    WiFi disconnect errors
    79
    11.9k
    • k3lagundefined
      k3lag
      @zlowred:
      I've replaced my Apple router with Google WiFi today, and it still disconnects, so I don't think it is related to particular router model.
      If it is router related I wouldn't necessarily expect it be limited to a single brand but it could be related to a particular WiFi chipset or chipset family. It's hard to say without a fair bit of data.
      • KeeganBundefined
        KeeganB
        I haven't updated to the newer firmwares yet b/c this current setup has been working so well for me compared to really horrible results previously. BUT over the past few days I have started getting some disconnects an also getting locked out. It is still really good compared the past, with only probably 4-5 disconnects over the past 3 days. Here is my latest M122 immediately following a disconnect. I will upgrade the firmwares after this current print.
        SENDING:M122
        Used output buffers: 2 of 32 (11 max)
        RepRapFirmware for Duet WiFi version 1.20beta7 running on Duet WiFi 1.0
        Board ID: 08DDM-9FAM2-LW4SD-6JTF0-3S86N-TLWZX
        Static ram used: 15472
        Dynamic ram used: 99192
        Recycled dynamic ram: 4120
        Stack ram used: 3992 current, 9144 maximum
        Never used ram: 3144
        Last reset 04:34:43 ago, cause: power up
        Last software reset reason: User, spinning module GCodes, available RAM 7296 bytes (slot 3)
        Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
        Error status: 0
        [ERROR] Error status: 0
        Free file entries: 9
        SD card longest block write time: 42.8ms
        MCU temperature: min 23.3, current 35.1, max 36.0
        Supply voltage: min 12.2, current 12.6, max 12.9, under voltage events: 0, over voltage events: 0
        Driver 0: ok
        Driver 1: ok
        Driver 2: open-load-B
        Driver 3: ok
        Driver 4: standstill
        Date/time: 2017-11-20 22:00:32
        Slowest main loop (seconds): 0.080215; fastest: 0.000041
        MaxReps: 5, StepErrors: 0, FreeDm: 136, MinFreeDm 120, MaxWait: 2289273250ms, Underruns: 0, 0
        Scheduled moves: 221848, completed moves: 221818
        Bed compensation in use: none
        Bed probe heights: -0.162 -0.151 -0.081 -0.058 -0.041
        Bed heater = 0, chamber heater = -1
        Heater 0 is on, I-accum = 0.3
        Heater 1 is on, I-accum = 0.5
        Segments left: 1
        Movement lock held by file
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is doing "G1 X0.401 Y8.421 E0.0067" in state(s) 0
        serial is ready with "M122" in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        Network state is running
        WiFi firmware version 1.20b8-nosleep
        WiFi MAC address 5c:cf:7f:ef:51:6f
        WiFi Vcc 3.38, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 29144
        WiFi IP address 10.0.1.161
        WiFi signal strength -37dBm, reconnections 4, sleep mode none
        HTTP sessions: 1 of 8
        Socket states:  0 0 0 0 0 0 0 0
        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        Artemis
        Rostock Max v2
        Orion
          It's interesting to see that you had 4 successful reconnections.
          • k3lagundefined
            k3lag
            I've now been on my new WiFi network for 3 days and I have had no unexpected disconnects. I can reconnect immediately after any expected disconnects (laptop goes to sleep or I close my iPad) and the response is very quick.
            • ukflyerundefined
              ukflyer
              Been following this thread for a while now.
              What is the current consensus for stable WiFi ?
              I have updated to the latest stable firmware and server releases. My printer is 300mm from the WiFi router and there are no other WiFi networks available and yet the network connection is currently dropping within seconds of starting the printer up.
              I have managed to start one print in the last 2 days before the WiFi connection dropped and that ran to completion so it can only be an issue with the WiFi module.
              Really beginning to wish I had paid the extra for an ethernet electronics board ๐Ÿ˜ž
                @ukflyer:
                โ€ฆ
                Please work through https://duet3d.com/wiki/WiFi_disconnections_and_AJAX_timeout_errors first, in particular check the signal strength.
                If the problem isn't signal strength, then the reports I have are that RepRapFirmware 1.20beta11 with DuetWiFiServer 1.20beta10 are more stable than the 1.19 versions in the stable release folder. So please try them. We have further work under way on DuetWiFiServer which we hope will resolve a remaining issue that some users experience.
                • ukflyerundefined
                  ukflyer
                  Okay I have the recommended Beta's installed -
                  Firmware Name: RepRapFirmware for Duet WiFi
                  Firmware Electronics: Duet WiFi 1.0
                  Firmware Version: 1.20beta11 (2017-11-28)
                  WiFi Server Version: 1.20b10
                  Web Interface Version: 1.19
                  And I have MacPronterface, connected via a USB cable, monitoring the WiFi debugging messages - fingers crossed.
                    Thanks, let us know how it goes.
                    • ukflyerundefined
                      ukflyer
                      Suffered a disconnect during a print but print still running
                      Output of M122
                      m122
                      SENDING:M122
                      Used output buffers: 2 of 32 (14 max)
                      RepRapFirmware for Duet WiFi version 1.20beta11 running on Duet WiFi 1.0
                      Board ID: 08DGM-95BNL-MGPSN-6JKDJ-3S46N-1LWHW
                      Static ram used: 15488
                      Dynamic ram used: 97768
                      Recycled dynamiWiFi:
                      c ram: 1432
                      Stack ram used: 4328 current, 9212 maximum
                      NeWiFi: LINK
                      ver used ram: 7172
                      Last reset 18:45:25 ago, cause: power up
                      Last software reset reason: User, spinning module GCodes, available RAM 7400 bytes (slot 2)
                      Software reset code 0x0003, HFSR 0x00000000, CFWiFi: xmit: 0
                      Error status: 1
                      [ERROR] Error status: 1
                      Free file entrieWiFi: recv: 0
                      s: 9
                      SD card longest block write time: 347.2ms
                      MCU temperature: min 36.8, current 42.3, max 42.6
                      Supply voltaWiFi: fw: 0
                      ge: min 11.5, current 12.5, max 13.1, under voltage events: 1, over voltage events: 0
                      Driver 0: ok
                      Driver 1: ok
                      Driver 2: ok
                      DriverWiFi: drop: 0
                      3: standstill
                      Date/time: 2017-12-03 15:10:06
                      Slowest main loop (secondsWiFi: chkerr: 0
                      ๐Ÿ˜ž 0.349178; fastest: 0.000040
                      MaxReps: 5, StepErrors: 0, FreeDm: 163, MinFreeDm 137, MaxWait: 50818999ms, Underruns: 11, 1
                      Scheduled moves: 157311, completed moves: 157281
                      Bed compensation in use: mesh
                      Bed probe heights: 0.000 0.000 0.000 0.0WiFi: lenerr: 0
                      00 0.000
                      Bed heater = 0, chamber hWiFi: memerr: 0
                      eater = -1
                      Heater 0 is on, I-accum = 0.0
                      Heater 1 is on, I-accum = 0.4
                      Segments left: 1
                      Movement lock held by null
                      telnet is idle WiFi: rterr: 0
                      in state(s) 0
                      file is doing "G1 X47.277 Y63.098 F9000" in state(s) 0
                      serial isWiFi: proterr: 0
                      Network sWiFi: opterr: 0
                      tate is running
                      WiFi: err: 0
                      WiFi firmware version 1.20b10
                      WiFi MAC address a0:20:a6:2f:bb:fe
                      WiFi Vcc 3.43, reset reason Turned on by main processor
                      WiFi flash size 4194304, freWiFi: cachehit: 0
                      e heap 28904
                      WiFi IP address 192.168.1.15
                      WiFi signal strength -27dBm, reconnections 0, sleep mode modem
                      Socket statWiFi:
                      es: 0 0 0 0 0 0 0 0
                      WiFi: ETHARP
                      WiFi: xmit: 4
                      WiFi: recv: 1637
                      WiFi: fw: 0
                      WiFi: drop: 1923
                      WiFi: chkerr: 0
                      WiFi: lenerr: 0
                      WiFi: memerr: 0
                      WiFi: rterr: 0
                      WiFi: proterr: 1923
                      WiFi: opterr: 0
                      WiFi: err: 0
                      WiFi: cachehit: 24039
                      WiFi:
                      WiFi: IP
                      WiFi: xmit: 24104
                      WiFi: recv: 36990
                      WiFi: fw: 0
                      WiFi: drop: 0
                      WiFi: chkerr: 0
                      WiFi: lenerr: 0
                      WiFi: memerr: 0
                      WiFi: rterr: 0
                      WiFi: proterr: 0
                      WiFi: opterr: 0
                      WiFi: err: 0
                      WiFi: cachehit: 0
                      WiFi:
                      WiFi: IGMP
                      WiFi: xmit: 7
                      WiFi: recv: 39
                      WiFi: drop: 0
                      WiFi: chkerr: 0
                      WiFi: lenerr: 0
                      WiFi: memerr: 0
                      WiFi: proterr: 0
                      WiFi: rx_v1: 0
                      WiFi: rx_group: 0
                      WiFi: rx_genet 17033
                      WiFi: recv: 33948
                      WiFi: fw: 0
                      WiFi: drop: 0
                      WiFi: chkerr: 0
                      WiFi: lenerr: 0
                      WiFi: memerr: 0
                      WiFi: rterr: 0
                      WiFi: proterr: 0
                      WiFi: opterr: 0
                      WiFi: err: 0
                      WiFi: cachehit: 0
                        Are you able to reconnect?
                        • ukflyerundefined
                          ukflyer
                          Not without issuing an M552 S-1 & M552 S1.
                          The logs are being taken from MacPronterface which is connected via USB
                          • ukflyerundefined
                            ukflyer
                            If I had to guess I would say that it is almost as though the Web Server has shutdown rather than the WiFi connection.
                            Just started a print which is predicted to run for 2 hours plus so will keep an eye on it.
                            • BMMalundefined
                              BMMal
                              • A M122 diagnostic report produced when WiFi was connected
                              Used output buffers: 3 of 32 (17 max)
                              RepRapFirmware for Duet WiFi version 1.20beta11 running on Duet WiFi 1.0 + DueX5
                              Board ID: 08D6M-91AST-L23S4-7JTD8-3S86K-1PX1K
                              Dynamic ram used: 98920
                              Recycled dynamic ram: 280
                              Stack ram used: 1368 current, 9220 maximum
                              Never used ram: 7164
                              Last reset 01:51:24 ago, cause: software
                              Last software reset reason: User, spinning module GCodes, available RAM 3032 bytes (slot 0)
                              Error status: 2
                              Free file entries: 8
                              SD card longest block write time: 0.0ms
                              MCU temperature: min 28.0, current 28.2, max 28.7
                              Supply voltage: min 24.3, current 24.5, max 24.8, under voltage events: 0, over voltage events: 0
                              Driver 0: ok
                              Driver 1: ok
                              Driver 2: standstill
                              Driver 3: standstill
                              Driver 5: standstill
                              Driver 6: ok
                              Driver 7: standstill
                              Driver 8: standstill
                              Driver 9: standstill
                              Expansion motor(s) stall indication: no
                              Date/time: 2017-12-04 11:26:10
                              Slowest main loop (seconds): 0.119764; fastest: 0.000112
                              MaxReps: 7, StepErrors: 194, FreeDm: 215, MinFreeDm 159, MaxWait: 0ms, Underruns: 0, 0
                              Scheduled moves: 12230, completed moves: 12221
                              Heater 4 is on, I-accum = 0.4
                              Segments left: 1
                              file is doing "G1 X163.249 Y162.84 E0.01646" in state(s) 0
                              serial is idle in state(s) 0
                              WiFi MAC address a0:20:a6:16:e6:c6
                              WiFi Vcc 3.26, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 27952
                              WiFi IP address 10.0.0.115
                              WiFi signal strength -29dBm, reconnections 0, sleep mode modem
                              Socket states: 0 2 0 0 0 0 0 0
                              Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                              [[language]]
                              ```- The make and model of your WiFi router
                              **Asus RT AC56U**
                              - Does the problem occur mainly (or only) during printing, or does it occur equally frequently when the printer is idle?
                              **Both but more so when printing**
                              - When the problem occurs, are you able to reconnect by pressing the Connect button in DWC?
                              **Rarely. I have been issuing the wifi module reset command from Paneldue as a work around most of the time.**
                              - If you are unable to connect, are you still able to ping the IP address of the Duet WiFi?
                              **No. Timesout**
                              - Anything else that you think may be correlated with disconnections occurring
                              **It seems that mine is more likely to lose connection if I leave the focus on the Web Control tab in Chrome. I don't know if this is because fewer things are updated when Web Control is not the focus?**
                              Duet Ethernet - Most likely the most recent Edge firmware
                              Duet X5
                              7" Panel Due V2
                              Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
                              • KeeganBundefined
                                KeeganB
                                I get these all the time, but here is a recent longer log both the wifi debugging output and then the M122 from a few mins after the final disconnect.
                                [c]WiFi: lwip: ../src/src/core/ipv4/ip.c(808) p->ref == 1
                                WiFi: lwip: ../src/src/core/ipv4/ip.c(652) p->ref == 1
                                WiFi: state: 5 -> 2 (7c0)
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi reported error: Lost connection, auto reconnecting
                                WiFi: reconnect
                                WiFi: state: 2 -> 0 (0)
                                WiFi: scandone
                                WiFi: state: 0 -> 2 (b0)
                                WiFi: state: 2 -> 3 (0)
                                WiFi: state: 3 -> 5 (10)
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: connected with Virus 2.0, channel 4
                                WiFi: dhcp client startโ€ฆ
                                WiFi reported error: Auto reconnect succeeded
                                WiFi: ip:10.0.1.161,mask:255.255.255.0,gw:10.0.1.1
                                WiFi: pm open,type:2 0
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: dhcp client start...
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: rm 0
                                WiFi: pm close 7
                                WiFi: reconnect
                                WiFi: scandone
                                WiFi: add 0
                                WiFi: aid 3
                                WiFi: cnt
                                WiFi:
                                WiFi: pm open,type:2 0[/c]
                                M122:
                                [c]>>> M122
                                SENDING:M122
                                Used output buffers: 3 of 32 (19 max)
                                Dynamic ram used: 97952
                                c ram: 1248
                                Stack ram used: 4328 current, 9364 maximum
                                Never used ram: 7020
                                Last reset 142:06:05 ago, cause: power up
                                Software reset code 0x0003, HFSR 0x00000000, CWiFi: LINK
                                FSR 0x00000000, ICSR 0x00400000, BFAR 0xe000edWiFi: xmit: 0
                                38, SP 0xffffffff
                                Error status: 1
                                SD card longest block write time: 35.2ms
                                MCU temperature: min 29.3, current 34.3, max 35.4
                                Supply voltaWiFi: recv: 0
                                ge: min 12.2, current 12.5, max 12.9, under voltage events: 4, over voltage evenWiFi: fw: 0
                                ts: 0
                                Driver 0: ok
                                Driver 1: ok
                                Driver 2: ok
                                Driver 3: ok
                                Date/time: 2017-12-04 21:25:50
                                Slowest main loop (seconds): 0.115WiFi: drop: 0
                                319; fastest: 0.000041
                                MaxReps: 5, StepErrors: 0, FreeDm: 127, MinFreeDm 120, MaxWait: 31071115ms, Underruns: 0, 0
                                Scheduled moves: 446029, completed moves: 445999
                                Bed probe heights: -0.053 -0.047 0.022 0.040 -0.0WiFi: chkerr: 0
                                10
                                Bed heater = 0, chamber heater WiFi: lenerr: 0
                                = -1
                                Segments left: 1
                                telnet is idle in staWiFi: memerr: 0
                                te(s) 0
                                file is doing "G1 X-4.645 Y-19.013 E0.14745 F1787.3" in state(s) 0
                                NetWiFi: rterr: 0
                                WiFi moduWiFi: proterr: 0
                                le is connected to access point
                                WiFi flash size 419430WiFi: opterr: 0
                                4, free heap 28520
                                WiFi signal stWiFi: err: 0
                                rength -46dBm, reconnections 31, sleep mode modem
                                WiFi: cachehit: 0
                                WiFi:
                                WiFi: ETHARP
                                WiFi: xmit: 97
                                WiFi: recv: 420
                                WiFi: fw: 0
                                WiFi: drop: 7246
                                WiFi: chkerr: 0
                                WiFi: lenerr: 0
                                WiFi: memerr: 0
                                WiFi: rterr: 0
                                WiFi: proterr: 7246
                                WiFi: opterr: 0
                                WiFi: err: 0
                                WiFi: cachehit: 48603
                                WiFi:
                                WiFi: IP
                                WiFi: xmit: 48776
                                WiFi: recv: 65007
                                WiFi: fw: 0
                                WiFi: drop: 0
                                WiFi: chkerr: 0
                                WiFi: lenerr: 0
                                WiFi: memerr: 0
                                WiFi: rterr: 0
                                WiFi: proterr: 0
                                WiFi: opterr: 0
                                WiFi: err: 0
                                WiFi: cachehit: 0
                                WiFi:
                                WiFi: IGMP
                                WiFi: xmit: 76
                                WiFi: recv: 168
                                WiFi: drop: 0
                                WiFi: chkerr: 0
                                WiFi: lenerr: 0
                                WiFi: memerr: 0
                                WiFi: proterr: 0
                                WiFi: rx_v1: 0
                                WiFi: rx_group: 0
                                WiFi: rx_ge: 21563
                                WiFi: recv: 61223
                                WiFi: fw: 0
                                WiFi: drop: 0
                                WiFi: chkerr: 0
                                WiFi: lenerr: 0
                                WiFi: memerr: 0
                                WiFi: rterr: 0
                                WiFi: proterr: 0
                                WiFi: opterr: 0
                                WiFi: err: 0
                                WiFi: cachehit: 0[/c]
                                Artemis
                                Rostock Max v2
                                Orion
                                  Thanks. It looks like we have two issues, possibly related. We'll have a new build of DuetWiFiServer soon which may resolve one or both of them.
                                    Hi all,
                                    Please can anyone who is running main firmware 1.20beta10 1.20beta11 and DuetWiFiServer 1.20beta10 and still experiencing WiFi disconnection problems try DuetWiFiServer 1.20b11, available here https://www.dropbox.com/s/ttoa6d9l9d0lrqe/DuetWiFiServer-1.20b11.bin?dl=1.
                                    As before, if possible connect a PC running a host program via USB too and send M111 S1 P14 to enable WiFi module debugging.
                                    • darookeeundefined
                                      darookee
                                      After installing DuetWifiServer 1.20b11 I could not connect to the Duet over Wifi and got these messages in Repetier-Host:
                                      13:24:06.852 : WiFi: Fatal exception (0):
                                      13:24:06.864 : WiFi: epc1=0x40100004, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
                                      13:24:06.868 : WiFi: Fatal exception (0):
                                      13:24:06.880 : WiFi: epc1=0x40100004, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
                                      13:24:06.882 : WiFi: Fatal exception (0):
                                      13:24:06.895 : WiFi: epc1=0x40100004, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
                                      Reverting to DuetWifiServer 1.20b10 for nowโ€ฆ
                                      I'm running "Firmware Version 1.20beta11 (2017-11-28)", could this be the issue? I did realize too late that you said '...running 1.20beta10...' ๐Ÿ˜
                                      • KeeganBundefined
                                        KeeganB
                                        @dc42:
                                        Hi all,
                                        I can test this tonight. Thanks.
                                        Artemis
                                        Rostock Max v2
                                        Orion
                                          @darookee, thanks for your report. I meant DuetWiFiFirmware 1.20beta11, not beta 10.
                                          Please can you try installing the new DuetWiFiserver file twice (i.e. send M997 S1 from USB or PanelDue after installing it the first time), in case the problem is the same as the one we had earlier.
                                          EDIT - I am about to generate a slightly modified version of the new DWS. Please wait for that version.
                                            Please try this version https://www.dropbox.com/s/u7vpp2wg4rlqs8l/DuetWiFiServer.bin?dl=1 installing it twice if necessary.
                                            EDIT: Scratch that, I need to do some more work on it.
