I have temporarily relocated and I cannot control my printer because of endless and repeated messages and responses coming up on the PanelDue complaining that the network is not connecting. I do not have the necessary USB cable for connecting the printer to this computer...
- How do I stop the messages from hiding the screen?
- How do I turn off the Wifi?
Edit the config.g on your SD card to remove the M552 S1 command that turns on the wifi module at startup.
@Phaedrux Thanks. I can do that.
Any way to make the messages popup not block the screen and all inputs?
What are your firmware versions?
undefined Phaedrux moved this topic from General Discussion
@Phaedrux M115 says that the firmware is 3.2.2, and the hardware is a Duet 2 Wifi and PanelDue 7i.
(Commenting out the M552 has got me underway. Thank you.)
