct a proper wire will be made)
Am I correct in just selecting Driver_5 and Driver_6 to connect?
I will try at the time the post is up but am happy for any input.
They started up and moved on command, so now to make a final wire harness
and just so people don't think the jumper wires would stay here is the wiring done
(for the stepper, the rest is next)
@budhi glad to hear it worked ok!
