Duet conversion
So, I've used the duet on a few (5 or 6) printers for several years, but it's been a while since I was in the nitty gritty of setting one up. I inherited an old delta and switched all the wiring over from the MKS setup. I can access the web portal and home the printer, but I cannot move the printhead. Any ideas on what might be going on here? Endstops seem to be correct, as it homes and the LED's light up upon homing.
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.16 on Mon Jul 10 2023 14:44:47 GMT-0400 (Eastern Daylight Time); General preferences
M550 P"LargeDelta" ; set printer name
M665 R325 L247 B150 H260 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
; M551 P"tigger1968" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X350 Y350 Z350 E650 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 R85 S20 ; define mesh grid; Heaters
T0 ; select first tool -
@Legrand said in Duet conversion:
M208 Z0 S1 ; set minimum ZMost of the axis limits are missing......
@Legrand almost certainly it’s your endstops:
Endstops M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
Your endstops are at the top, ie the maximum end of the axes, and you home to the top, so they should be X2 Y2 and Z2.
@DIY-O-Sphere that’s normal for a delta. The XY limit is defined as a circle, the radius of which is the B parameter in M665. So you only need Z in M208.
A delta radius of 325 seems unlikely, it is generally only a bit bigger than the B value, and smaller than the L value. You probably have diameter rather than radius, so halve it. See my post here for guidance on setting these parameters: https://forum.duet3d.com/post/289874
@droftarts said in Duet conversion:
Sorry, I missed that.....
Changed to X2, Y2, Z2, LED's now illuminate when away from end stops, printer homes, but still cannot move axis.
@Legrand Are you getting any error messages in the console? Generally you need to move down in Z first with a delta, you can't move X and Y at the top. The area you can move in is like a cone on top of a cylinder, because the axes would have to move past the homing point (and axis limit) to move in X and Y at the limit of Z.
@droftarts Got it. It was the delta radius issue. I didn't think that would prevent the move, but, apparently it did. Thanks.
Movement cannot be computed if the rod length is less than the delta radius.
