    mesh bed compensation
    447
    • tom33undefined
      tom33 @tom33
      @tom33
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Mar 31 2021 11:16:46 GMT+0200 (heure d’été d’Europe centrale)
      M291 S3 R"Bed Levelling" P"Voulez vous réaliser un palpage plateau ?"
      M291 S2 R"Bed Levelling" P"Assurez-vous que le plateau d'impression est monté et l'espace de travail libéré"
      M291 S2 R"Bed Levelling" P"Le palpage plateau va démarrer - Veuillez fermer les portes - Température buse max 80°C"
      M400
      ;M291 S3 R"Bed Levelling" P"Voulez vous réaliser un palpage plateau ?" T1
      ;M42 P ;Fermeture des portes + Verif portes fermées.
      if heat.heaters[1].current > 81
         M109 S80
         M291 S1 R"Bed Levelling" P"T --> 80°C"
         M116
      else
         ;continue
      M400
      ;G28 C
      T-1
      M280 P4 S180
      G90
      G53 G0 X250 Y250 Z50 F2400
      M561
      G29 s2
      M376
      G30
      G29  ; probe the bed and enable compensation
      M400
      G28Z
      G29 S2
      T0
      G30 S-2
      M500
      G28
      G29 S1
      M291 S1 R"Bed Levelling" P"Calibration plateau terminée"
      tom33undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
      • tom33undefined
        tom33 @tom33
        @tom33
        When I send M122 the bed compensation is enable
        tom33undefined 1 Reply Last reply Reply Quote 0
        • tom33undefined
          tom33 @tom33
          @tom33
          I probe directly with the head of the machine
          extract of config g
          M563 P0 S"E0" D0 H1 F0					                ; Define Extruder 0 drive 0 Heater 1 Fan 0
          G10 P0 X-30.4 Y0 Z-30.620 						                ; Set offset
          G10 P0 R0 S0 							                ; Reset initial tool 0 active and standby temperatures to 0C
          G10 L2 P1 X37.60 Y20.00 Z0
          M500
          M558 P5 C"io4.in" H7.5 F300 T6000
          G31 P500 X0 Y0 Z-2.35                                    ; set Z probe trigger value, offset and trigger height
          tom33undefined fcwiltundefined 3 Replies Last reply Reply Quote 0
          • tom33undefined
            tom33 @tom33
            @tom33
            start.g
            M42 P0 S0
            M98 P/macros/Machine/Safety/03_Porte.g
            M98 P/macros/myUpTimePrint.g
            ;G28
            G29 S1
            • tom33undefined
              tom33 @tom33
              @tom33 I have also tried with
              G31 P500 X-30.4 Y0 Z-2.35 ; ```
              • fcwiltundefined
                fcwilt @tom33
                @tom33
                I will be glad to help but I need to study your code.
                One thing I will mention now before I get into studying your code:
                The developers have this in mind for using G32 and G29:
                G32 will run bed.g.
                G29 will run mesh.g.
                In bed.g there should be the code for leveling the bed.
                In mesh.g there should be the code for creating the height map that is needed for mesh bed compensation.
                Bed Leveling and Mesh Bed Compensation are two totally different things.
                You have put the code for using mesh bed compensation in the file bed.g. While this will work it is not as intended. There are commands in the DWC that expect the conventional use of bed.g and mesh.g.
                It's your printer and naturally you are free to do whatever you like.
                Now I am off to study your code. In the meantime could you post the image of your height map?
                • fcwiltundefined
                  fcwilt @tom33
                  @tom33
                  Please post your entire config.g file.
                  A few things to consider:
                  • once you have homed your printer it should stay homed unless something goes wrong.
                  • before creating the height map with G29 you should set the Z=0 Datum with G30 at some fixed position - I use the center of the bed.
                  • before loading the height map with G29 S1 you should again set the Z=0 Datum as before.
                  • you should create the height map with the bed at the temperature you are going to print at. I let the bed heat for at least 30 minutes before creating the height map.
                  • once you have created the height map you should not need to re-create it unless something goes wrong.
                  Question: You have a G30 S-2 command in your bed.g file. Why is that?
                  • tom33undefined
                    tom33 @fcwilt
                    @fcwilt I'm not runing a G30 before each print
                    The G30 S-2 is to save the tool Z offset in the config-override
                    And when I'm doing the height map, the bed is well heated
                    • fcwiltundefined
                      fcwilt @tom33
                      @tom33 said in mesh bed compensation:
                      It needs to be done at the times I posted.
                      Tool offsets only apply to multi-tool printers. Is that what you have?
                      That is good.
                      • tom33undefined
                        tom33 @fcwilt
                        @fcwilt Yes I have two tool heads in the machine
                        I don't understand where I have to move the G30 S-2 ?
                        • fcwiltundefined
                          fcwilt @tom33
                          So it's not a tool changing printer but tools are always present?
                          • tom33undefined
                            tom33 @fcwilt
                            @fcwilt Yes, I have just a system to up and down the second tool head
                            • fcwiltundefined
                              fcwilt @tom33
                              As you understand the firmware needs to know the locations (X, Y, Z) of the Z probe and the tools, relative to one another.
                              With a single tool system the tool XYZ offsets are the reference (all zero) and the Z probe offsets/trigger height are set as appropriate.
                              Typically with a multi-tool system the Z probe is the reference (offsets/trigger height all zero) and the tool XYZ offsets are set as appropriate.
                              Your are combining both approaches - which will work - it is just unusual.
                              Where did you get the code in BED.G - there is much there that I don't understand.
                              When configuring your tools you have G10 L2 P1 X37.60 Y20.00 Z0. Why the L2?
                              But back to your original problem. Have you updated start.g to include a G30 before the G29 S1? Recall that the G30 used to set the Z=0 Datum should always be at the same XY machine position.
