    NodeDSF : Interface nodes for Node-Red (V1.1.11 - 06-10-23).
    Third-party software
    5.8k
    • MintyTreborundefined
      MintyTrebor @tekstyle
      @tekstyle Using the same example as before:
      The DSF Event node sends the value of the event to msg.dsf.eventValue
      Look at the help for the DSF Event node and its fully described:
      NodeDSF - Native Node-Red integration with Duet boards.
      BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
      ReleaseMgr - Duet update info inside DWC.
      Repo
      tekstyleundefined 1 Reply Last reply Reply Quote 0
      • tekstyleundefined
        tekstyle @MintyTrebor
        @mintytrebor
        My DSF event node/model path = state.displayMessage
        debug node/output = msg.dsf.eventValue
        the debug window above looks like this:
        1/9/2022, 9:07:14 PMnode: aebd8e98337002b3
        dsfModel : msg.dsf.eventValue : string[4]
        "dfsf"
        my email looks like this:
        {"fullModel":{"boards":[{"axisMins":[-198.7,-244,0,0],"axisMaxes":[214,196,365,141],"accelerations":[900,900,100,800,500,500,500,500,1250,1250,600,1250],"currents":[1000,1000,1700,0,0,0,0,0,680,680,500,680],"firmwareElectronics":"Duet WiFi 1.02 or later + DueX5","firmwareName":"RepRapFirmware for Duet 2 WiFi/Ethernet","firmwareVersion":"3.3","dwsVersion":"1.26","firmwareDate":"2021-06-15","sysdir":"0:/sys/","idleCurrentFactor":30,"idleTimeout":30,"minFeedrates":[33.33,33.33,8.33,0.83,15,15,15,15,50,50,5,50],"maxFeedrates":[333.33,333.33,8.33,133.33,100,100,100,100,133.33,133.33,60,133.33],"mcuTemp":{"current":29.7},"vIn":{"current":24.1}}],"directories":{},"fans":[{"actualValue":0,"requestedValue":0,"rpm":-1},null,null,{"actualValue":0,"requestedValue":1,"rpm":-1},{"actualValue":1,"requestedValue":1,"rpm":-1},{"actualValue":1,"requestedValue":1,"rpm":-1},{"actualValue":0,"requestedValue":1,"rpm":-1},null,{"actualValue":0,"requestedValue":0,"rpm":-1},{"actualValue":0,"requestedValue":0,"rpm":-1}],"global":{"PTOOL":-1,"BH3":0,"BH2":0,"BH1":0,"BH0":0,"BED":0,"PCCFHOTENDR":160,"PCCFHOTENDS":265},"heat":{"heaters":[{"active":0,"current":18,"standby":0,"state":"off"},{"active":0,"current":18,"standby":0,"state":"off"},{"active":0,"current":-273.1,"standby":0,"state":"off"},{"active":0,"current":-273.1,"standby":0,"state":"off"},{"active":0,"current":18,"standby":0,"state":"off"},{"active":0,"current":18,"standby":0,"state":"off"},{"active":0,"current":18.3,"standby":0,"state":"off"},{"active":0,"current":20.3,"standby":0,"state":"off"}]},"inputs":[{"feedRate":50,"lineNumber":2,"state":"idle"},{"feedRate":50,"lineNumber":0,"state":"idle"},{"feedRate":50,"lineNumber":0,"state":"idle"},{"feedRate":50,"lineNumber":0,"state":"idle"},{"feedRate":50,"lineNumber":67965,"state":"idle"},{"feedRate":50,"lineNumber":0,"state":"idle"},{"feedRate":50,"lineNumber":0,"state":"idle"},{"feedRate":50,"lineNumber":0,"state":"idle"},null,{"feedRate":50,"lineNumber":0,"state":"idle"},null,{"feedRate":50,"lineNumber":0,"state":"idle"}],"job":{"build":null,"duration":null,"filePosition":0,"layer":null,"layerTime":null,"pauseDuration":null,"rawExtrusion":null,"timesLeft":{"filament":null,"file":null,"slicer":null},"warmUpDuration":null},"limits":{},"move":{"axes":[{"machinePosition":0,"userPosition":0},{"machinePosition":0,"userPosition":0},{"machinePosition":0,"userPosition":0},{"machinePosition":0,"userPosition":0}],"currentMove":{"acceleration":0,"deceleration":0,"laserPwm":null,"requestedSpeed":0,"topSpeed":0},"extruders":[{"position":0,"rawPosition":0},{"position":0,"rawPosition":0},{"position":0,"rawPosition":0},{"position":0,"rawPosition":0},{"position":0,"rawPosition":0}],"virtualEPos":0},"network":{},"scanner":{},"sensors":{"analog":[{"lastReading":18},{"lastReading":18},{"lastReading":18.3},{"lastReading":20.3},{"lastReading":18},{"lastReading":-273.1},{"lastReading":-273.1},{"lastReading":18}],"endstops":[{"triggered":false},{"triggered":false},null,{"triggered":true}],"filamentMonitors":[null,null,null,{"status":"ok"}],"gpIn":[],"probes":[{"value":[0]}]},"seqs":{"boards":0,"directories":0,"fans":14,"global":8,"heat":42,"inputs":11,"job":1,"move":48,"network":4467,"reply":2,"scanner":1,"sensors":12,"spindles":0,"state":3,"tools":22,"volChanges":[1,0],"volumes":120},"spindles":[{"current":0,"state":"unconfigured"},{"current":0,"state":"unconfigured"},{"current":0,"state":"unconfigured"},{"current":0,"state":"unconfigured"}],"state":{"messageBox":{"title":null,"message":null},"atxPower":null,"currentTool":-1,"gpOut":[],"laserPwm":null,"msUpTime":71,"nextTool":-1,"previousTool":-1,"status":"idle","time":"2022-01-09T20:57:15","upTime":11396,"displayMessage":"he"},"tools":[{"active":[],"standby":[],"state":"off"},{"active":[0],"standby":[0],"state":"off"},{"active":[0],"standby":[0],"state":"off"},{"active":[0],"standby":[0],"state":"off"},{"active":[0],"standby":[0],"state":"off"}],"volumes":[{},{}]},"patchModel":{"boards":{"0":{"vIn":{"current":24.1}}},"heat":{"heaters":{"0":{"current":18},"1":{"current":18},"4":{"current":18},"5":{"current":18},"6":{"current":18.3}}},"inputs":{"0":{"lineNumber":2}},"sensors":{"analog":{"0":{"lastReading":18},"1":{"lastReading":18},"2":{"lastReading":18.3},"4":{"lastReading":18},"7":{"lastReading":18}}},"seqs":{"reply":2,"state":3},"state":{"msUpTime":71,"time":"2022-01-09T20:57:15","upTime":11396,"displayMessage":"he"}},"prevModel":{"boards":[{"axisMins":[-198.7,-244,0,0],"axisMaxes":[214,196,365,141],"accelerations":[900,900,100,800,500,500,500,500,1250,1250,600,1250],"currents":[1000,1000,1700,0,0,0,0,0,680,680,500,680],"firmwareElectronics":"Duet WiFi 1.02 or later + DueX5","firmwareName":"RepRapFirmware for Duet 2 WiFi/Ethernet","firmwareVersion":"3.3","dwsVersion":"1.26","firmwareDate":"2021-06-15","sysdir":"0:/sys/","idleCurrentFactor":30,"idleTimeout":30,"minFeedrates":[33.33,33.33,8.33,0.83,15,15,15,15,50,50,5,50],"maxFeedrates":[333.33,333.33,8.33,133.33,100,100,100,100,133.33,133.33,60,133.33],"mcuTemp":{"current":29.7},"vIn":{"current":24.2}}],"directories":{},"fans":[{"actualValue":0,"requestedValue":0,"rpm":-1},null,null,{"actualValue":0,"requestedValue":1,"rpm":-1},{"actualValue":1,"requestedValue":1,"rpm":-1},{"actualValue":1,"requestedValue":1,"rpm":-1},{"actualValue":0,"requestedValue":1,"rpm":-1},null,{"actualValue":0,"requestedValue":0,"rpm":-1},{"actualValue":0,"requestedValue":0,"rpm":-1}],"global":{"PTOOL":-1,"BH3":0,"BH2":0,"BH1":0,"BH0":0,"BED":0,"PCCFHOTENDR":160,"PCCFHOTENDS":265},"heat":{"heaters":[{"active":0,"current":18.1,"standby":0,"state":"off"},{"active":0,"current":18.1,"standby":0,"state":"off"},{"active":0,"current":-273.1,"standby":0,"state":"off"},{"active":0,"current":-273.1,"standby":0,"state":"off"},{"active":0,"current":17.9,"standby":0,"state":"off"},{"active":0,"current":17.9,"standby":0,"state":"off"},{"active":0,"current":18.1,"standby":0,"state":"off"},{"active":0,"current":20.3,"standby":0,"state":"off"}]},"inputs":[{"feedRate":50,"lineNumber":1,"state":"idle"},{"feedRate":50,"lineNumber":0,"state":"idle"},{"feedRate":50,"lineNumber":0,"state":"idle"},{"feedRate":50,"lineNumber":0,"state":"idle"},{"feedRate":50,"lineNumber":67965,"state":"idle"},{"feedRate":50,"lineNumber":0,"state":"idle"},{"feedRate":50,"lineNumber":0,"state":"idle"},{"feedRate":50,"lineNumber":0,"state":"idle"},null,{"feedRate":50,"lineNumber":0,"state":"idle"},null,{"feedRate":50,"lineNumber":0,"state":"idle"}],"job":{"build":null,"duration":null,"filePosition":0,"layer":null,"layerTime":null,"pauseDuration":null,"rawExtrusion":null,"timesLeft":{"filament":null,"file":null,"slicer":null},"warmUpDuration":null},"limits":{},"move":{"axes":[{"machinePosition":0,"userPosition":0},{"machinePosition":0,"userPosition":0},{"machinePosition":0,"userPosition":0},{"machinePosition":0,"userPosition":0}],"currentMove":{"acceleration":0,"deceleration":0,"laserPwm":null,"requestedSpeed":0,"topSpeed":0},"extruders":[{"position":0,"rawPosition":0},{"position":0,"rawPosition":0},{"position":0,"rawPosition":0},{"position":0,"rawPosition":0},{"position":0,"rawPosition":0}],"virtualEPos":0},"network":{},"scanner":{},"sensors":{"analog":[{"lastReading":18.1},{"lastReading":17.9},{"lastReading":18.1},{"lastReading":20.3},{"lastReading":18.1},{"lastReading":-273.1},{"lastReading":-273.1},{"lastReading":17.9}],"endstops":[{"triggered":false},{"triggered":false},null,{"triggered":true}],"filamentMonitors":[null,null,null,{"status":"ok"}],"gpIn":[],"probes":[{"value":[0]}]},"seqs":{"boards":0,"directories":0,"fans":14,"global":8,"heat":42,"inputs":11,"job":1,"move":48,"network":4467,"reply":1,"scanner":1,"sensors":12,"spindles":0,"state":2,"tools":22,"volChanges":[1,0],"volumes":120},"spindles":[{"current":0,"state":"unconfigured"},{"current":0,"state":"unconfigured"},{"current":0,"state":"unconfigured"},{"current":0,"state":"unconfigured"}],"state":{"messageBox":{"title":null,"message":null},"atxPower":null,"currentTool":-1,"gpOut":[],"laserPwm":null,"msUpTime":838,"nextTool":-1,"previousTool":-1,"status":"idle","time":"2022-01-09T20:57:14","upTime":11395},"tools":[{"active":[],"standby":[],"state":"off"},{"active":[0],"standby":[0],"state":"off"},{"active":[0],"standby":[0],"state":"off"},{"active":[0],"standby":[0],"state":"off"},{"active":[0],"standby":[0],"state":"off"}],"volumes":[{},{}]}}
        MintyTreborundefined 1 Reply Last reply Reply Quote 0
          @tekstyle The help from the email node states:
          So if you want the email to just be the M117 msg text you have to set msg.payload = msg.dsf.eventValue
          you need to add a change node to make this change
          Repo
          • tekstyleundefined
            @mintytrebor Thank you for the tip to check the email node's help. still learning how to use it.
            I was able to just send the M117 message. now i am working on how i can send values from the object modelling to it. It will take some time to play around with.
            Thanks for getting me started and helping me get a little familiar with how node-red works.
              MintyTrebor @MintyTrebor
              V1.1.5 Update - Improved communication in Duet mode which should resolve issue where board could crash or fail to respond, plus fixed node not stopping on deploy when active.
              Repo
              tekstyleundefined 1 Reply Last reply Reply Quote 1
              • tekstyleundefined
                @mintytrebor
                I am curious to understand how NodeDSF works. so even though I am just trying to monitor for changes in the display message when a M117 is entered, what I noticed is that when ANY thing gets posted in the console, it trigger a flow no matter if a new M117 command was evoked. I just want to make sure I got this correct.
                Regarding your update, majority of my wifi issues came from having a node-red server running on the same network as my duet2wifi. I was getting frequent disconnects that was impossible to resolve. Your update seems to have fixed some of those issues but I still have to mess around with it some more to make sure that was the case.
                Currently, I have a very interesting setup. I have 2 wifi adapters on my laptop. 1 integrated, and 1 via USB. i have my integrated connected to my home WIFI. i have the USB connected to the duet in access point mode. i have node-red installed on my windows 10 machine. I am able to access the internet and connect to both node-red and duet2 board with a working nodeDSF.
                MintyTreborundefined 2 Replies Last reply Reply Quote 0
                  @tekstyle The monitor node gets the machine object model from the sbc/control board about every 200ms (much like DWC does), and pushes it to the next node as a msg, with 3 main categories: The new Full Model, the Delta Model (just what's changed since the last msg), and the Previous Model.
                  Essentially the monitor node is emulating the same method the DWC uses to get data from the board, what happens with that information is up to your flow design.
                  The event node is designed to watch for user defined object model keys that change from the monitor node so you can trigger specific flows/actions only when the value changes, eg when the printer state changes from printing to paused.
                  The other nodes are specific functions to send gcode commands back to the sbc/control board, and to look for specially formatted M291 messages (see the NodeDSF wiki).
                  Repo
                    @tekstyle I would not recommend running node-red & NodeDSF on the same PC where DWC is also open in a browser, its the same as running 2 DWC sessions at the same time, which will generate a lot of network traffic. Your dual wifi may have mitigated this restriction.
                    My original use case for NodeDSF was to integrate the printer with my existing home automation solution running on Node-Red, which is running on a standalone SBC, so the design kind of reflects that original use case (and probably why I never experienced any crashes/issues)
                    Repo
                    • tekstyleundefined
                      @mintytrebor
                      thanks for the recommendation. i am in the process of converting my duet2wifi to SBC. just waiting on the adapter for the wifi module pinout.
                      • jgrg1undefined
                        jgrg1
                        Have to say, this project is excellent. Having never used NodeRed, it was relatively trivial to setup on my Raspberry pi 3b+ SBC board (following the instructions) and get going. I then wired up a pushover node, and voila, I now have notifications on my phone.
                        Essentially, I wanted to recreate the pushover notifications that you get with octoprint, and this worked a treat. It's actually more powerful, as the DSF-Event nodes let you look for specific changes with the Duet object model.
                        I used the DSF-Intercept node (with custom g-code added in the slicer) to check for layer changes and report when the first layer was started and finished.
                        MintyTreborundefined 1 Reply Last reply Reply Quote 1
                        • ilias.khizanundefined
                          ilias.khizan
                          This post is deleted!
                            MintyTrebor @jgrg1
                            V1.1.11 Update - Nodes updated to RRF 3.5 comptability. Update through Node-Red Palette manager.
                            Repo
                            DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 1
                            • DIY-O-Sphereundefined
                              DIY-O-Sphere @MintyTrebor
                              @MintyTrebor
                              I would like to share my experience with installing NodeDSF.
                              I am running Node-Red in a Docker container on a PI4.
                              It is important not to load the latest Node-Red image when setting up the container.
                              If you do, NodeDSF will not install. (Incompatible node.js version).
                              With nodered/node-red:3.1.0-18 as image it worked.
                              Info about specific images are here https://github.com/node-red/node-red-docker
                              It took me hours to figure this out....
                              (UTC+1)
                                MintyTrebor @DIY-O-Sphere
                                @DIY-O-Sphere NodeDSF is built against the recommended NodeJS version (18) as stated by node-red here https://nodered.org/docs/faq/node-versions
                                Unfortunately if the docker image maintainers have not updated thier "latest" image to NodeJS18 there is not much I can do about it.
                                Repo
                                DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                                  @MintyTrebor
                                  This should not be a criticism rather meant as a help for others.
                                  And it's a bit strange that the latest image contains such old versions of node.js....
                                  (UTC+1)
                                    @DIY-O-Sphere said in NodeDSF : Interface nodes for Node-Red (V1.1.11 - 06-10-23).:
                                    Yep - a user of my nodes for klipper (moonnode) hit the same problem (v18 nodes on v16 docker image), he raised the issue with the docker image maintainers and there response was something like "we wont update the node version until the next major release" - which is not ideal
                                    Repo
