    Disable display of messages on PanelDue
    PanelDue
    • MJLewundefined
      MJLew
      I have temporarily relocated and I cannot control my printer because of endless and repeated messages and responses coming up on the PanelDue complaining that the network is not connecting. I do not have the necessary USB cable for connecting the printer to this computer...
      1. How do I stop the messages from hiding the screen?
      2. How do I turn off the Wifi?
        Edit the config.g on your SD card to remove the M552 S1 command that turns on the wifi module at startup.
        MJLewundefined 1 Reply Last reply Reply Quote 0
        • MJLewundefined
          MJLew @Phaedrux
          @Phaedrux Thanks. I can do that.
          Any way to make the messages popup not block the screen and all inputs?
            What are your firmware versions?
            • Phaedruxundefined Phaedrux moved this topic from General Discussion
            • MJLewundefined
              MJLew @Phaedrux
              @Phaedrux M115 says that the firmware is 3.2.2, and the hardware is a Duet 2 Wifi and PanelDue 7i.
              (Commenting out the M552 has got me underway. Thank you.)
