    Creality CR-10 upgrade
    252
    53.8k
    • Agniusmundefined
      Agniusm
      Updated firmware and interface, i don't know why some modules show as 1.19 when it should be 1.20:
      Firmware Name: RepRapFirmware for Duet WiFi
      Firmware Electronics: Duet WiFi 1.0
      Firmware Version: 1.19 (2017-08-14)
      WiFi Server Version: 1.19.2
      Web Interface Version: 1.19.3
      • Dougal1957undefined
        Dougal1957
        beecause it hasn't taken the firmware try again make sure you are doing the right one?
        • Agniusmundefined
          Agniusm
          OK. Tried this one more time and it updated. Now disconnects are rarer and reconnects faster. Still get them though
          • Agniusmundefined
            Agniusm
            Stuck with mesh bed probing. I follow this:
            Make sure there is no filament stuck to the nozzle (you may want to do this test with the nozzle hot)
            Cancel any existing bed compensation by sending M561
            Send M208 S1 Z-3 to temporarily allow Z moves down to Z=-3mm. This is to ensure that you can lower the nozzle all the way to the bed in step 5.
            Command the print head to the XY coordinates you want to probe
            Command the print head down in small steps until the nozzle just touches the bed or just grips a sheet of paper. You may need to send M564 S0 to allow movement lower than where the firmware thinks Z=0 is. You may also wish to create a macro to lower the head by e.g. 0.02mm to get greater accuracy (G91 followed by G1 Z-0.02).
            Send G92 Z0 to define that height as Z=0
            Command the nozzle up 5mm (G1 Z5)
            Send G30 S-1 to probe the bed without resetting the Z=0 position
            Read off the Z height from the web interface. That is the trigger height.
            And get trigger height at 2.320
            I put that value in config.g
            G31 P500 X5 Y14.5 Z2.32
            I don't know if i set the offsets correct. My probe is 5mm to the left of the nozzle and 14.5mm in front of the nozzle.
            When i home, Z is at 2.32
            The i do Mesh grid and send G29 but the bloody thing drives into the bed.
            I am totally lost here
              Check that you don't also have a config-override.g file with a G31 command in it.
              The WiFi disconnects may be even rarer if you upgrade to 1.20RC1, but you may wish to defer that until you have everything working.
              • Agniusmundefined
                Agniusm
                OK Everything works fine now. Trying to extrude. Doing extruder calibration. E3D states that their extruder is 400 steps but i only get half of the requested 100mm of filament. Will double the steps but why twice from stated 400? Could be voltage, that they state rate at 24V? Will see
                P.S. BTW, any pointers where i can get sample start end end gcode scripts with mesh compensation?
                  @Agniusm:
                  The (approx.) 400 steps is for a 1.8deg extruder motor. You are probably using a 0.9 deg motor. If you bought it from E3D, it will be 0.9deg.
                  • Agniusmundefined
                    Agniusm
                    Ah, yes, you are correct, i completely forgot i've read somewhere about it.
                    I thank you David for your support and answering those noob questions. I can state that my build is alive and printing. Still some road to cover with fine tuning but i am so happy that i have completed this machine. Here is my 6th test cube:
                    P.S. I have noticed that each time i control printer through Panel Due i get ajax error on web interface.
                      Please report the text of the "Error reason" in the Ajax error message Z if there is one.
                      • Agniusmundefined
                        Agniusm
                        One general question. Trying printing quicker and i get some uneven perimeter lines. What could be happening? Does Extrusion Factor on web interface got anything to do with it?
                        My pressure advance is set to .7 on direct drive
                        M569 P0 S0 ; Drive 0 goes forwards
                        M569 P2 S0 ; Drive 2 goes forwards
                        M569 P3 S0 ; Drive 3 goes forwards
                        M92 X79.9 Y80.69 Z396 E800 ; Set steps per mm
                        M566 X900 Y900 Z12 E200 ; Set maximum instantaneous speed changes (mm/min) (buvo e120)
                        M203 X40000 Y40000 Z1000 E1200 ; Set maximum speeds (mm/min)
                        M201 X3000 Y1500 Z20 E250 ; Set accelerations (mm/s^2)
                        M906 X1000 Y1500 Z1000 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                          If your extruder is direct drive (i.e. no significant length of Bowden tube between the extruder drive and the nozzle), then pressure advance of 0.7 is much too high. Try 0.05.
                          • Agniusmundefined
                            Agniusm
                            Tried 0.5 and 0.7 made it better. I found my problem. Skipping gear on e3d.
                            Don't know why its happening so will contact their support
                            • Agniusmundefined
                              Agniusm
                              What should i put in starting Gcode for mech bed compensation?
                              is it only the M28 command or should i erase previous probing?
                              Here is what i have at the moment (mainly modified from prusa mk2 🙂 😞
                              M83 ; extruder relative mode
                              M104 S[first_layer_temperature] ; set extruder temp
                              M140 S[first_layer_bed_temperature] ; set bed temp
                              M190 S[first_layer_bed_temperature] ; wait for bed temp
                              M109 S[first_layer_temperature] ; wait for extruder temp
                              G28 ; home all without mesh bed level
                              G32 ; mesh bed leveling
                              G1 Y20 X10 Z0.30 F7000.0 ; go outside printing area
                              G1 E10 F100
                              G1 X100.0 E9.0 F1000 ; intro line
                              G1 X180.0 E12.5 F1000 ; intro line
                              So instead of 5 point probing G32 i have, should i change to:
                              G29 S0 (or S1 if i want to use previous data from last measurement)?
                              • Agniusmundefined
                                Agniusm
                                So my titan aero is clicking and e3d sent a new motor only larger which does not fit my design. Are you David use titan aero and if so any issues ? I found this motor and i dont know if the data is correct and if it would work: https://www.omc-stepperonline.com/hybrid-stepper-motor/nema-17-bipolar-18deg-18ncm-255ozin-07a-29v-42x42x25mm-4-wires-17hs10-0704s.html
                                  I don't use a Titan Aero, I use a regular Titan. The motor I use is this https://www.omc-stepperonline.com/hybrid-stepper-motor/nema-17-bipolar-18deg-22ncm-31ozin-133a-28v-42x42x34mm-4-wires-17hs13-1334s.html.
                                  • Agniusmundefined
                                    Agniusm
                                    Changed my bed for precision plate now battling IR probe as endstop. I cant seem to grasp the concept here. I lover the nozzle to where it touches the piece of paper then G92 Z0 and when i home it does not go back to that height. Tried G31 P500 X5 Y14.5 Z-5.5 ; with no success.
                                    Whats the proper procedure setting Z probe height?
                                    I am looking at these :
                                    https://duet3d.com/wiki/Setting_up_automatic_probing_of_the_print_bed
                                    https://duet3d.com/wiki/Using_mesh_bed_compensation
                                      The G31 Z parameter should be positive for sensors that trigger before the nozzle touches the bed. For the IR sensor is should be no higher than about 3mm.
                                      If you are restarting the Duet between attempts, also check that you don't also have a G31 command in config-override.g.
                                      • Agniusmundefined
                                        Agniusm
                                        I dont have that file. So G31 is the offset of the Z probe depending how its mounted?
                                        So then i would go:
                                        M208 S1 Z-3
                                        Lower the nozzle to where it touches say piece of paper.
                                        G92 Z0 to store that
                                        But where is that offset, do i need to read it from web interface and then enter it to config.g's G31? Is there a step by step somewhere?
                                          I suggest you read the commissioning instructions in the fitting instructions page, at https://miscsolutions.wordpress.com/mini-height-sensor-board/.
                                          • Agniusmundefined
                                            Agniusm
                                            Thank you. I think i have the idea now. Here is the map:
                                            Is this any good or my bed is bad?
                                            I have bought new 8mm precision plate but it does not look that precise.
                                            Before i had Chaina heatbed out of 3mm aluminium and got this:
                                            Can you help interpret the results?
                                            P.S. I have 5V LED bar. Draws little over 1 A
                                            Can i connect it to unused expansion header pins and control it with a macro? Cant seem to find header ratings
