    DuetLapse3
    Third-party software
    20
    296
    30.1k
    • stuartofmtundefined
      stuartofmt
      This post is deleted!
        stuartofmt @JonasBaleine
        @JonasBaleine
        Before we get too far along - I've rebuilt the blugin against the 3.4.6 release (attached at end).
        In theory there should not have been a difference between 3.4.5 and 3.4.6 from a plugin perspective but ...
        Regarding the version numbers. In the beta / rc versions I require a complete match because there can be some sensitivity. I was not thinking when I set the version number in 3.4.5. It should have been 3.4 which will match any release in that series. I've corrected this in the version above (The only change to DuetLapse3 I made).
        Regarding the start issue. The fact that it shows as only partially started when you run it from the terminal is, I think, to be expected based on the underlying plugin framework. What we should focus on is what happens when installed as a plugin and run as a plugin.
        From the logfile I see
        -duet = c3po.local . The connection to the printer is successful, so that part is good.
        For -weburl1 = http://c3po.local:8081/0/stream its hard to tell because its likely not tried to capture any images.
        If the problem persistes with the above build .....
        1. From a browser on the pi does http://c3po.local:8081/0/stream display your video feed?
        2. The logfile is only partial - can you run it with -verbose as that will capture most errors seen by the program.
        3. In a console: run the following command before trying to start the plugin and monitor for errors. sudo SYSTEMD_LESS=RXMK /usr/bin/journalctl -f
        [DuetLapse3-3.4.6--5.2.2.1.zip.txt]
        JonasBaleineundefined 1 Reply Last reply Reply Quote 0
        • JonasBaleineundefined
          JonasBaleine @stuartofmt
          @stuartofmt Hi, I downloaded the new version you provided and installed it. When I start it, it says "started" for a few seconds, then "partially started".
          To answer your questions:
          1. Yes, http://c3po.local:8081/0/stream display my video feed, on the pi, on my pc, in the Webcam tab of the DWC.
          2. -verbose is already in my DuetLapse3.config.txt file. Starting the plugin does not seem to create a startup.log file.
          3. When I run the command in the terminal and start the plugin, I get this result: Errors.txt saying PermissionError: [Errno 13] Permission denied: '/opt/dsf/sd/DuetLapse3/C3PO/c3po-local/startup.log'
          I tried stopping Motion Webcam Server, but it did not solve the issue.
          I tried adding my Raspberry Pi password to the config file with -password, but it did not solve the issue.
          Thanks again, I appreciate the help.
          stuartofmtundefined 1 Reply Last reply Reply Quote 0
            @JonasBaleine said in DuetLapse3:
            Thanks for the quick turnaround. This is looking like a permissions issue as opposed to a code issue. Lets see ...
            This makes sense given the problems below.
            1. -verbose is already in my DuetLapse3.config.txt file. Starting the plugin does not seem to create a startup.log file.
            That seems wierd - the location for the config file should be /opt/dsf/sd/sys/DuetLapse3/DuetLapse3.config. Using DWC - Did you create a folder off your sys directory called DuetLapse3 and place your config file there ?
            This is set by -basedir = /opt/dsf/sd/DuetLapse3. If you have those folders/files set up - this error is possibly related to the permission issue described below.
            1. When I run the command in the terminal and start the plugin, I get this result: Errors.txt saying PermissionError: [Errno 13] Permission denied: '/opt/dsf/sd/DuetLapse3/C3PO/c3po-local/startup.log'
            This looks to be a a permissions error. I dont know where the /assets/ ... path comes into it. Its certainly not in the DuetLapse3 code. The /assets folder does not even exist in my setup. It could be a temp folder and we are seeing it because of the error.
            All the files under /opt/dsf should be owned by dsf:dsf. I've seen several times now where the strange permissions were set when installing SBC using these instructions. https://docs.duet3d.com/User_manual/Machine_configuration/DSF_Other
            Take a look in /opt/dsf and confirm all the files / folders have the correct permissions.
            I've had to fix it by uninstalling the plugin, running the following, then reinstalling the plugin
            cd /opt/dsf
            sudo chown -R dsf:dsf *
            I've reported it and hopefully its something that can be fixed.
            The config file only requires a -password if you have set a password for your printer and is only used for connecting with the printer. Its not used for the file / folder structure.
              @stuartofmt Hi, thanks for the quick reply. Yes, I did create a folder in System and then created the config file inside it.
              By trying a few things, I realised that my Pi failed to fetch updates with sudo apt update, so I reflashed the Pi, following the steps https://docs.duet3d.com/en/User_manual/Machine_configuration/SBC_setup again. Now it works when I start the plugin.
              Thanks for all your help, I really appreciate it.
                JonasBaleine
                Hi @stuartofmt, its me again. I have everything working properly now, but I am wondering if there is a way that DuetLapse3 would not automatically resume a print if I manually paused it or paused by a filament sensor? Thanks!
                  I cannot reply in full just now but the answer is yes. Take a look at the documentation. From memory you don't want to set - pause
                  What does your config file look like
                    @stuartofmt Here is my config DuetLapse3.config.txt. In the Info tab, I see pause as no. But when I pause a print with the Pause button from the Job/Status tab, the print automatically resumes if DuetLapse3 is started. In standby, it does not resume by itself.
                      Thanks! - I found a logic error I had introduced a while back when I was re-arranging code (aka a bug). Would you mind trying this? I've not had a chance to test it but it was a 2 line change - so should (fingers crossed) be OK.
                      DuetLapse3-3.4.6-test.zip.txt
                        @stuartofmt I haven't tried everything, but it seems to work. It no longer resumes the print on its own. Thanks again!
                        • jltxundefined
                          jltx
                          @stuartofmt I'm not sure if this is still working in 2025 but I'm trying to get it set up. I want to use the plug-in version. I'm on 3.5.4 but planning to move to 3.6 soon.
                          The documentation seems to be missing key info. The link to the plug-in instructions is broken. The general setup is good and I did that. The getting started goes through all kinds of options I need to set but doesn't say where until the very end, which caused me much confusion. Then it says create some configuration file but with what name and where does it go? sys directory? Do I need to make the directory user /opt/dsf/sd?
                          All the hardware, RPi and webcam, are working but I cannot get the sw configured because I can't tell where I am supposed to put anything. There are so many permutations I'm not sure which set I am supposed to follow vs a stand-alone. I am not a sw person so I am fumbling through this desperately with no success other than capturing a still frame from the cmd line. Any help appreciated.
                          osteracundefined 1 Reply Last reply Reply Quote 0
                          • osteracundefined
                            osterac @jltx
                            @jltx it works for me currently. I'll try and get some info for you later on.
                            Edit:
                            Just saw you wanted the plug-in version. I'm using standalone. If you want help with that though, I can help.
                            jltxundefined 1 Reply Last reply Reply Quote 0
                            • jltxundefined
                              jltx @osterac
                              @osterac I am willing to try it stand alone. Any help will likely get me unblocked. Thanks.
                              • osteracundefined
                                osterac @jltx
                                @jltx In the standalone there is no configuration file. I put the the program files in the home directory, within an FTP share, so that I can access the videos over FTP. You can also access them from a web browser. The configuration is done upon launch with command switches. This is what I use, it is for 2 cameras:
                                sudo python3 /home/pi/ftp/files/DuetLapse/DuetLapse3.py -duet 192.168.1.8 -minvideo 3 -maxvideo 12 -seconds 3 -detect none -dontwait -restart -camera1 stream -weburl1 http://cam.local:8081/101/stream -camera2 stream -weburl2 http://cam.local:8081/102/stream -basedir /home/pi/ftp/files/DuetLapse -standby -deletepics -verbose -keeplogs -port 8094 -extratime 2 -fps 30
                                This produces a maximum of 12 seconds of video (less if the print time is very short). If the print time is longer, the frame rate goes up instead of the duration of the video. At the end, there will be 2 seconds of a still image of the finished print. This is for a corexy printer, if you have a bedslinger you will need to have commands to center the bed for each snapshot, and you would probably want to do it between layers.
                                In order to run duetlapse at startup, I put the preceeding command in my "/etc/rc.local" file.
                                In order to automatically trigger duetlapse, you need to create 4 (ideally) .g files in your printers' system folder. I have it set up like this:
                                DuetLapse3Start.g
                                M291 P"DuetLapse3.start" S1 T5 ;Start DuetLapse3
                                DuetLapse3Pause.g
                                M291 P"DuetLapse3.pause" S1 T5 ;pause DuetLapse3
                                DuetLapse3Continue.g
                                M291 P"DuetLapse3.continue" S1 T5 ;resume DuetLapse3
                                DuetLapse3Stop.g
                                M291 P"DuetLapse3.completed" S1 T5 ;Stop DuetLapse3
                                G4 S10   ;pause for 10 seconds
                                in my pause.g file, I add this line:
                                M98 P"DuetLapse3pause.g" ;Pause DuetLapse 3
                                This pauses the timelapse when you pause the print.
                                In my resume.g file I add this line:
                                M98 P"DuetLapse3continue.g" ;resume timelapse
                                This resumes the timelapse when I resume a print.
                                In order to trigger the timelapse upon the start of a print, I need to add commands to my slicer's start and end gcode.
                                To the start gcode:
                                M98 P"DuetLapse3Start.g" ;start timelapse
                                Place this after your command to turn on LED Lighting, if you have it.
                                To the end gcode:
                                M98 P"DuetLapse3Stop.g" ;Stop Timelapse
                                M400	;Wait for timelapse to stop
                                Place this line before your command to turn off your LED lighting, if you have it.
                                That should about do it
                                • jltxundefined
                                  jltx @osterac
                                  @osterac Thanks. What firmware version are you on? The version of DeutLapse3 that I'm trying to set up for 3.5.4 has the M291 deprecated. But I can see what you did so I will try to adapt it.
                                    stuartofmt @jltx
                                    @jltx
                                    I have been "offline" for about 6 months and am just now restarting having rebuilt my system.
                                    For SBC the 3.5 version in github is the one you should be using. I'll push out a 3.6 version shortly (I don't think there will be any changes - but ...)
                                    There was one broken link in the documentation which I just fixed. This is likely the main info you are missing
                                    https://github.com/stuartofmt/DuetLapse3/blob/main/Documents/plugin installation guide.md
                                    The software grew in capability over time - so its important to start of simply and not be overwhelmed by too many options. See the examples here (they are for standalone but the config file examples are the same for the plugin version)
                                    https://github.com/stuartofmt/DuetLapse3/blob/main/Documents/DuetLapse3 Useage Examples.md
                                    The example and the fixed link should get you started. When testing - make sure you include -verbose so that errors and warnings can be seen.
                                    Once you have it basically configured and can use the plugin UI - you can then start tweaking configurations and doing "fancy stuff" with gcodes.
                                    Let me know if you get stuck.
                                    • jltxundefined
                                      jltx @stuartofmt
                                      @stuartofmt thank you! That was the missing information I needed. I have it installed and running. Now to test some gcode…
                                        stuartofmt @jltx
                                        @jltx
                                        • jltxundefined
                                          jltx @stuartofmt
                                          @stuartofmt Hmm, not sure if this is right but it pauses 2.7 seconds on every layer which is not going to work for me as it will ruin many prints. Got several msgqueue full pop-ups. After the print there are no images in /opt/dsf/sd/DuetLapse3/. The plug-in said deactivated, though it was working when I started. I did capture manually and the camera works. Idea where to debug?
                                            stuartofmt @jltx
                                            @jltx
                                            Lets have a look at your config file.
                                            Also - to be clear, you are running 3.5.4 SBC on Bookworm? Buster?
                                            Also - since there are no images being collected - there is something wrong - so please include a log file that was created with -verbose.
                                            The images are not created in that directory. See the info tab for the directory location. You should also be able to see them in the files tab.
                                            Its best to get basic operation working correctly before adding pauses and such.
