Printer paused by it self?
I just started a print and all of a sudden the printer paused. I was there so I saw the whole thing and even on the PanelDue.
It was printing and then just stopped, beeped and moved to the pause position. On the display it looked just like I would have tapped pause (which I didn't, wasn't even near the display).
What could have caused this?
After I resumed most of the filament didn't stick to the bed, that has never happened on this printer before. Something really strange. I also noticed afterwards the tool heater was marked as "fault".
@Reine if the heater was marked as fault then I expect it was a heater fault that triggered the pause.
What version of firmware are you running?
Was there anything else reported in the DWC console?
@Reine said in Printer paused by it self?:
If the heater faulted the temp would have dropped.
@T3P3Tony I'm on 3.4.6. Nothing else reported and after a restart the same print came out fine also the four prints after that.
@Reine If it happens again you need to investigate the heater fault.
This just happened again and the heater was at 200c just like it should.
This was in the console though, not sure what it means.
Could it be the heater overshooting? It's supposed to be 200c but I notice it overshoots to 210c before dropping.
Could be due to the cooling fan is inactive and I pid tuned with it on..
If so it's strange it started happening now and not before. -
I suggest you retune your heater as a tool so that it can take the cooling fan into account.
M303 T0 S220
for examplehttps://docs.duet3d.com/User_manual/Reference/Gcodes#m303-run-heater-tuning
