    Puzzled by Z0 position and first layer print
    1.9k
    • stephencundefined
      stephenc
      here you go. Also for some reason S3D keep inserting M106 and I don't know how to tell it not to do that…
      G90
      M83
      M106 S0
      M104 S205 T0
      M109 S205 T0
      G10 P0 R160 S205
      G10 P1 R160 S205
      G90 ; set absolute
      G1 X0 Y119 F9000 ; move head to far left bed for purging
      G1 F1500 ; set feedrate
      G1 Z0.24 ; drop z to printing 1st layer height
      G1 X100 E8 ; purge 8mm filament on to opposite edge of bed while running 100mm toward T0 parking position.
      T1
      G90 ; set absolute
      G1 X0 Y0 F9000 ; move head to far right bed for purging
      G1 X100 E8 ; purge 8mm filament on to edge of bed while running 100mm toward T1 parking position.
      G1 E-1.4000 F3600
      G1 Z0.240 F1002
      ; process T0 left
      ; layer 1, Z = 0.240
      T0
      ; tool H0.240 W0.312
      ; skirt
      G1 X24.351 Y39.633 F12000
      G1 E1.3500 F1080
      G1 X25.984 Y38.720 E0.0582 F1200
      G1 X25.993 Y38.716 E0.0003
      G1 X27.245 Y38.222 E0.0419
      G1 X27.254 Y38.219 E0.0003
      G1 X28.786 Y37.839 E0.0491
      G1 X28.791 Y37.838 E0.0002
      G1 X29.474 Y37.718 E0.0216
      G1 X29.480 Y37.717 E0.0002
      G1 X35.167 Y37.117 E0.1780
      G1 X42.982 Y36.127 E0.2453
      G1 X48.168 Y35.362 E0.1632
      G1 X57.263 Y33.857 E0.2870
      G1 X57.265 Y33.856 E0.0001
      G1 X57.519 Y33.821 E0.0080
      G1 X57.520 Y33.821 E0.0001
      G1 X59.717 Y33.571 E0.0688
      G1 X59.719 Y33.571 E0.0001
      G1 X59.941 Y33.551 E0.0070
      G1 X59.943 Y33.550 E0.0001
      G1 X61.825 Y33.421 E0.0587
      G1 X61.826 Y33.421 E0.0001
      G1 X62.043 Y33.410 E0.0068
      G1 X62.045 Y33.410 E0.0001
      G1 X64.320 Y33.352 E0.0708
      Stephen
      https://github.com/stephenci/ZideX
        1. Do you have any tool change files (tpre0, tpost0, tfree0 etc.), and if so what do you have in them?
        2. Is this an IDEX machine?
        3. Which firmware version are you running?
        • botundefined
          bot
          Are you setting the Z height with the paper when the printer is heated up or not? Heat can greatly affect the Z height, depending on printer setup and construction material.
          *not actually a robot
          • stephencundefined
            stephenc
            Yes I have a slightly different idex build. Nothing fancy on my tpre and tpost just regular park head to far end of arm and M116. Picture below for reference as you can see I actually have been printing for a while with T0 only and no first layer problem Now that I have finished installing T1 and tried dual printing, I get that first layer issue. I'm on frmware 19. Something I forgot will check later tonight
            Stephen
            • stephencundefined
              stephenc
              Firmware version 1.19.2
              My tfree0.g
              G90
              G1 X127 F12000
              My tfree1.g
              G90
              G1 X132.2 F12000
              Stephen
                Please upgrade to firmware 1.19.2. Also, to work around a known issue that is fixed in firmware 1.20, please add one M400 command right at the start of every tool change file that includes movement, and another at the end.
                  deckingman
                  @stephenc.
                  In another thread you mention that you have this in the start code of S3D.
                  G10 P0 R160 S200
                  G10 P1 R160 S200
                  From the wiki, it states:
                  "Remember that any parameter that you don't specify will automatically be set to the last value for that parameter. That usually means that you want explicitly to set Z0.0…................"
                  So, I'm just wondering if it's those G10 commands in your start gcode that are applying an offset.
                  HTH
                    @deckingman:
                    @stephenc.
                    G10 P0 R160 S200
                    G10 P1 R160 S200
                    HTH
                    Those commands should leave the Z offset of each tool alone, so I don't think that's likely to be the problem. The tool offsets default to zero if they are never set.
                    • stephencundefined
                      stephenc
                      in my config I have G31 set as follow for z offset after probing which works perfectly when I have T0 printing only
                      M574 Z0 S0 ; Define active low and unused microswitches
                      M574 X1 U1 Y1 S1 ; Define active high microswitches
                      M558 P6 X0 Y0 Z1 H5 F120 T12000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                      G31 P600 X0 Y0 Z0.148 ; Set Z probe trigger value, offset and trigger height
                      Stephen
                      • stephencundefined
                        stephenc
                        went back and reviewed my Drives section (posted below) in config.g
                        do I need to do this for my 2nd Z?
                        Z16:16 ; for microstepping
                        Z800:800 ; for step per mm
                        Z800:800 ; for motor current
                        and so on?
                        M569 P0 S0 ; Drive 0 goes forwards X
                        M569 P1 S0 ; Drive 1 goes forwards Y
                        M569 P2 S1 ; Drive 2 goes forwards Z
                        M569 P3 S0 ; Drive 3 goes forwards extruder T0
                        M569 P4 S0 ; Drive 4 goes forwards extruder T1
                        M569 P5 S1 ; Drive 5 goes forwards Uz
                        M569 P6 S1 ; Drive 6 goes forwards Ux
                        M350 X16 U16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
                        M92 X80 U80 Y53.33 Z800 E830:415 ; Set steps per mm
                        M566 X2000 U2000 Y2000 Z60 E1500:1500 ; Set maximum instantaneous speed changes (mm/min)
                        M203 X15000 U15000 Y15000 Z180 E6000:6000 ; Set maximum speeds (mm/min)
                        M201 X2500 U2500 Y2500 Z250 E1000:1000 ; Set accelerations (mm/s^2)
                        M906 X950 U950 Y950 Z800 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        Stephen
                        • stephencundefined
                          stephenc
                          can't remember if I've posted this video here… but this is how I home the 2 towers. After this homing, I manually confirm the two heads when move to same spot they both have the same distance between nozzle to top of bed surface. When printing, T0 (the one on the left and is the primary extruder) would print as expected in the correct layer height. But, T1 is problematic for some odd reason it appear to dive more in Z resulting the nozzle touching the bed surface perfectly thus nothing is extruding resulting in backpressure...
                          it's almost as if my G31 below as defined in my config.g is only applying to the left tower only...
                          https://youtu.be/PqQjZGIJ1rw
                          Stephen
                            @stephenc:
                            and so on?
                            No; but your M906 and M350 commands must come after the M584 command, so that they are applied to both the Z drivers.
                            Have you added M400 commands to your tool change files as per my previous response?
                            • stephencundefined
                              stephenc
                              yes I did add M400 though it doesn't appear to have any impact
                              my M584 is way up there under "general preferences" in the beginning of my config.g so both M906 and M350 have been placed after. or are you suggesting reversing this order?
                              Stephen
                                The order you have is correct: M584 early, M350 and M906 later.
                                • stephencundefined
                                  stephenc
                                  in a very strange work around. I actually managed to get it to work. both print head print at the correct first layer now and more importantly same height
                                  since my G31 has z offset of 0.15 all I did were:
                                  • update my homez.g after T1 touches FSR instead of it goes up 5mm i changed it to 5.15mm ( I kept T0 go up at 5mm)
                                  • After homez.g finish running, I ended up with Z5.30. now if I print this way I will end up with the issue I started this post with. so I went to console and did G92 Z5.15
                                  then problem solved although this seems like a band aid solution…
                                  Stephen
