I can not move the stepper
808
    T3P3Tony administrators @Makergal3D
    @Makergal3D said in I can not move the stepper:
    M574 Z1 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io2.in
    it would be normal to have one endstop per z axis motor so the individual axes can be trammed to the overall Z axis however AFAIK thats not mandatory.
    what happens when you send M98 P"0:sys/config.g"
    undefined undefined 2 Replies Last reply 6 Aug 2023, 19:33 Reply Quote 0
      Makergal3D @Makergal3D
      The drivers in Z has breakes, because the ammount of weight of the gantry, I read in the manual that I need a relay to open the break, but could I connect the break to an output in the board??
      Best
      Alvaro
        Makergal3D @T3P3Tony
        @T3P3Tony said in I can not move the stepper:
        M98 P"0
        I was thinking in using a probe to detect the bed, so I don't need extra endstops.
        When I type M98 P0, the control panel said this "M98 P0 Warning: Macro file 0 not found"
          T3P3Tony administrators @T3P3Tony
          you need to have the "", what this command is doing is running the config file again to see if there are errors in it that i did not notice - those will be shown in the console on DWC
          I did not realise the drivers had brakes, you need to setup the brake control. You can control the brakes from the board
          https://docs.duet3d.com/User_manual/Reference/Gcodes#m5697-configure-motor-brake-port
          undefined 2 Replies Last reply 10 Aug 2023, 10:50 Reply Quote 0
            This post is deleted!
              Hi @T3P3Tony to last questions I think i'm almost ready to test.
              Just 2 question. with the M98 is gives me back this.
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
              Error: Setting not available for external drivers
              When I start up the machine it said this all the times I power UP
              Warning: Discarded std reply src=122 RID=3 exp=4 "Setting not available for external drivers"
              Ans last, how do I select PIN from the 1XD board, I gor 4 heaters in my assembly and I would like to control 1 heater from the 1XD board. But I can not find in the forum how to set it up. The heater is in the Out 0 of the 1XD, it will control an SSR
              Thanks in advance
              undefined 1 Reply Last reply 10 Aug 2023, 13:33 Reply Quote 0
                droftarts administrators @Makergal3D
                I expect this error is caused by trying to set the stepper drive current for the external drivers in the M906 line:
                Remove X, Y and Z parameters.
                It is not ideal to run a heater from the 1XD. One of the limitations of RRF is that any heater has to be connected to the same board as the temperature sensor that controls it. While the 1XD does have a thermistor input, it is lower resolution than the temperature inputs on other Duet boards. It was originally intended for monitoring the temperature of connected motors. However, if it is enough for your application, yes, you should be able to control the heater. Note that the OUT0 and OUT1 are limited to 2A, and are driven at the input voltage (up to 48V) so if using an SSR, check the voltage limits. If it works with 3.3V signalling, you can use an io.out pin to control it.
                undefined 1 Reply Last reply 10 Aug 2023, 14:23 Reply Quote 0
                  Makergal3D @droftarts
                  @droftarts So I should move the thermistor also to the 1XD boards.
                  But I got the same question how do I say here that the pin is in the 1XD board
                  I supoose that in with the M950 but what number should I use for defining the pin in the 1XD board??
                  M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp3
                  M950 H0 C"out0" T0 ; create bed heater output on out3 and map it to sensor 0
                  M143 H0 S100 ; set temperature limit for heater 0 to 100C4
                  Thanks
                  undefined 1 Reply Last reply 10 Aug 2023, 14:41 Reply Quote 0
                    @Makergal3D prefix the pin name with the CAN address, eg
                    M308 S0 P"122.temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp3
                    See https://docs.duet3d.com/en/User_manual/Machine_configuration/CAN_connection#using-can-addresses
                    undefined 1 Reply Last reply 10 Aug 2023, 14:53 Reply Quote 1
                      @droftarts Yes you mean putting in this line the 122 address I suppose
                      M950 H0 C"122.out0" T0
                      undefined 1 Reply Last reply 11 Aug 2023, 21:53 Reply Quote 0
                        I got another question. I got my extruder in the 1XD board, I change the can Address to 40, I can comunicate correctly with the board. But I'm not shure if I configure correctly the extruder.
                        Should I select in anyway that in the tool section in config, that my driver is in the can Address 40¿¿
                        But If I try to move the extruder from the DWC, i configure a filament to be able to extrude, but if a click in retract, or in extrude, it doesn't do anything. No movement at all.
                        Extruder is a 240 degrees so it should not be related with the minimum extrusion temperature.
                        Thanks
                        ; Configuration file for Duet 3 MB 6XD (firmware version 3.3)
                        ; generated by RepRapFirmware Configuration Tool v3.3.16 on Fri Aug 11 2023 20:50:08 GMT+0200 (hora de verano de Europa central)
                        M550 P"GM200" ; set printer name
                        ; Wait a moment for the CAN expansion boards to start
                        G4 S2
                        M551 P"Makergal" ; set password
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                        M569 P0.0 T1:1:2:0
                        M569 P0.1 T1:1:2:0
                        M569 P0.2 T1:1:2:0
                        M569 P0.3 T1:1:2:0
                        M569 P0.4 S1 ; physical drive 0.4 goes forwards
                        M569 P0.4 T1:1:2:0
                        M569 P0.5 S1 ; physical drive 0.5 goes forwards
                        M569 P0.5 T1:1:2:0
                        M569 P40.0 S1 R1 ; physical drive 121.0 goes forwards
                        M569 P40.0 T1:1:2:0
                        M584 X0.0 Y0.1 Z0.5:0.4:0.3:0.2 E40.0 ; set drive mapping
                        M671 X50:50:1100:1100 Y250:1850:1850:250 S0.5 ; leadscrews at rear left, front middle and rear right
                        M92 X16.00 Y16.00 Z320.00 E420.00 ; set steps per mm
                        M566 X900.00 Y900.00 Z30.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                        M203 X3000.00 Y3000.00 Z200.00 E1200.00 ; set maximum speeds (mm/min)
                        M201 X1000.00 Y1000.00 Z5.00 E250.00 ; set accelerations (mm/s^2)
                        M84 S30 ; Set idle timeout
                        M208 X1200 Y2000 Z995 S0 ; set axis maxima
                        M574 X1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
                        M574 Y1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
                        M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                        M308 S0 P"40.temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin 121.temp0
                        M950 H0 C"40.out0" T0 ; create bed heater output on out3 and map it to sensor 0
                        M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as PT1000 on pin temp0
                        M950 H1 C"out0" T1 ; create nozzle heater output on out0 and map it to sensor 1
                        M307 H1 R0.952 K0.203:0.000 D38.46 E1.35 S1.00 B0 V24.3 ; disable bang-bang mode for heater and set PWM limit
                        M308 S2 P"spi.cs2" Y"rtd-max31865" ; configure sensor 2 as PT1000 on pin temp1
                        M950 H2 C"out1" T2 ; create nozzle heater output on out1 and map it to sensor 2
                        M307 H2 R0.747 K0.166:0.000 D26.47 E1.35 S1.00 B0 V24.3 ; disable bang-bang mode for heater and set PWM limit
                        M143 H2 S280 ; set temperature limit for heater 2 to 280C
                        M308 S3 P"spi.cs3" Y"rtd-max31865" ; configure sensor 3 as PT1000 on pin temp2
                        M950 H3 C"out2" T3 ; create nozzle heater output on out2 and map it to sensor 3
                        M307 H3 R0.972 K0.189:0.000 D19.35 E1.35 S1.00 B0 V24.3 ; disable bang-bang mode for heater and set PWM limit
                        M143 H3 S280 ; set temperature limit for heater 3 to 280C
                        M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
                        M106 P0 S0 H1:2:3:0 T45 ; set fan 0 value. Thermostatic control is turned on
                        M563 P0 S"PULSAR" D0 H1:2:3 F0 ; define tool 0
                        M302 S120 R110
                          charlie323a
                          I try to use G91 and then G1 H2 X10 but not movement at all. Even if I use G92 X0 Y0 Z0 I can press the movement button in the dashboard, the numbers change in the status area, but the machine is not moving at all.
                          undefined 2 Replies Last reply 14 Aug 2023, 15:19 Reply Quote 0
                            Makergal3D @charlie323a
                              @charlie323a Use M564 H0, that should allow you to move without homing. without homing you can move the axis, that command allows you to move without it, but be carefull
                                Makergal3D
                                Hi i'm comming back this issue agian.
                                Because I'm having troubles, everything works unless the extruder driver.
                                I have an 6XD board and a 1XD, the extruder is in the 1XD, but I'm not able to move it.
                                this is my config.g
                                ; generated by RepRapFirmware Configuration Tool v3.4.1 on Tue Jun 04 2024 19:55:09 GMT+0200 (hora de verano de Europa central)
                                G90                                          ; send absolute coordinates...
                                M83                                          ; ...but relative extruder moves
                                M550 P"My Printer"                           ; set printer name
                                G4 S2
                                M551 P"Soon2020"                                 ; set password
                                M569 P0.0 T1:1:2:0
                                M569 P0.1 T1:1:2:0
                                M569 P0.2 T1:1:2:0
                                M569 P0.3 T1:1:2:0
                                M569 P0.4 T1:1:2:0
                                M569 P0.5 T1:1:2:0
                                M569 P45.0 S0 R0                               ; physical drive 121.0 goes forwardsM569
                                M569 P45.0 T5:5:10:10
                                M350 X16  Y16 Z16 E16 I1
                                M584 X0.0 Y0.1 Z0.5:0.4:0.3:0.2 E45.0                   ; set drive mapping
                                M671 X60:60:1160:1160 Y174:1069:1069:174 S5 ; leadscrews at rear left, front middle and rear right
                                M92 X64.00 Y64.00 Z160.00 E225.00            ; set steps per mm
                                M566 X3000.00 Y3000.00 Z600.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
                                M203 X5000.00 Y5000.00 Z1200.00 E1200.00      ; set maximum speeds (mm/min)
                                M208 X-8:1060 Y-43:1200 Z0:1027 S1                                 ; set axis minima
                                M574 X1 S1 P"io2.in"                             ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
                                M574 Y1 S1 P"io3.in"                             ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
                                M574 Z1 S2                                       ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io2.in
                                M558 P1 C"^io4.in" B1 H5 F600:60 T6000                 ; set Z probe type to switch and the dive height + speeds
                                G31 P500 X-40 Y0 Z1                              ; set Z probe trigger value, offset and trigger height
                                M557 X100:1050 Y100:1050 S200                         ; define mesh grid
                                M308 S0 P"45.temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin 121.temp0
                                M950 H0 C"45.out0" T0                               ; create bed heater output on out3 and map it to sensor 0
                                M307 H0 R0.383 K1.328:0.000 D14.73 E1.35 S1.00 B0                               ; disable bang-bang mode for the bed heater and set PWM limit
                                M570 H0 P10 T15
                                M140 H0                                          ; map heated bed to heater 0
                                M143 H0 S120                                     ; set temperature limit for heater 0 to 120C
                                M307 H1 R0.876 K0.099:0.000 D36.88 E1.35 S1.00 B0 V24.3                                 ; disable bang-bang mode for heater  and set PWM limit
                                M563 P0 S"PULSAR" D0 H1:2:3 F0 T0                         ; define tool 0
                                G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
                                G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
                                M302 P1
                                My 122
                                m122
                                RepRapFirmware for Duet 3 MB6XD version 3.5.1 (2024-04-19 14:39:48) running on Duet 3 MB6XD v1.01 or later (standalone mode)
                                Board ID: 0JD2M-999AL-D25SW-6JTDD-3S06Q-T4ZB1
                                Used output buffers: 1 of 40 (19 max)
                                Error in macro line 37 while starting up: in file macro line 37 column 20: M350: array too long, max length = 0
                                Static ram: 153624
                                Dynamic ram: 120392 of which 16 recycled
                                Never used RAM 69032, free system stack 192 words
                                Tasks: NETWORK(1,ready,32.8%,183) ETHERNET(5,nWait 7,0.1%,317) HEAT(3,nWait 6,0.1%,323) Move(4,nWait 6,0.0%,211) CanReceiv(6,nWait 1,0.0%,797) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,351) MAIN(1,running,67.0%,444) IDLE(0,ready,0.0%,30), total 100.0%
                                Owned mutexes:
                                Last reset 00:17:28 ago, cause: software
                                Last software reset at 2024-06-09 13:57, reason: User, Gcodes spinning, available RAM 69600, slot 2
                                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                                Error status: 0x00
                                Aux0 errors 0,0,0
                                MCU temperature: min 28.7, current 30.4, max 30.5
                                Supply voltage: min 24.1, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                                Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/80/0, gc cycles 0
                                Events: 2 queued, 2 completed
                                Driver 0: ok
                                Driver 1: ok
                                Driver 2: ok
                                Driver 3: ok
                                Driver 4: ok
                                Driver 5: ok
                                Date/time: 2024-06-09 14:15:25
                                Slowest loop: 38.55ms; fastest: 0.07ms
                                === Storage ===
                                Free file entries: 20
                                SD card longest read time 8.9ms, write time 0.0ms, max retries 0
                                DMs created 125, segments created 3, maxWait 122441ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                no step interrupt scheduled
                                Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                                === DDARing 0 ===
                                Scheduled moves 7, completed 7, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 7], CDDA state -1
                                === DDARing 1 ===
                                Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                SBC is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Aux2 is idle in state(s) 0
                                File2 is idle in state(s) 0
                                Queue2 is idle in state(s) 0
                                Q0 segments left 0, axes/extruders owned 0x0000000
                                Code queue 0 is empty
                                Code queue 1 is empty
                                === CAN ===
                                Messages queued 9457, received 16788, lost 0, errs 1, boc 0
                                Longest wait 2ms for reply type 6053, peak Tx sync delay 322, free buffers 50 (min 49), ts 5244/5243/0
                                Tx timeouts 0,0,0,0,0,0
                                === Network ===
                                Slowest loop: 8.23ms; fastest: 0.03ms
                                Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                                HTTP sessions: 1 of 8
                                = Ethernet =
                                Interface state: active
                                Error counts: 0 0 0 0 0 0
                                Socket states: 5 5 2 2 2 0 0 0
                                === Multicast handler ===
                                Responder is inactive, messages received 0, responses 0
                                M122 B45
                                Diagnostics for board 45:
                                Duet EXP1XD firmware version 3.5.1 (2024-04-19 14:42:58)
                                Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25)
                                All averaging filters OK
                                Never used RAM 6016, free system stack 136 words
                                Tasks: Move(3,nWait 7,0.0%,135) HEAT(2,nWait 6,0.2%,129) CanAsync(5,nWait 4,0.0%,55) CanRecv(3,nWait 1,0.0%,71) CanClock(5,nWait 1,0.0%,59) MAIN(1,running,78.1%,433) IDLE(0,ready,0.0%,40) AIN(2,nWait 2,21.6%,112), total 100.0%
                                Owned mutexes:
                                Last reset 00:01:11 ago, cause: power up
                                Last software reset data not available
                                Driver 0: pos 0, 225.0 steps/mm, steps req 0 done 0
                                Moves scheduled 0, completed 0, in progress 0, hiccups 0, segs 0, step errors 0, maxLate 0 maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 0.00
                                Peak sync jitter 1/5, peak Rx sync delay 208, resyncs 0/0, no timer interrupt scheduled
                                VIN voltage: min 24.2, current 24.2, max 24.2
                                MCU temperature: min 24.3C, current 24.6C, max 24.8C
                                Last sensors broadcast 0x00000001 found 1 162 ticks ago, 0 ordering errs, loop time 0
                                CAN messages queued 1145, send timeouts 0, received 648, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                                We use 2 diferrent drivers but we had the same problem with both, right now we are using a DM556T form stepperonline.
                                https://www.omc-stepperonline.com/download/DM556T_V4.0.pdf
                                If we connect the stepper motor to other driver, that is connected to the main board, it works, but in a driver connected to the expasion board I can not make it work.
                                We check all of this
                                Both boards has the same firmware version.
                                There is can comunication.
                                The wires are properly connected ( we try both +signals, and -signals just in case)
                                We try in M569, diferents timmings.
                                T2.5:2.5:5.0
                                T5:5:10:10
                                even T4:4:4:4
                                If we send M569 P45.0
                                Driver 45.0 runs in reverse, active low enable, step timing 5.0:5.7:10.7:11.0us
                                it gives this back with the T in 5:5:10:10
                                We dont have the enable pin connected.
                                I'm dont know what else to look for, or to change.
                                We even create a new config file but I can not make it work.
                                I hope you can help me
                                Best Alvaro
                                Phaedruxundefined undefined dc42undefined 3 Replies Last reply 10 Jun 2024, 18:39 Reply Quote 0
                                  Phaedrux Moderator @Makergal3D
                                  @Makergal3D Can you send M98 P"config.g" and report the result?
                                    @Makergal3D The 6XD and 1XD have different wiring schemes, and have different ways of enabling the drive. Please post a picture showing how the drive is wired at both ends.
                                      dc42 administrators @Makergal3D
                                      this is my config.g
                                      G4 S2
                                      M569 P0.0 T1:1:2:0
                                      M569 P0.1 T1:1:2:0
                                      M569 P0.2 T1:1:2:0
                                      M569 P0.3 T1:1:2:0
                                      M569 P0.4 T1:1:2:0
                                      M569 P0.5 T1:1:2:0
                                      M570 H0 P10 T15
                                      M302 P1
                                      My 122
                                      m122
                                      Static ram: 153624
                                      Owned mutexes:
                                      Error status: 0x00
                                      Aux0 errors 0,0,0
                                      Driver 0: ok
                                      Driver 1: ok
                                      Driver 2: ok
                                      Driver 3: ok
                                      Driver 4: ok
                                      Driver 5: ok
                                      === Storage ===
                                      === DDARing 0 ===
                                      === DDARing 1 ===
                                      === CAN ===
                                      === Network ===
                                      = Ethernet =
                                      M122 B45
                                      Owned mutexes:
                                      T2.5:2.5:5.0
                                      T5:5:10:10
                                      even T4:4:4:4
                                      Best Alvaro
                                      Did you select tool 0 before you tried to extrude?
