    Wifi problem since replacing SD card with new Firmware
    Firmware installation
    575
    • mesacrashundefined
      mesacrash @Phaedrux
        mesacrash @Phaedrux
        @Phaedrux Please advise.
          mesacrash @Phaedrux
          @Phaedrux
          SD card 0 not detected, interface speed: 30.0MBytes/sec
            mesacrash @Phaedrux
            @Phaedrux
            M39
            Error: M39: No SD card mounted in slot 0
            ok
              droftarts administrators @mesacrash
              @mesacrash It is not finding the SD card. Make sure the SD card is in, and reset the board. Send M122 and post the reply. You can cut and paste from YAT into your reply, in between 'code' quotes (</> formatting in the message window) which is much easier and more readable than taking a screenshot.
              If the SD card is in, how big is it, and how is it formatted? See https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#formatting
              To flash the firmware, you also need the IAP (In Application Programmer) binary file in the /firmware folder. You need to use the version of this that matches the firmware that is currently on your board. Most likely using the one from RRF 3.4.5 will be fine. Get the "Duet2_SDiap32_WiFiEth.bin" file from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.5 and put it in the /firmware folder.
              mesacrashundefined 3 Replies Last reply Reply Quote 1
                mesacrash @droftarts
                @droftarts
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.6 (2023-07-21 14:08:28) running on Duet WiFi 1.02 or later
                Board ID: 0JD2M-9F8TA-GJ4TJ-6JTD4-3S46T-16UL6
                Used output buffers: 1 of 26 (1 max)
                Static ram: 23896
                Dynamic ram: 73392 of which 0 recycled
                Never used RAM 14792, free system stack 184 words
                Tasks: NETWORK(ready,6.8%,513) HEAT(notifyWait,0.0%,388) Move(notifyWait,0.0%,363) MAIN(running,93.0%,602) IDLE(ready,0.2%,30), total 100.0%
                Owned mutexes: USB(MAIN)
                Last reset 00:08:47 ago, cause: reset button or watchdog
                Last software reset at 2023-10-17 18:21, reason: User, GCodes spinning, available RAM 12876, slot 0
                Error status: 0x00
                Step timer max interval 0
                MCU temperature: min 22.1, current 22.7, max 23.7
                Supply voltage: min 24.3, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                Events: 0 queued, 0 completed
                Driver 0: standstill, SG min n/a
                Driver 1: standstill, SG min n/a
                Driver 2: standstill, SG min n/a
                Driver 3: standstill, SG min n/a
                Driver 4: standstill, SG min n/a
                Driver 5:
                Driver 6:
                Driver 7:
                Driver 8:
                Driver 9:
                Driver 10:
                Driver 11:
                Slowest loop: 4.44ms; fastest: 0.19ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 3.5ms, write time 0.0ms, max retries 0
                DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                === MainDDARing ===
                === AuxDDARing ===
                Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is ready with "M122" in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                Daemon is idle in state(s) 0
                Code queue is empty
                === Network ===
                Slowest loop: 0.29ms; fastest: 0.00ms
                Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                HTTP sessions: 0 of 8
                = WiFi =
                Interface state: disabled
                Module is disabled
                ok
                  @droftarts
                  Every time I formatted an SD card with the SD Card Formatter, My main PC said Windows wouldn't open it. So, I used Windows Formatter, not Quick.
                    @droftarts
                    The reset must have been the answer. It is currently burning to the board.
                      @mesacrash
                      The M122 says firmware version is 3.4.6, so not much point updating it.
                      It also says "SD card 0 detected, interface speed: 20.0MBytes/sec" so that seems to be okay. Try sending M39 again.
                      Your WiFi module is disabled, so I can't tell if that is working or not.
                      Is there a config.g in the /sys folder of the SD card?
                      mesacrashundefined 1 Reply Last reply Reply Quote 0
                        @mesacrash said in Wifi problem since replacing SD card with new Firmware:
                        @droftarts
                        If you eject the SD card, when you put it back in, you either need to remount it with M21, or reset the board.
                          @droftarts No, my old card crapped out on me, so I'm starting fresh.
                            @droftarts I don't see the configuration tool, wth?
                              @mesacrash https://configtool.reprapfirmware.org/Start
