    Creality CR-10 upgrade
    252
    53.8k
    • Agniusmundefined
      Agniusm
      Btw, here is my extruder and all:
        @Agniusm:
        OK. Got another weird question out of the blue, dont laugh. So i habe that IR probe with signal, ground and +3.3. What would happen if i will have a switch paralleled to IR ground and signal shorted? The probe is used before print and keepimg wiring to the minimum, what if simple filament runout sensor switch was hooked there? I am no electronics guy but would that might work?
        I don't see why you would want to connect a filament runout sensor to the Z probe input. Filament monitors are normally connected to spare endstop inputs.
        • Agniusmundefined
          Agniusm
          Started wiring. Got the X and Z working fine. Still need to wire in some end stops.
          Do i need mechanical endstop on Z if i have IR bed probe?
          The thing that buggers me though is the constant disconnect with message:
          An AJAX error has been reported, so the current session has been terminated.
          Please check if your printer is still on and try to connect again.
          Error reason: timeout
          Then i get:
          Could not establish a connection to the Duet firmware! Please check your settings and try again.
          After some refreshes it connects but it repeats.
          I have read about signal strength but have no clue why, i think i have good connection, probably 6m away.
            See https://duet3d.com/wiki/WiFi_disconnections_and_AJAX_timeout_errors to start with.
            • Agniusmundefined
              Agniusm
              [[language]]
              M122
              Used output buffers: 3 of 32 (8 max)
              RepRapFirmware for Duet WiFi version 1.19 running on Duet WiFi 1.0
              Board ID: 08DDM-9FAM2-LW4S4-6JKF0-3SD6J-T2SVX
              Static ram used: 21176
              Dynamic ram used: 95928
              Recycled dynamic ram: 1680
              Stack ram used: 1304 current, 4840 maximum
              Never used ram: 7448
              Last reset 00:01:19 ago, cause: power up
              Last software reset reason: User, spinning module GCodes, available RAM 7448 bytes (slot 3)
              Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
              Error status: 0
              Free file entries: 10
              SD card longest block write time: 0.0ms
              MCU temperature: min 21.0, current 26.2, max 28.4
              Supply voltage: min 12.1, current 12.1, max 12.3, under voltage events: 0, over voltage events: 0
              Driver 0: standstill
              Driver 1: standstill
              Driver 2: standstill
              Driver 3: standstill
              Driver 4: standstill
              Date/time: 2017-11-11 23:25:16
              Slowest main loop (seconds): 0.008141; fastest: 0.000034
              MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
              Bed compensation in use: none
              Bed heater = 0, chamber heater = -1
              Segments left: 0
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              Network state is running
              WiFi firmware version 1.19
              WiFi MAC address 5c:cf:7f:ef:4d:9b
              WiFi Vcc 3.12, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 39848
              WiFi IP address 192.168.2.144
              WiFi signal strength -62dBm
              HTTP sessions: 1 of 8
              Socket states: 2 0 0 0 0 0 0 0
              Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
              • Agniusmundefined
                Agniusm
                Updated firmware and interface, i don't know why some modules show as 1.19 when it should be 1.20:
                Firmware Name: RepRapFirmware for Duet WiFi
                Firmware Electronics: Duet WiFi 1.0
                Firmware Version: 1.19 (2017-08-14)
                WiFi Server Version: 1.19.2
                Web Interface Version: 1.19.3
                • Dougal1957undefined
                  Dougal1957
                  beecause it hasn't taken the firmware try again make sure you are doing the right one?
                  • Agniusmundefined
                    Agniusm
                    OK. Tried this one more time and it updated. Now disconnects are rarer and reconnects faster. Still get them though
                    • Agniusmundefined
                      Agniusm
                      Stuck with mesh bed probing. I follow this:
                      Make sure there is no filament stuck to the nozzle (you may want to do this test with the nozzle hot)
                      Cancel any existing bed compensation by sending M561
                      Send M208 S1 Z-3 to temporarily allow Z moves down to Z=-3mm. This is to ensure that you can lower the nozzle all the way to the bed in step 5.
                      Command the print head to the XY coordinates you want to probe
                      Command the print head down in small steps until the nozzle just touches the bed or just grips a sheet of paper. You may need to send M564 S0 to allow movement lower than where the firmware thinks Z=0 is. You may also wish to create a macro to lower the head by e.g. 0.02mm to get greater accuracy (G91 followed by G1 Z-0.02).
                      Send G92 Z0 to define that height as Z=0
                      Command the nozzle up 5mm (G1 Z5)
                      Send G30 S-1 to probe the bed without resetting the Z=0 position
                      Read off the Z height from the web interface. That is the trigger height.
                      And get trigger height at 2.320
                      I put that value in config.g
                      G31 P500 X5 Y14.5 Z2.32
                      I don't know if i set the offsets correct. My probe is 5mm to the left of the nozzle and 14.5mm in front of the nozzle.
                      When i home, Z is at 2.32
                      The i do Mesh grid and send G29 but the bloody thing drives into the bed.
                      I am totally lost here
                        Check that you don't also have a config-override.g file with a G31 command in it.
                        The WiFi disconnects may be even rarer if you upgrade to 1.20RC1, but you may wish to defer that until you have everything working.
                        • Agniusmundefined
                          Agniusm
                          OK Everything works fine now. Trying to extrude. Doing extruder calibration. E3D states that their extruder is 400 steps but i only get half of the requested 100mm of filament. Will double the steps but why twice from stated 400? Could be voltage, that they state rate at 24V? Will see
                          P.S. BTW, any pointers where i can get sample start end end gcode scripts with mesh compensation?
                            @Agniusm:
                            The (approx.) 400 steps is for a 1.8deg extruder motor. You are probably using a 0.9 deg motor. If you bought it from E3D, it will be 0.9deg.
                            • Agniusmundefined
                              Agniusm
                              Ah, yes, you are correct, i completely forgot i've read somewhere about it.
                              I thank you David for your support and answering those noob questions. I can state that my build is alive and printing. Still some road to cover with fine tuning but i am so happy that i have completed this machine. Here is my 6th test cube:
                              P.S. I have noticed that each time i control printer through Panel Due i get ajax error on web interface.
                                Please report the text of the "Error reason" in the Ajax error message Z if there is one.
                                • Agniusmundefined
                                  Agniusm
                                  One general question. Trying printing quicker and i get some uneven perimeter lines. What could be happening? Does Extrusion Factor on web interface got anything to do with it?
                                  My pressure advance is set to .7 on direct drive
                                  M569 P0 S0 ; Drive 0 goes forwards
                                  M569 P2 S0 ; Drive 2 goes forwards
                                  M569 P3 S0 ; Drive 3 goes forwards
                                  M92 X79.9 Y80.69 Z396 E800 ; Set steps per mm
                                  M566 X900 Y900 Z12 E200 ; Set maximum instantaneous speed changes (mm/min) (buvo e120)
                                  M203 X40000 Y40000 Z1000 E1200 ; Set maximum speeds (mm/min)
                                  M201 X3000 Y1500 Z20 E250 ; Set accelerations (mm/s^2)
                                  M906 X1000 Y1500 Z1000 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                  M84 S30 ; Set idle timeout
                                    If your extruder is direct drive (i.e. no significant length of Bowden tube between the extruder drive and the nozzle), then pressure advance of 0.7 is much too high. Try 0.05.
                                    • Agniusmundefined
                                      Agniusm
                                      Tried 0.5 and 0.7 made it better. I found my problem. Skipping gear on e3d.
                                      Don't know why its happening so will contact their support
                                      • Agniusmundefined
                                        Agniusm
                                        What should i put in starting Gcode for mech bed compensation?
                                        is it only the M28 command or should i erase previous probing?
                                        Here is what i have at the moment (mainly modified from prusa mk2 🙂 😞
                                        M83 ; extruder relative mode
                                        M104 S[first_layer_temperature] ; set extruder temp
                                        M140 S[first_layer_bed_temperature] ; set bed temp
                                        M190 S[first_layer_bed_temperature] ; wait for bed temp
                                        M109 S[first_layer_temperature] ; wait for extruder temp
                                        G28 ; home all without mesh bed level
                                        G32 ; mesh bed leveling
                                        G1 Y20 X10 Z0.30 F7000.0 ; go outside printing area
                                        G1 E10 F100
                                        G1 X100.0 E9.0 F1000 ; intro line
                                        G1 X180.0 E12.5 F1000 ; intro line
                                        So instead of 5 point probing G32 i have, should i change to:
                                        G29 S0 (or S1 if i want to use previous data from last measurement)?
                                        • Agniusmundefined
                                          Agniusm
                                          So my titan aero is clicking and e3d sent a new motor only larger which does not fit my design. Are you David use titan aero and if so any issues ? I found this motor and i dont know if the data is correct and if it would work: https://www.omc-stepperonline.com/hybrid-stepper-motor/nema-17-bipolar-18deg-18ncm-255ozin-07a-29v-42x42x25mm-4-wires-17hs10-0704s.html
                                            I don't use a Titan Aero, I use a regular Titan. The motor I use is this https://www.omc-stepperonline.com/hybrid-stepper-motor/nema-17-bipolar-18deg-22ncm-31ozin-133a-28v-42x42x34mm-4-wires-17hs13-1334s.html.
