Cannot upgrading firmware from 2.05.1 to 3.0 and 3.4.5
@genioluiz7 so thats fine. does it still show as
Duet ejected your HTTP request
when you navigate to 192.168.1.53? -
@genioluiz7 ok, i see the issue.
replace the contents of the www folder with the contents of this zip file https://github.com/Duet3D/RepRapFirmware/releases/download/2.05/DuetWebControl-SD-2.04.zip -
@jay_s_uk
Just to specify... Have I to unzip this file and put all the files inside in the www folder? -
@genioluiz7 yep
@jay_s_uk ok now? retry M122?
@genioluiz7 now try the ip address again (obviously with the SD card inserted and the board power cycled)
@jay_s_uk
again
@genioluiz7 my only other thought is that you're running the latest wifi firmware with 2.05.1.
put this file https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2CombinedFirmware.bin
and this file https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2CombinedIAP.bin
in the "sys" folder thats on the SD card.
Then with the sd card inserted sendM997
using YAT
that should install 3.0. you can then confirm using M115
then try browsing to the IP address again -
@droftarts I've already tried this
@jay_s_uk
So, have I just to put them in the sys folder? -
@genioluiz7 yep, then run M997 etc
@jay_s_uk M997
M997: Firmware binary "Duet2CombinedFirmware.bin" not found
ok -
@genioluiz7 and thats with the SD card installed in the board? that sounds slightly more concerning.
SendM39
and post the output -
@jay_s_uk M39
M39: No SD card mounted in slot 0
ok
Is it inserted on the right side? -
@genioluiz7 its orientated correctly but it should be inserted a lot deeper than that
@jay_s_uk yeah I know, I pull off it just for the picture
@genioluiz7 if its not detecting the SD card when its fully inserted, try another one
if that isn't detected then the SD card slot on the board is damaged in some way -
@jay_s_uk I retry few time
M39
ok
M39
ok
M39
ok
M39
okthe SD slot can be repaired?
@genioluiz7 it can be replaced yes. I tend to have a 50/50 chance when i've repaired boards in the past
