Duet Mini 5+ stuck in SBC mode
@moonman Where did you buy that board?
I got it from Filastruder.com.
@moonman The boards is reverting to SBC mode because it can't find an SD card. Both your M122 reports show no SD card, so either the SD card is not pushed far enough into the socket, or there's a failure of the card or card socket.
If you have tried an alternative card (make sure it is formatted correctly, and has the right files on it, see https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#formatting), and you're sure you have pushed it in far enough, can you post a good picture of the pins of the SD card holder? See https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#sd-card-socket
Yes I have tried 3 cards now and I used that link to format and install the files. I am pretty sure the card is in all the way. Also I don't know if this matters but the network port has no lights on when I plug in the Cable I assume that's is because it is in SBC mode.
@moonman the socket soldering looks fine. Can you show a bit more of the area behind the SD card socket? On the Mini 5+, occasionally it’s be of the small components behind the socket that fails.
@droftarts Yes, I will after work.
@droftarts here is the picture.
@moonman said in Duet Mini 5+ stuck in SBC mode:
When did you buy it?
@Phaedrux
@moonman said in Duet Mini 5+ stuck in SBC mode:this month on the 6th
Let's replace your board under warranty. Please send an email to warranty@duet3d.com and put Filastruder in CC. Also add a link to this forum thread and the details of your purchase. After that you'll receive a form to fill out.
@chrishamm will do thanks.
