    MPCNC Endstop G28 Issue
    790
    • ZPomeroyundefined
      ZPomeroy @Phaedrux
      @Phaedrux I have dual motors. I don't know why the config came out like that. This is my current config for the motors and end stops:
      I'll try playing around with the m574 command. any suggestions for the proper config given my current setup?
      M569 P4 S1 ; physical drive 4 goes forwards
      M584 X0:1 Y3:4 Z2 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X855 Y612 Z120 S0 ; set axis maxima
      M574 E0 S1 P"xstop". ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 E1 S1 P"x2stop" ; configure switch-type (e.g. microswitch) endstop for low end on X2 via pin x2stop
      M574 X1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Y1 S1 P"y2stop" ; configure switch-type (e.g. microswitch) endstop for low end on Y2 via pin y2stop
        These are the endstop pin names
        Endstop inputs
        Label   Pin name
        X_STOP	xstop
        Y_STOP	ystop
        Z_STOP	zstop
        E0_STOP	e0stop
        E1_STOP	e1stop
        So I'd do something like...
        M574 X1 S1 P"xstop+e0stop"
        M574 Y1 S1 P"ystop+e1stop"
        X1 Y1 means the endstop is on the low end of travel.
        P"pinname+pinname" means it will use both those endstops when you home the axis with a G1 H1 X move, etc for Y. the order of the pins needs to correspond to the order of the motors in M584.
        ZPomeroyundefined 1 Reply Last reply Reply Quote 0
        • ZPomeroyundefined
          ZPomeroy @Phaedrux
          @Phaedrux Thank7you I really appreciate your help! Okay so I think I've set up the endstops correctly, but when I try to home all the axis just moves maybe +10 in X and Y and comes up with failed to enable endstops
          This is what I have the endstops as:
          M574 X1 S1 P"e0stop+e1stop" ; configure active-high endstops for low end on x via pins e0stop and e1stop
          M574 Y1 S1 P"xstop+ystop" ; configure active-high endstops for low end on y via pins xstop and ystop
          And this is my Home All file:
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.3.16 on Mon Oct 09 2023 20:52:40 GMT+1100 (AEDT)
          G91 ; relative positioning
          G1 H1 X-860 Y-617 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F6000 ; go back a few mm
          G1 H1 X-860 Y-617 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G1 H1 Z-125 F360 ; move Z down stopping at the endstop
          G90 ; absolute positioning
          G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
          ;G91 ; relative positioning
          ;G90 ; absolute positioning
            And you have them plugged into those ports on the board?
            Can you please post your entire config.g as it is now?
            Also please send M122 and M98 P"config.g" in the gcode console and report the responses.
            Can you also confirm that the direction of rotation of the motors is correct? Move the head to the center while the printer is off. Then power on and send G92 X100 Y100, and then send a G1 X10 Y10. That should move the head away from the endstops (since they are at the low end)
            • ZPomeroyundefined
              ZPomeroy @Phaedrux
              @Phaedrux
              I used the duet config website to generate this config so I'm not sure what all the errors in M98 are about? The G1 command moved everything towards the 0 point of each axis is that right? I currently have the motors set so that if I press X-50 it moves towards 0 and X+50 is away from 0. The endstops are on the truck carriages and should trigger when the axis reaches 0
              current config:
              ; Configuration file for Duet WiFi (firmware version 3.3)
              M575 P1 S1 B57600                               ; enable support for PanelDue
              G90                                             ; send absolute coordinates...
              M83                                             ; ...but relative extruder moves
              M550 P"MPCNC"                                   ; set printer name
              M552 S1                                         ; enable network
              M586 P0 S1                                      ; enable HTTP
              M586 P1 S0                                      ; disable FTP
              M586 P2 S0                                      ; disable Telnet
              M208 X0 Y0 Z0 S1                                ; set axis minima
              M558 P0 H5 F120 T6000                           ; disable Z probe but set dive height, probe speed and travel speed
              M557 X15:215 Y15:195 S20                        ; define mesh grid
              M140 H-1                                        ; disable heated bed (overrides default heater mapping)
              M563 P0 D0 F0                                   ; define tool 0
              G10 P0 X0 Y0 Z0                                 ; set tool 0 axis offsets
              G10 P0 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
              M122 report:
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.0 or 1.01
              Board ID: 08DAM-999TL-MQ4S4-6JKDG-3S46M-TPH3Y
              Used output buffers: 3 of 24 (19 max)
              Static ram: 27980
              Dynamic ram: 92908 of which 32 recycled
              Exception stack ram used: 352
              Never used ram: 9800
              Tasks: NETWORK(ready,404) HEAT(blocked,1456) MAIN(running,1880) IDLE(ready,80)
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:01:20 ago, cause: power up
              Last software reset at 2023-10-14 15:57, reason: User, spinning module GCodes, available RAM 9680 bytes (slot 2)
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
              Error status: 0
              MCU temperature: min 32.8, current 33.0, max 33.6
              Supply voltage: min 12.8, current 12.9, max 13.0, under voltage events: 0, over voltage events: 0, power good: yes
              Date/time: 2023-10-14 16:56:14
              Cache data hit count 135137405
              Slowest loop: 151.62ms; fastest: 0.13ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 2.0ms, write time 228.0ms, max retries 0
              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
              === MainDDARing ===
              Scheduled moves: 9, completed moves: 9, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
              === AuxDDARing ===
              Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
              Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 481.27ms; fastest: 0.09ms
              Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is active
                Failed messages: pending 0, notready 0, noresp 1
                WiFi firmware version 1.23
                WiFi MAC address 60:01:94:09:b9:45
                WiFi Vcc 3.35, reset reason Unknown
                WiFi flash size 4194304, free heap 23568
                WiFi IP address 10.0.0.235
                WiFi signal strength -66dBm, reconnections 0, sleep mode modem
                Socket states: 4 0 0 0 0 0 0 0
              M98 report:
              M98 P"config.g"
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
              Error: in file macro line 25 column 22: M350: array too long, max length = 1
              Error: in file macro line 26 column 35: M92: array too long, max length = 1
              Error: in file macro line 27 column 37: M566: array too long, max length = 1
              Error: in file macro line 28 column 41: M203: array too long, max length = 1
              Error: in file macro line 29 column 37: M201: array too long, max length = 1
              Error: in file macro line 30 column 26: M906: array too long, max length = 1
              Tool 0 offsets: X0.00 Y0.00 Z0.00
                Phaedrux Moderator @ZPomeroy
                @ZPomeroy said in MPCNC Endstop G28 Issue:
                These errors are complaining that you're specifying E values for those commands, but don't have an extruder motor defined. So just delete the E values from those commands.
                Your firmware version is quite out of date. I suggest you update.
                It's as easy as uploading a zip file to the system tab in DWC.
                Here is the latest release: https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.6/Duet2and3Firmware-3.4.6.zip
                Upload it as is, do not extract it first.
                The changelogs are here: https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-346
                This sounds fine, but the assumption is that the 0,0 point is on the front left of the machine to give you a left hand coordinate system to match what you'd see in CAD software or a slicer.
                So -X would move left, +X right, -Y to the front, +Y to the back.
                Does that match what you're seeing?
                ZPomeroyundefined 4 Replies Last reply Reply Quote 0
                • ZPomeroyundefined
                  ZPomeroy @Phaedrux
                  @Phaedrux Yes that's correct, I have it setup as CAD because that's what I'm familiar with. I'll update the software now and see if that makes a difference
                  • ZPomeroyundefined
                    ZPomeroy @Phaedrux
                    This post is deleted!
                    • ZPomeroyundefined
                      ZPomeroy @Phaedrux
                      • ZPomeroyundefined
                        ZPomeroy @Phaedrux
                        @Phaedrux I've been able to change the endstops in M574 with the ! to flip the endstops so they work correctly. Now if I try to home X or Y only 1 motor is activating. What commands do I need to put in so that it will activate both motors independently?
                        Home X:
                        ; homex.g
                        ; called to home the X axis
                        ; generated by RepRapFirmware Configuration Tool v3.3.16 on Mon Oct 09 2023 20:52:41 GMT+1100 (AEDT)
                        G1 H1 X-860 F1800 ; move quickly to X axis endstop and stop there (first pass)
                        G1 H2 X5 F6000    ; go back a few mm
                        G1 H1 X-860 F360  ; move slowly to X axis endstop once more (second pass)
                        G1 H2 Z-5 F6000   ; lower Z again
                        Home Y:
                        ; homey.g
                        ; called to home the Y axis
                        G1 H1 Y-617 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                        G1 H2 Y5 F6000    ; go back a few mm
                        G1 H1 Y-617 F360  ; move slowly to Y axis endstop once more (second pass)
                        Home All:
                        ; homeall.g
                        • ZPomeroyundefined
                          ZPomeroy
                          I think I've figured it out all good. It's showing as homed on X and Y with the endstops triggered. Thankyou so much for your help!
                            it's moving the Z up, then jutting back a few mm (in the + direction) and moving Z down again.
                            This indicates that the endstops are already triggered at the start of the homing moves. The jutting back is the back off move. You've already solved it by inverting the pin logic.
                            Glad you got it all going now.
                            One last thing, just to make sure your firmware update went smoothly, can you send M122 and M98 P"config.g" once more?
                            • ZPomeroyundefined
                              ZPomeroy @Phaedrux
                              @Phaedrux After a few days break I'm back at it and am having an issue with homing. When I try to home X the 2nd X motor (X1 is driver 0, and X2 is driver 1) gets stuck right before the endstop would usually be triggered and starts shaking violently. The same thing happens when I try to home Y, the 2nd Y motor (Y1 is driver 3 and Y2 is driver 4) starts shaking violently and making a horrible noise when it gets to the endstop. Any ideas what might be causing this?
                              Here's the M122 and M98 readouts from previous. Looks like it updated correctly
                              m122
                              m122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.6 (2023-07-21 14:08:28) running on Duet WiFi 1.0 or 1.01
                              Used output buffers: 1 of 26 (12 max)
                              Static ram: 23896
                              Dynamic ram: 73796 of which 264 recycled
                              Never used RAM 14124, free system stack 184 words
                              Tasks: NETWORK(notifyWait,13.6%,272) HEAT(notifyWait,0.0%,388) Move(notifyWait,0.0%,363) MAIN(running,85.1%,454) IDLE(ready,1.3%,30), total 100.0%
                              Last reset 00:01:11 ago, cause: software
                              Last software reset at 2023-10-23 14:33, reason: User, GCodes spinning, available RAM 13980, slot 1
                              Error status: 0x00
                              Aux0 errors 0,0,0
                              Step timer max interval 0
                              MCU temperature: min 33.3, current 34.8, max 35.2
                              Supply voltage: min 12.9, current 12.9, max 13.1, under voltage events: 0, over voltage events: 0, power good: yes
                              Events: 0 queued, 0 completed
                              Driver 0: standstill, SG min n/a
                              Driver 1: standstill, SG min n/a
                              Driver 2: standstill, SG min n/a
                              Driver 3: standstill, SG min n/a
                              Driver 4: standstill, SG min n/a
                              Driver 5:
                              Driver 6:
                              Driver 7:
                              Driver 8:
                              Driver 9:
                              Driver 10:
                              Driver 11:
                              Date/time: 2023-10-23 14:34:59
                              Cache data hit count 2530679737
                              Slowest loop: 9.72ms; fastest: 0.18ms
                              === Storage ===
                              SD card longest read time 1.7ms, write time 0.0ms, max retries 0
                              DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                              === MainDDARing ===
                              === AuxDDARing ===
                              Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                              Segments left: 0
                              LCD is idle in state(s) 0
                              Code queue is empty
                              === Network ===
                              Slowest loop: 275.46ms; fastest: 0.00ms
                              Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                              = WiFi =
                              Interface state: active
                              Module is connected to access point
                              WiFi firmware version 1.27
                              WiFi Vcc 3.34, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 25176
                              WiFi IP address 10.0.0.5
                              WiFi signal strength -67dBm, mode 802.11n, reconnections 0, sleep mode modem
                              Clock register 00002002
                              M98 P"config.g"
                              M98 P"config.g"
                              FTP is disabled
                              TELNET is disabled
                              Error: in file macro line 25 column 19: M350: array too long, max length = 0
                              Error: in file macro line 26 column 28: M92: array too long, max length = 0
                              Error: in file macro line 27 column 30: M566: array too long, max length = 0
                              Error: in file macro line 28 column 33: M203: array too long, max length = 0
                              Error: in file macro line 29 column 30: M201: array too long, max length = 0
                              Error: in file macro line 30 column 22: M906: array too long, max length = 0
                              Error: bad drive number
                              Error: in file macro line 52: G10: Invalid tool number
                              Error: in file macro line 53: G10: Invalid tool number
                                Please post your config.g as it is now.
                                It looks like you still have all the E values present causing those errors.
                                • ZPomeroyundefined
                                  ZPomeroy @Phaedrux
                                  @Phaedrux
                                  M574 X1 S1 P"!e0stop+!e1stop"                     ; configure active-high endstops for low end on x via pins e0stop and e1stop
                                  M574 Y1 S1 P"!xstop+!ystop"                       ; configure active-high endstops for low end on y via pins xstop and ystop
                                    In this section remove the E values like this
                                    M350 X16 Y16 Z1 I1                      ; configure microstepping with interpolation
                                    M92 X80.00 Y80.00 Z400.00        ; set steps per mm
                                    M566 X900.00 Y900.00 Z60.00      ; set maximum instantaneous speed changes (mm/min)
                                    M203 X6000.00 Y6000.00 Z180.00 ; set maximum speeds (mm/min)
                                    M201 X500.00 Y500.00 Z20.00      ; set accelerations (mm/s^2)
                                    M906 X800 Y800 Z800 I30                ; set motor currents (mA) and motor idle factor in per cent
                                    And in the tool definition you should remove the extruder drive and fan references
                                    Like this
                                    M563 P0                                   ; define tool 0
                                    Make those adjustments and run M98 P"config.g" again and see if your homing issue is still there.
                                    Also make sure the homing move is long enough to guarantee an endstop hit from the farthest point.
                                    • ZPomeroyundefined
                                      ZPomeroy @Phaedrux
                                      @Phaedrux I'm still having issues but I'm not sure why. Sometimes the motors will skip and start making a horrible noise when the endstops should have been triggered. The other issue I'm having is I don't know how to home Z without a Z probe? I've got M558 in config.g. How do I tell the board that the Z axis is homed?
                                        G1 H1 Z-125 F360 ; move Z down stopping at the endstopG90 ; absolute positioningG92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                        In your homeall you're doing a homing move as if you have an endstop to home to, but you don't have a z endstop defined in config.g
                                        How do you intend to home your Z axis?
                                        Right now you have a manual probe defined, so it would prompt you to manually jog the axis to touch the Z0 point. To use that you would need to modify your homez and homeall and change these lines
                                        To simply G30 so that it would call the probe and prompt you to home Z manually.
                                        Can you give me detail about this? Maybe a video showing what is happening?
                                        Do it happen every time? Randomly? Does the axis move normally otherwise?
