MPCNC Endstop G28 Issue
@ZPomeroy said in MPCNC Endstop G28 Issue:
M574 E0 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
M574 E1 S1 P"ystop"
M574 X1 S1 "x2stop"
M574 Y1 S1 "y2stop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstopWhere did you get this configuration, it's not correct at all.
https://docs.duet3d.com/User_manual/Reference/Gcodes#m574-set-endstop-configuration
Where are your endstops actually wired and which axis do they correspond to?
@Phaedrux I used the config tool to generate the config file. It's a dual end stop setup, where the end stops are on the trucks and triggered when homed. 1st is x axis. 2nd is on y axis. 3rd is on x2 axis. 4th on y2 axis. Ive labelled a photo so you can see where they are
In RRF you can only have one endstop per axis for homing. The firmware applies soft limits based on the axis length defined in M208.
If you're concerned about something causing lost steps and a potential crash you can reconfigure the homing endstops and your secondary endstops as an Estop trigger.
Which ports on the board are you trying to use for the endstops?
@Phaedrux Oh... I'm sure I've read about other people doing dual end stops with the duet? the reason for the 2 end stops on each axis is so that the machine automatically squares itself using the 2 end stops on each axis. I really want to make it work with the 2 so that it's completely square every time. If I remap the 2nd Endstops of each axis to a different stop will that work? Say if u used the z stop for x2 and one of the expansion slots for y2? I don't have a z stop as the router isn't connected to the board
Ah I misunderstood you. Yes you can use dual endstops for a single axis, but only for one end of travel or the other, not both. This also assumes you have dual motors on each axis. From your config it doesn't appear that that is the case?
See the example here: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling#axis-levelling-using-endstops
It's described for the Z axis, but it applies to all axis.
To use two endstops for a single axis you must use both pin names in the M574 command. Be sure to keep the order of the endstops the same as the order of the motors defined in M584. Again, assuming you have two motors per axis?
@Phaedrux I have dual motors. I don't know why the config came out like that. This is my current config for the motors and end stops:
I'll try playing around with the m574 command. any suggestions for the proper config given my current setup?
M569 P4 S1 ; physical drive 4 goes forwards
M584 X0:1 Y3:4 Z2 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X855 Y612 Z120 S0 ; set axis maxima; Endstops
M574 E0 S1 P"xstop". ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 E1 S1 P"x2stop" ; configure switch-type (e.g. microswitch) endstop for low end on X2 via pin x2stop
M574 X1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Y1 S1 P"y2stop" ; configure switch-type (e.g. microswitch) endstop for low end on Y2 via pin y2stop -
These are the endstop pin names
Endstop inputs Label Pin name X_STOP xstop Y_STOP ystop Z_STOP zstop E0_STOP e0stop E1_STOP e1stop
So I'd do something like...
M574 X1 S1 P"xstop+e0stop" M574 Y1 S1 P"ystop+e1stop"
X1 Y1 means the endstop is on the low end of travel.
P"pinname+pinname" means it will use both those endstops when you home the axis with a G1 H1 X move, etc for Y. the order of the pins needs to correspond to the order of the motors in M584. -
@Phaedrux Thank7you I really appreciate your help! Okay so I think I've set up the endstops correctly, but when I try to home all the axis just moves maybe +10 in X and Y and comes up with failed to enable endstops
This is what I have the endstops as:
M574 X1 S1 P"e0stop+e1stop" ; configure active-high endstops for low end on x via pins e0stop and e1stop
M574 Y1 S1 P"xstop+ystop" ; configure active-high endstops for low end on y via pins xstop and ystopAnd this is my Home All file:
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.3.16 on Mon Oct 09 2023 20:52:40 GMT+1100 (AEDT)
G91 ; relative positioning
G1 H1 X-860 Y-617 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-860 Y-617 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-125 F360 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
And you have them plugged into those ports on the board?
Can you please post your entire config.g as it is now?
Also please send M122 and M98 P"config.g" in the gcode console and report the responses.
Can you also confirm that the direction of rotation of the motors is correct? Move the head to the center while the printer is off. Then power on and send G92 X100 Y100, and then send a G1 X10 Y10. That should move the head away from the endstops (since they are at the low end)
@Phaedrux
I used the duet config website to generate this config so I'm not sure what all the errors in M98 are about? The G1 command moved everything towards the 0 point of each axis is that right? I currently have the motors set so that if I press X-50 it moves towards 0 and X+50 is away from 0. The endstops are on the truck carriages and should trigger when the axis reaches 0current config:
; Configuration file for Duet WiFi (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Mon Oct 09 2023 20:52:40 GMT+1100 (AEDT) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"MPCNC" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P4 S1 ; physical drive 4 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M584 X0:1 Y3:4 Z2 ; set drive mapping M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X855 Y612 Z120 S0 ; set axis maxima ; Endstops M574 X1 S1 P"e0stop+e1stop" ; configure active-high endstops for low end on x via pins e0stop and e1stop M574 Y1 S1 P"xstop+ystop" ; configure active-high endstops for low end on y via pins xstop and ystop ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M140 H-1 ; disable heated bed (overrides default heater mapping) ; Fans ; Tools M563 P0 D0 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
M122 report:
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.0 or 1.01
Board ID: 08DAM-999TL-MQ4S4-6JKDG-3S46M-TPH3Y
Used output buffers: 3 of 24 (19 max)
Static ram: 27980
Dynamic ram: 92908 of which 32 recycled
Exception stack ram used: 352
Never used ram: 9800
Tasks: NETWORK(ready,404) HEAT(blocked,1456) MAIN(running,1880) IDLE(ready,80)
Owned mutexes: WiFi(NETWORK)
Last reset 00:01:20 ago, cause: power up
Last software reset at 2023-10-14 15:57, reason: User, spinning module GCodes, available RAM 9680 bytes (slot 2)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 32.8, current 33.0, max 33.6
Supply voltage: min 12.8, current 12.9, max 13.0, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2023-10-14 16:56:14
Cache data hit count 135137405
Slowest loop: 151.62ms; fastest: 0.13ms
=== Storage ===
Free file entries: 10
SD card longest read time 2.0ms, write time 228.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 9, completed moves: 9, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 481.27ms; fastest: 0.09ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
Failed messages: pending 0, notready 0, noresp 1
WiFi firmware version 1.23
WiFi MAC address 60:01:94:09:b9:45
WiFi Vcc 3.35, reset reason Unknown
WiFi flash size 4194304, free heap 23568
WiFi IP address 10.0.0.235
WiFi signal strength -66dBm, reconnections 0, sleep mode modem
Socket states: 4 0 0 0 0 0 0 0
M98 report:
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: in file macro line 25 column 22: M350: array too long, max length = 1
Error: in file macro line 26 column 35: M92: array too long, max length = 1
Error: in file macro line 27 column 37: M566: array too long, max length = 1
Error: in file macro line 28 column 41: M203: array too long, max length = 1
Error: in file macro line 29 column 37: M201: array too long, max length = 1
Error: in file macro line 30 column 26: M906: array too long, max length = 1
Tool 0 offsets: X0.00 Y0.00 Z0.00 - WiFi -
Error: in file macro line 30 column 26: M906: array too long, max length = 1These errors are complaining that you're specifying E values for those commands, but don't have an extruder motor defined. So just delete the E values from those commands.
Your firmware version is quite out of date. I suggest you update.
It's as easy as uploading a zip file to the system tab in DWC.
Here is the latest release: https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.6/Duet2and3Firmware-3.4.6.zip
Upload it as is, do not extract it first.The changelogs are here: https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-346
This sounds fine, but the assumption is that the 0,0 point is on the front left of the machine to give you a left hand coordinate system to match what you'd see in CAD software or a slicer.
So -X would move left, +X right, -Y to the front, +Y to the back.
Does that match what you're seeing?
@Phaedrux Yes that's correct, I have it setup as CAD because that's what I'm familiar with. I'll update the software now and see if that makes a difference
This post is deleted! -
@Phaedrux I've been able to change the endstops in M574 with the ! to flip the endstops so they work correctly. Now if I try to home X or Y only 1 motor is activating. What commands do I need to put in so that it will activate both motors independently?
Home X:
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Mon Oct 09 2023 20:52:41 GMT+1100 (AEDT) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-860 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X5 F6000 ; go back a few mm G1 H1 X-860 F360 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
Home Y:
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Mon Oct 09 2023 20:52:41 GMT+1100 (AEDT) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Y-617 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 H2 Y5 F6000 ; go back a few mm G1 H1 Y-617 F360 ; move slowly to Y axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
Home All:
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Mon Oct 09 2023 20:52:40 GMT+1100 (AEDT) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-860 Y-617 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-860 Y-617 F360 ; move slowly to X and Y axis endstops once more (second pass) G1 H1 Z-125 F360 ; move Z down stopping at the endstop G90 ; absolute positioning G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
I think I've figured it out all good. It's showing as homed on X and Y with the endstops triggered. Thankyou so much for your help!
it's moving the Z up, then jutting back a few mm (in the + direction) and moving Z down again.
This indicates that the endstops are already triggered at the start of the homing moves. The jutting back is the back off move. You've already solved it by inverting the pin logic.
Glad you got it all going now.
One last thing, just to make sure your firmware update went smoothly, can you send M122 and M98 P"config.g" once more?
@Phaedrux After a few days break I'm back at it and am having an issue with homing. When I try to home X the 2nd X motor (X1 is driver 0, and X2 is driver 1) gets stuck right before the endstop would usually be triggered and starts shaking violently. The same thing happens when I try to home Y, the 2nd Y motor (Y1 is driver 3 and Y2 is driver 4) starts shaking violently and making a horrible noise when it gets to the endstop. Any ideas what might be causing this?
Here's the M122 and M98 readouts from previous. Looks like it updated correctly
m122
m122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.6 (2023-07-21 14:08:28) running on Duet WiFi 1.0 or 1.01 Board ID: 08DAM-999TL-MQ4S4-6JKDG-3S46M-TPH3Y Used output buffers: 1 of 26 (12 max) === RTOS === Static ram: 23896 Dynamic ram: 73796 of which 264 recycled Never used RAM 14124, free system stack 184 words Tasks: NETWORK(notifyWait,13.6%,272) HEAT(notifyWait,0.0%,388) Move(notifyWait,0.0%,363) MAIN(running,85.1%,454) IDLE(ready,1.3%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:01:11 ago, cause: software Last software reset at 2023-10-23 14:33, reason: User, GCodes spinning, available RAM 13980, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 33.3, current 34.8, max 35.2 Supply voltage: min 12.9, current 12.9, max 13.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min n/a Driver 1: standstill, SG min n/a Driver 2: standstill, SG min n/a Driver 3: standstill, SG min n/a Driver 4: standstill, SG min n/a Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2023-10-23 14:34:59 Cache data hit count 2530679737 Slowest loop: 9.72ms; fastest: 0.18ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 1.7ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Network === Slowest loop: 275.46ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Interface state: active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.27 WiFi MAC address 60:01:94:09:b9:45 WiFi Vcc 3.34, reset reason Turned on by main processor WiFi flash size 4194304, free heap 25176 WiFi IP address 10.0.0.5 WiFi signal strength -67dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
M98 P"config.g"
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled Error: in file macro line 25 column 19: M350: array too long, max length = 0 Error: in file macro line 26 column 28: M92: array too long, max length = 0 Error: in file macro line 27 column 30: M566: array too long, max length = 0 Error: in file macro line 28 column 33: M203: array too long, max length = 0 Error: in file macro line 29 column 30: M201: array too long, max length = 0 Error: in file macro line 30 column 22: M906: array too long, max length = 0 Error: bad drive number Error: in file macro line 52: G10: Invalid tool number Error: in file macro line 53: G10: Invalid tool number
Please post your config.g as it is now.
It looks like you still have all the E values present causing those errors.
; Configuration file for Duet WiFi (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Mon Oct 09 2023 20:52:40 GMT+1100 (AEDT) ; General preferences M575 P1 S1 B57600 ; enable support for PanelDue G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"MPCNC" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P4 S1 ; physical drive 4 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M584 X0:1 Y3:4 Z2 ; set drive mapping M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X855 Y612 Z120 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!e0stop+!e1stop" ; configure active-high endstops for low end on x via pins e0stop and e1stop M574 Y1 S1 P"!xstop+!ystop" ; configure active-high endstops for low end on y via pins xstop and ystop ; Z-Probe M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M140 H-1 ; disable heated bed (overrides default heater mapping) ; Fans ; Tools M563 P0 D0 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
