M574 can't disable pin
@dc42 please.. can you have a look at my issue? Any idea is welcomed
@Leonard03 I think you should repost your files as they are now and describe exactly what the problem is currently and when it happens. I've been following this thread and I've lost track of what is working and what is not.
@gloomyandy Hello!
I updated to drive the actual configuration of my printer.
I'll try simplify it how much as I can:
tpostX.g
->/loadToFinda.g
->/loadToBondtech.g
->/loadToNozzle.g
this works
tpostX.g
->/errorAction.g
->/loadToFinda.g
->/loadToBondtech.g
->/loadToNozzle.g
this doesn't work.The problem seems to be in
0:/sys/MMU Control/loadToNozzle.g
If it is called from tpostn the filament sensing is activated ok
if it is called via the "errorAction.g" i get this errorError: Pin 'duex.e2stop' is not free Error: G1: Failed to enable endstops
wich cancels the print but looking in OM after that error, the filament sensor is enabled as it should
@Leonard03 said in M574 can't disable pin:
tpostX.g -> /errorAction.g -> /loadToFinda.g -> /loadToBondtech.g -> /loadToNozzle.g
Since you have a lot of nested macros, I think the actual control flow is more complex than you have shown here. Try adding an echo command to the start of each macro in the
MMU Control
folder to help find what file the error is actually in.This error
can only occur with aG1 H1/3/4
command which is not present inloadToNozzle.g
, which implies (at least part of) the issue is in some other macroCan you send the full console output of the macro calls that: a) work, b) do not work
@AndyE3D said in M574 can't disable pin:
This error Error: G1: Failed to enable endstops can only occur with a G1 H1/3/4 command which is not present in loadToNozzle.g, which implies (at least part of) the issue is in some other macro
I thought about this as well. I modified only the
errorAction.g
errorAction_debug.txt
I opted forM118
becauseecho
commands gets skipped (not showing in the console).On the other hand, for whatever reason I can't download the console as text but I copy it here
Console.txt -
That error must come from load or unload to finda. That are only macros that uses exp.e2stop followed by a G1 H4 command. But the strange thing is that those macros behave as they should even with that error in place. Maybe that error cannot show up until any macros are executed, but even then, everything works as it should except for that error wich cancels any print
No one..?
Good morning everyone
Since I got almost no answer, especially from devs, I have a simple question:This issue, being a software issue (I assume that I opted to try the beta firmwares) is there any chance that updating the endstops pins configurations between deeply nested macros to be solved before the first release candidate of RRF3.5 becomes available?
@Leonard03 Unfortunately complex macros like this can become pretty much "write only code" (at least to anyone other than the author), so it is very hard for anyone else to follow exactly what is happening here. Looking at your current debug traces I suspect that the full execution path has still not been revealed with the addition of the trace code in the errorAction.g macro (remember that if there is a bug in RRF the code path may not be what you think it is). I suggest that what you should do is...
- As mentioned above "Try adding an echo (or M118) command to the start of each macro in the MMU Control folder to help find what file the error is actually in."
- Add additional M118 commands whenever you enable/disable the problem endstop
- Add additional M118 commands whenever you make a G1 H4 command (or any other command that uses an endstop).
Hopefully this will reveal the full code path being followed and we can then narrow down what is going on.
I realise this is very tedious, but it is pretty much impossible for anyone else to try and reproduce the situation you have. For a developer to be able to fix a problem (if there is one) we really need to be able to reproduce the issue ideally with as simple an example as possible and one that does not require special hardware.
@Leonard03 please can you try to reduce the complexity of the macros to the minimum need to reproduce the fault. Then I will try to reproduce it.
Good morning everyone!
First of all, I would like to apologize to you. This was not an issue with RRF but with my own code... Thank you all for your help and support!
Just in case, @gloomyandy and @AndyE3D you were right about M118 in every file in MMU Control. But I has no chance seeing something unusual until I used logging.
@dc42 I am sorry for tagging you here and wasting your time.. was my fault, not RRF's fault..The problem was elsewhere, right at the beginning, in
tpostn.g
There, were three simple calls: load the filament in the MMU, then in the extruder and last in the nozzle. If during those macros any error raised, the tool change macro continued showing a dialog (M291). But, it can also callerrorAction.g
which by itself loads the filament all the way to the nozzle, but being called from a "while" loop intpostn.g
, aftererrorAction.g
the while loop was trying to load it again to the MMU. The log confirmed that:2023-08-02 12:02:28 [debug] Finish: loadToBondtech.g 2023-08-02 12:02:28 [debug] Begin: idlerMove.g 2023-08-02 12:02:28 [debug] Finish: idlerMove.g 2023-08-02 12:02:28 [debug] Begin: loadToNozzle.g 2023-08-02 12:02:28 [debug] Finish: loadToNozzle.g < here the duex.e2stop is configured as a filament sensor 2023-08-02 12:02:28 [debug] Begin: loadToFinda.g < here the duex.e2stop is used to load the filament in the MMU 2023-08-02 12:02:35 [warn] Error: Pin 'duex.e2stop' is not free 2023-08-02 12:02:35 [warn] Error: G1: Failed to enable endstops 2023-08-02 12:02:41 [info] Event logging stopped
In
tpostn.g
adding a break statement to exit the wile loop solved this problemThank you again to all of you for your support!
