Cannot upgrading firmware from 2.05.1 to 3.0 and 3.4.5
@jay_s_uk
how can i configure this page? -
@genioluiz7 assign things how they are in your current config
@jay_s_uk
Hi, I've configured the new file json. How can I be sure I set everything correctly? I want to check before upload that on duet.
@genioluiz7 the board doesn't use the json file it uses config.g
@droftarts don't worry I downloaded the zip file to from the RRF. Now what should I do?
@genioluiz7 said in Cannot upgrading firmware from 2.05.1 to 3.0 and 3.4.5:
Upload that zip file to the system tab in DWC.
@jay_s_uk don't worry I downloaded the zip file to from the RRF. Now what should I do?
@genioluiz7 if you have uploaded your configuration to the Duet, you now need to test everything works, and adjust it as necessary if it does not. Follow this guide: https://docs.duet3d.com/en/How_to_guides/Commissioning
@droftarts I've followed the instruction in the link you sent. After several configurations, these are the conclusions: something works something doesn't. The z-axis doesn't move correctly. My Chiron has two motors to lift the extruder, but only the left one is working, the other seems turned off.
So I think that I've to turn it on and next level the x-axis and synchronize the two z-motors (A and B) together.How can I fix this problem?
Many thanks for your help. Very appreciated. -
So I think that I've to turn it on and next level the x-axis and synchronize the two z-motors (A and B) together.Probably best to start a new thread for this problem. Include your config.g and how you have the motors connected.
