DWC 3.4.5 gcode uploading via LAN error
once again I have encoutered simmilar obstacle.
I have several machines on Duet 6HC, running firmware 3.4.5 (2022-11-30), and they were working perfectly until few days ago.
They are connected via LAN, through a router and 3 switches.
When I try to upload a gcode (20-170MB large) it loses connection and tries to reconnect.
This happens on all our machines.
We tried diffrent browsers (Firefox, Brave) and 3 diffrent computers (Win10, Mint and Win7).
On Win7 via wifi 2.4gh it works completly normally and fine.
Just via LAN, I can't upload any gcode. It seems like a software / network issue.
Please find one of my M122 below, but I don't think it could be of any help...I know my sd card could be faster, but... it just worked fine a few days ago?
M122
RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (standalone mode)
Board ID: 08DJM-9P63L-DJMSS-6JTDJ-3SN6T-9SHMB
Used output buffers: 3 of 40 (40 max)
Static ram: 152760
Dynamic ram: 96920 of which 0 recycled
Never used RAM 97296, free system stack 114 words
Tasks: NETWORK(ready,29.2%,194) ETHERNET(notifyWait,0.3%,392) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,245) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,326) CanClock(delaying,0.0%,339) TMC(notifyWait,8.1%,57) MAIN(running,62.2%,1101) IDLE(ready,0.1%,30), total 100.0%
Owned mutexes:
Last reset 341:58:26 ago, cause: power up
Last software reset details not available
Error status: 0x04
Aux0 errors 0,0,0
Step timer max interval 153
MCU temperature: min 57.5, current 58.4, max 59.0
Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/230/184, gc cycles 0
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a, mspos 408, reads 24600, writes 0 timeouts 0
Driver 1: standstill, SG min n/a, mspos 584, reads 24600, writes 0 timeouts 0
Driver 2: standstill, SG min n/a, mspos 1000, reads 24600, writes 0 timeouts 0
Driver 3: standstill, SG min n/a, mspos 8, reads 24599, writes 0 timeouts 0
Driver 4: standstill, SG min n/a, mspos 8, reads 24599, writes 0 timeouts 0
Driver 5: standstill, SG min n/a, mspos 520, reads 24599, writes 0 timeouts 0
Date/time: 2023-08-18 20:38:02
Slowest loop: 378.93ms; fastest: 0.05ms
=== Storage ===
Free file entries: 9
SD card longest read time 3.4ms, write time 119.7ms, max retries 0
DMs created 125, segments created 35, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
=== MainDDARing ===
Scheduled moves 73077, completed 73077, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty
=== CAN ===
Messages queued 14673, received 32605, lost 0, boc 0
Longest wait 0ms for reply type 0, peak Tx sync delay 263, free buffers 50 (min 50), ts 8152/8152/0
Tx timeouts 0,0,0,0,0,0
=== Network ===
Slowest loop: 2739.99ms; fastest: 0.03ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
HTTP sessions: 1 of 8
= Ethernet =
State: active
Error counts: 0 0 0 0 0 0
=== Multicast handler ===
Responder is inactive, messages received 0, responses 0Best Regards,
Paul -
@paul12345 said in DWC 3.4.5 gcode uploading via LAN error:
What exactly do you see when this happens? Is there an error message?
Are you familiar with Wireshark? Could you capture a trace while uploading a file that fails?
One other thing you can try in the meantime is update to 3.4.6.
And if possible, try a new SD card. It may be failing. At the very least, have a backup of your config files. -
I don't think that 10 microsd cards could failed at once. But thanks for suggestion.
We've reviewed the wireshark capture and would like to see if the problem is still present on 3.4.6
Dear @Phaedrux,
I've just updated firmware on one Duet3D and there is no change. -
Are you able to test 3.5 RC1?
@Phaedrux I did it and there is still no change. I think it is on the side of our network, perhaps router.
However on the 3.4.6 the computer with Win7 couldn't even start the upload, it was just freezing on 0%.
The 3.5 RC1 works perfectly on Win7 comp, thank youI also get "Error in start-up file macro line 47: Response timeout: CAN addr 121 req type 6057, RID=5" on few occasions, but TB works fine.
If you don't already have a G4 S5 delay near the start of your config.g you should add one to give all boards time to startup before the configuration is executed.
undefined paul12345 referenced this topic
