Duetlapse3 "printer is not connected"
@stuartofmt here is status output.
i checked the log and that all it is - there is no version section so nothing has been left out -
@Aurimas
I was able to take a closer look.
Please make the following changes to your config fileRemove the line
-host = 192.168.1.128
as it is not usually needed.
From the documentation
If omitted the default is 0.0.0.0
Generally this can be left out (default) as it will allow connection to the http listener from http://localhost:[port] (locally) or from another machine with network access using http://actual-ip-address-of-server-running-DuetLapse3[port]There is a problem with your camera settings. You have the following:
-camera1 usb -camera2 stream -weburl1 http://192.168.1.128:8084/stream -weburl2
What this is requesting is two cameras.
The first (-camera1) is a usb camera so-weburl1
will be ignored. The second (-camera2) is expecting a stream input but none is given in the corresponding-weburl2
I may not be trapping this unexpected set of options and this may be the cause of the issue. I'll have a look when I get back to my printer and camera.
Please confirm in your browser that
displays the camera output. Provided it does - I think your option settings should be:-camera1 stream -weburl1 http://192.168.1.128:8084/stream
with no second camera.
@stuartofmt it looks like there is some mismatch somewhere - might be just me.
there is no USB setting in the config file - please see attached.
Also updated log file attached - i tried before with host and without. made no difference. -
@Aurimas the camera itself is working fine - no issues at all. it is just not taking timelapse images.
The default for -camera1 is usb
You still have -camera2 stream in your config.
It should be -camera1 stream
@stuartofmt changed it as you instructed - no difference to connection. Still printer not connected.
log file attached. -
Thanks - this log shows that it is definitely not happy with getting the version number.
Something strange is happening. I’ll add some additional debug logging and send you a test plugin - hopefully later today.
Can you try this please.
Uninstall the existing plugin and install this version. Note that I have made the changes "blind" i.e. do not have access to my printer to test them.
There are two changes:- I added some defensive / debug code to the section that is checking the board version.
- No matter what the results of above - I am forcing a valid version to be returned. This should (hopefully) mean that DuetLapse3 continues on its merry way
In either case - there should be more information in the logfile and I can try to determine what the root cause is. Please post the logfile when you are able.
Note: you will need to remove the
.txt
extension from the attached file. -
Good news - we have progress
so now it is connected and it is even taking pictures.
the only problem is that it is taking images while the printer is idle (that was when the interval was set to 30s)
once I changed to layer detect it is still running but not taking images on its own.also why do I have detect layer still enabled?
2023-07-21 09:01:12,302 - MainThread - -seconds = 30
2023-07-21 09:01:12,303 - MainThread - -detect = layereven though it is not in the config.
-seconds 30
-verbose
startup.txtDuetLapse3 Version 5.3.0
Connected to printer at: 192.168.1.128:8082Process Id: 6407
Last Update: Friday - 08:53
Capture Status:= Waiting
DuetLapse3 State:= start
Duet Status:= idle
Images Captured:= 0
Current Layer:= None -
@Aurimas said in Duetlapse3 "printer is not connected":
so now it is connected and it is even taking pictures.Excellent - I now see where the problem lay and had fixed it but not promoted it to to the correct github folder (beta and non-beta variants are different). I'll do some tidy-up and (likely next week) create an updated version.
This is expected with both
-detect none
and-seconds [some number]
There is a message in the earlier log informing that this is equivalent to-dontwait
.once I changed to layer detect it is still running but not taking images on its own.
With no
-second
setting and-detect layer
the first image will not be captured until after layer 1 of the print job (also the logfile name will be changed reflect the printjob name).also why do I have detect layer still enabled?
even though it is not in the config.The default for
-detect
is layer
DuetLapse has expanded its capabilities over time and some values reflect previous defaults. The documentation is fairly comprehensive.Enjoy! If there are any further issues, let me know.
@stuartofmt thank you.
few more issues maybe bugs
- delete files buttons are not available until you restart the plugin
- video continues to build up, rather than restarting with every job.
@Aurimas
Whooops - looks like I recently introducted a bug. Thanks for pointing this out. I should be able to fix it quickly. -
@stuartofmt
I just did a quick check and it seems to be working ok BUT I'm not convinced as I have seen some strange behavior in the past. Mostly to do with video creation. Sometimes its difficult to trap errors ...Do you have the logfile? How many images did / do you have ?
What version of ffmpeg are you using ?
ffmpeg -version
Also - was this a print job that completed normaly or did you use the UI terminate --> graceful terminate ?
I did introduce a bug last week. Payback for not being able to test changes with a printer !!! I dragged and dropped a
to a different part of a logical expression (that I was not editing) and, of course, it was no longer logical. Had me scartching my head for quite a whileWhile I was investigating, I spotted a possible timing / race condition with large image counts. May or may not have occured in nature but best avoided. The main visual difference is that a graceful terminate from the UI no longer has a popup confirming the video was created.
Both of these would have caused the lack of delete buttons since the program thought it was still capturing the current print job.
The delete buttons now work as expected but note that it may take several minutes, while the video is being created, for them to appear.
This, especially if there are a lot of images to process.I've run many hrs of test and all seems well. Version 5.3.2 for beta.4 is here:
thank you. will test it now. if any issues I will let you know
@stuartofmt is there a setting to start new video with new print?
right now it keeps recording the images under the same folder -
right now it keeps recording the images under the same folderIt depends a lot on the settings you already have. The documentation is pretty comprehensive but there is a lot of it
Can you explain the sequence of events and the settings you have? I can then explain how it should work with those settings.
For example, if you have
seconds > 0
anddontwait
(explicit or logical) and are not in 'standby' then after the prior print: images will continue to be captured eveny 'n' seconds and placed in a folder. When you start the next print job, the folder (and logfile) will be renamed to the name of the print job (keeping the accumulated images). I suspect this is what you are seeing.There are a couple of ways to change the behavior e.g. using
-standby
in the options will stop capture after the print job (no matter other settings). It does require a 'start' (from the UI or otherwise) at the start of the print job to allow.If you are not using
seconds
and just using-detect layer
and not using-standby
then at the end of the print job, no images will be captured until the start of the next print job (and folders / logs get renamed with the jobname)Another way is to send messages to DuetLapse3 to finely control the behavior using gcode. This is what I do
In 3.4.5 the M291 message command was used but recent changes in Duet3d firmware mean that does ot work as well as I would like. I'm finishing a custom alternative (likely today) and can walk you through it if yo like ?
@stuartofmt
for some reason when I click on the video now I get this message:
192.168.1.128 sent an invalid response. -
Please start a new thread and include a logfile with -verbose set
@stuartofmt i think the issue might be with the length of the name. is there anyway to rename files?
