Duetlapse3 "printer is not connected"
@Aurimas said in Duetlapse3 "printer is not connected":
could you please share 5.3.0 version? maybe you can email direct?
I shared it several posts above. If you are using the plugin, let me know and I can share that as well.
@stuartofmt I am using plugin in SBC mode.
All I can find is the Beta 3. can you please share the latest version?
thank you -
@stuartofmt same
DuetLapse3 Version 5.3.0
Connected to printer at: 192.168.1.128:8082Process Id: 1724
Last Update: Wednesday - 12:20
Capture Status:= Waiting
DuetLapse3 State:= start
Duet Status:= Printer is not connected
Images Captured:= 0
Current Layer:= None -
@stuartofmt same
Connected to printer at: 192.168.1.128:8082Hi - Iโm away from my printer for a couple of weeks but we should be able to resolve this.
Can you restart duetlapse3 plugin after setting the config file to include โ-verboseโ and post the log file?The error likely occurs when attempting to resolve the version number of the printer. Iโm wondering if the port number is confounding something. Is there a special reason why you have set the port number for the printer? Can you try it without the port number being set (I.e. no port number set for the printer and no port number set for DuetLapse3). When I switched to SBC, I must admit, I did not test with a port number set on the printer as I did not see an advantage to doing so. Is there one ?
Iโm assuming with this question that the SBC is not trying to serve up another web interface that uses port 80.
@stuartofmt thanks a lot
it says connected but in emulation mode.
what could be the reason for that?
i didn't change standard settings on DSFi tried to go to:
http://192.168.1.128/rr_connect?password=reprapand got this output
{"apiLevel":1,"err":0,"isEmulated":true,"sessionTimeout":8000,"boardType":"duet5lcunknown"}2023-07-14 09:11:12,255 - MainThread - DuetLapse3 Version --- 5.3.0 2023-07-14 09:11:12,256 - MainThread - Process Id --- 1655 2023-07-14 09:11:12,257 - MainThread - ------------------------------------------------------------------------------- 2023-07-14 09:11:12,257 - MainThread - dontwait has been changed to True 2023-07-14 09:11:12,258 - MainThread - ################### Options at start of this print job ##################### 2023-07-14 09:11:12,258 - MainThread - # Environment 2023-07-14 09:11:12,259 - MainThread - -duet = 192.168.1.128 2023-07-14 09:11:12,259 - MainThread - -basedir = /opt/dsf/sd/DuetLapse3 2023-07-14 09:11:12,260 - MainThread - -poll = 10 2023-07-14 09:11:12,260 - MainThread - -instances = single 2023-07-14 09:11:12,260 - MainThread - -logtype = both 2023-07-14 09:11:12,261 - MainThread - -nolog = False 2023-07-14 09:11:12,261 - MainThread - -verbose = True 2023-07-14 09:11:12,261 - MainThread - -host = 192.168.1.128 2023-07-14 09:11:12,261 - MainThread - -port = 8082 2023-07-14 09:11:12,261 - MainThread - -keeplogs = False 2023-07-14 09:11:12,262 - MainThread - -novideo = False 2023-07-14 09:11:12,262 - MainThread - -deletepics = False 2023-07-14 09:11:12,263 - MainThread - -maxffmpeg = 2 2023-07-14 09:11:12,263 - MainThread - -keepfiles = True 2023-07-14 09:11:12,264 - MainThread - # Execution 2023-07-14 09:11:12,264 - MainThread - -dontwait = True 2023-07-14 09:11:12,264 - MainThread - -seconds = 30 2023-07-14 09:11:12,264 - MainThread - -detect = none 2023-07-14 09:11:12,265 - MainThread - -pause = no 2023-07-14 09:11:12,265 - MainThread - -numlayers = 1 2023-07-14 09:11:12,265 - MainThread - -movehead = [0, 0] 2023-07-14 09:11:12,265 - MainThread - -rest = 1 2023-07-14 09:11:12,266 - MainThread - -standby = False 2023-07-14 09:11:12,266 - MainThread - -restart = True 2023-07-14 09:11:12,266 - MainThread - # Camera 2023-07-14 09:11:12,266 - MainThread - -camera1 = usb 2023-07-14 09:11:12,267 - MainThread - -camera2 = stream 2023-07-14 09:11:12,267 - MainThread - -weburl1 = http://192.168.1.128:8084/stream 2023-07-14 09:11:12,267 - MainThread - -weburl2 2023-07-14 09:11:12,267 - MainThread - # Video 2023-07-14 09:11:12,268 - MainThread - -extratime = 0 2023-07-14 09:11:12,268 - MainThread - -fps = 10 2023-07-14 09:11:12,268 - MainThread - -minvideo = 5 2023-07-14 09:11:12,268 - MainThread - -maxvideo = 0 2023-07-14 09:11:12,269 - MainThread - # Overrides 2023-07-14 09:11:12,269 - MainThread - -camparam1 2023-07-14 09:11:12,269 - MainThread - -camparam2 2023-07-14 09:11:12,269 - MainThread - -vidparam1 2023-07-14 09:11:12,270 - MainThread - -vidparam2 2023-07-14 09:11:12,270 - MainThread - # UI 2023-07-14 09:11:12,270 - MainThread - -hidebuttons = False 2023-07-14 09:11:12,272 - MainThread - # Special Functions 2023-07-14 09:11:12,272 - MainThread - -execkey 2023-07-14 09:11:12,272 - MainThread - ----------------------------------------------------------------------- 2023-07-14 09:11:12,272 - MainThread - ************************************************************************************ 2023-07-14 09:11:12,273 - MainThread - Warning: -seconds 30 and -detect none 2023-07-14 09:11:12,273 - MainThread - This combination implies -dontwait and will be set automatically 2023-07-14 09:11:12,274 - MainThread - ************************************************************************************ 2023-07-14 09:11:12,275 - MainThread - ########################################################## 2023-07-14 09:11:12,277 - MainThread - Will start capturing images immediately 2023-07-14 09:11:12,277 - MainThread - ########################################################## 2023-07-14 09:11:12,277 - MainThread - ########################################################## 2023-07-14 09:11:12,277 - MainThread - Video will be created when printing ends 2023-07-14 09:11:12,278 - MainThread - or if requested from the UI or M291 "DuetLapse3.completed" S2 2023-07-14 09:11:12,278 - MainThread - ########################################################## 2023-07-14 09:11:12,279 - MainThread - ########################################################## 2023-07-14 09:11:12,279 - MainThread - If running from a console using the command line 2023-07-14 09:11:12,280 - MainThread - Press Ctrl+C one time to stop the program and create a video. 2023-07-14 09:11:12,280 - MainThread - ########################################################## 2023-07-14 09:11:12,281 - MainThread - ***** Initializing state and counters ***** 2023-07-14 09:11:12,340 - MainThread - ########################################################## 2023-07-14 09:11:12,341 - MainThread - ***** Started http listener ***** 2023-07-14 09:11:12,341 - MainThread - ########################################################## 2023-07-14 09:11:12,342 - MainThread - Logging in to Printer 2023-07-14 09:11:12,342 - MainThread - 0 url: http://192.168.1.128/rr_disconnect post: False 2023-07-14 09:11:13,397 - MainThread - 1 url: http://192.168.1.128/rr_disconnect post: False 2023-07-14 09:11:14,434 - MainThread - 0 url: http://192.168.1.128/rr_connect?password=reprap post: False 2023-07-14 09:11:14,761 - MainThread - Connected but in emulation mode 2023-07-14 09:11:14,762 - MainThread - 0 url: http://192.168.1.128/machine/disconnect post: False 2023-07-14 09:11:14,893 - Thread-1 - !!!!! http call: {} !!!!! 2023-07-14 09:11:14,943 - Thread-2 - !!!!! http call: {'displayFiles': ['true']} !!!!! 2023-07-14 09:11:14,944 - Thread-2 - list_dir called with path = /opt/dsf/sd/DuetLapse3/Vega600/192-168-1-128 2023-07-14 09:11:14,945 - Thread-2 - Finished parsing the files directory 2023-07-14 09:11:15,796 - MainThread - 1 url: http://192.168.1.128/machine/disconnect post: False 2023-07-14 09:11:16,081 - Thread-3 - !!!!! http call: {'displayFiles': ['true']} !!!!! 2023-07-14 09:11:16,082 - Thread-3 - list_dir called with path = /opt/dsf/sd/DuetLapse3/Vega600/192-168-1-128 2023-07-14 09:11:16,082 - Thread-3 - Finished parsing the files directory 2023-07-14 09:11:16,833 - MainThread - 0 url: http://192.168.1.128/machine/connect?password=reprap post: False 2023-07-14 09:11:16,914 - MainThread - !!!!! Connected to SBC printer !!!!! 2023-07-14 09:11:16,915 - MainThread - 0 url: http://192.168.1.128/machine/status post: False 2023-07-14 09:11:17,124 - Thread-4 - !!!!! http call: {'getfile': ['/opt/dsf/sd/DuetLapse3/Vega600/192-168-1-128/startup.log']} !!!!! 2023-07-14 09:11:17,125 - Thread-4 - Trying to get file /opt/dsf/sd/DuetLapse3/Vega600/192-168-1-128/startup.log 2023-07-14 09:11:17,125 - Thread-4 - application/octet-stream
I am travelling and using my phone and have managed to confuse things. My appologies.
I have an incorrect UI element that I need to correct. The line that says Connected to printer at: 192.168.1.128:8082 is misleading (and led me astray).
Here is what happens:
The
-port
setting is only used for the UI that is generated by DuetLapse3. It has nothing to do with the printer, the SBC or DWC. This port setting needs to be different to any other http setting on your machine. -
When DuetLapse3 starts it checks to see if it is trying to connect in Standalaone or SBC mode using a failover approach. Emulation mode is relatively new and is not used by DuetLapse3. If it detects emulation mode, it (rightfully) tries to connect using SBC mode.
Once connected - it checks the version number
Based on your output from this:
i tried to go to: http://192.168.1.128/rr_connect?password=reprap
and the logfile output, you are using a standard configuration without any port assignments.
Also there is this line in the logfile that confirms SBC mode
Bottom line - you can ignore the messages about emulation mode. Did you check that the UI still says
?What is missing from the logfile you posted is the next part of the start sequence that confirms the versions. So I cannot confirm that the version was correctly determined.
Can you do two things please:
- resend a more complete logfile.
- send a screenshot or similar of the output from this url
I wondering if the firmware is being picked up differently due to differences in duet boards (unlikely).
@stuartofmt here is status output.
i checked the log and that all it is - there is no version section so nothing has been left out -
@Aurimas
I was able to take a closer look.
Please make the following changes to your config fileRemove the line
as it is not usually needed.
From the documentation
If omitted the default is 0.0.0.0
Generally this can be left out (default) as it will allow connection to the http listener from http://localhost:[port] (locally) or from another machine with network access using http://actual-ip-address-of-server-running-DuetLapse3[port]There is a problem with your camera settings. You have the following:
-camera1 usb -camera2 stream -weburl1 http://192.168.1.128:8084/stream -weburl2
What this is requesting is two cameras.
The first (-camera1) is a usb camera so-weburl1
will be ignored. The second (-camera2) is expecting a stream input but none is given in the corresponding-weburl2
I may not be trapping this unexpected set of options and this may be the cause of the issue. I'll have a look when I get back to my printer and camera.
Please confirm in your browser that
displays the camera output. Provided it does - I think your option settings should be:-camera1 stream -weburl1 http://192.168.1.128:8084/stream
with no second camera.
@stuartofmt it looks like there is some mismatch somewhere - might be just me.
there is no USB setting in the config file - please see attached.
Also updated log file attached - i tried before with host and without. made no difference. -
@Aurimas the camera itself is working fine - no issues at all. it is just not taking timelapse images.
The default for -camera1 is usb
You still have -camera2 stream in your config.
It should be -camera1 stream
@stuartofmt changed it as you instructed - no difference to connection. Still printer not connected.
log file attached. -
Thanks - this log shows that it is definitely not happy with getting the version number.
Something strange is happening. Iโll add some additional debug logging and send you a test plugin - hopefully later today.
Can you try this please.
Uninstall the existing plugin and install this version. Note that I have made the changes "blind" i.e. do not have access to my printer to test them.
There are two changes:- I added some defensive / debug code to the section that is checking the board version.
- No matter what the results of above - I am forcing a valid version to be returned. This should (hopefully) mean that DuetLapse3 continues on its merry way
In either case - there should be more information in the logfile and I can try to determine what the root cause is. Please post the logfile when you are able.
Note: you will need to remove the
.txt
extension from the attached file. -
Good news - we have progress
so now it is connected and it is even taking pictures.
the only problem is that it is taking images while the printer is idle (that was when the interval was set to 30s)
once I changed to layer detect it is still running but not taking images on its own.also why do I have detect layer still enabled?
2023-07-21 09:01:12,302 - MainThread - -seconds = 30
2023-07-21 09:01:12,303 - MainThread - -detect = layereven though it is not in the config.
-seconds 30
-verbose
startup.txtDuetLapse3 Version 5.3.0
Connected to printer at: 192.168.1.128:8082Process Id: 6407
Last Update: Friday - 08:53
Duet Status:= idle
Images Captured:= 0
so now it is connected and it is even taking pictures.Excellent - I now see where the problem lay and had fixed it but not promoted it to to the correct github folder (beta and non-beta variants are different). I'll do some tidy-up and (likely next week) create an updated version.
This is expected with both
-detect none
and-seconds [some number]
There is a message in the earlier log informing that this is equivalent to-dontwait
.once I changed to layer detect it is still running but not taking images on its own.
With no
-second
setting and-detect layer
the first image will not be captured until after layer 1 of the print job (also the logfile name will be changed reflect the printjob name).also why do I have detect layer still enabled?
even though it is not in the config.The default for
-detect
is layer
DuetLapse has expanded its capabilities over time and some values reflect previous defaults. The documentation is fairly comprehensive.Enjoy! If there are any further issues, let me know.
@stuartofmt thank you.
few more issues maybe bugs
- delete files buttons are not available until you restart the plugin
- video continues to build up, rather than restarting with every job.
@Aurimas
Whooops - looks like I recently introducted a bug. Thanks for pointing this out. I should be able to fix it quickly. -
@stuartofmt
I just did a quick check and it seems to be working ok BUT I'm not convinced as I have seen some strange behavior in the past. Mostly to do with video creation. Sometimes its difficult to trap errors ...Do you have the logfile? How many images did / do you have ?
What version of ffmpeg are you using ?
ffmpeg -version
Also - was this a print job that completed normaly or did you use the UI terminate --> graceful terminate ?
