    Fly-RRF-36 RP2040 not work second fan
    Other control boards
    500
    • agz90undefined
      agz90 @agz90
      @agz90 said in Fly-RRF-36 RP2040 not work second fan:
      @gloomyandy
      Hello. This is my config for the fans.
      M950 F1 C"124.out2" Q500 ; create fan 0 on pin out5 and set its frequency
      M106 P1 C"PartCool" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
      M950 F0 C"124.out1" Q500 ; create fan 1 on pin out4 and set its frequency
      M106 P0 C"HotEnd" S1 H1 T55 ; set fan 1 name and value. Thermostatic control is turned on
      the heater works, the extruder cooling fan works, but the parts cooling fan does not.
        jay_s_uk @agz90
        @agz90 post your whole config so we can see your tool assignments
        agz90undefined 1 Reply Last reply Reply Quote 0
        • agz90undefined
          agz90 @jay_s_uk
          @jay_s_uk said in Fly-RRF-36 RP2040 not work second fan:
          ; Configuration file for BTT OctoPus V1 (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v3.1.10+4-LPC on Tue Jan 19 2021 17:25:01 GMT+0800 (中国标准时间)
          M111 S0 ; Debug off
          G21 ; Work in millimetres
          M550 P"BTT-AGZ_VORON" ; set printer name
          M669 K1 ; select CoreXY mode
          G4 S20 ; wait for expansion boards to start
          M575 P1 B57600 S1 ; Comms parameters for PanelDue
          M564 S1 H1 ; Forbid axis movements when not homed
          ;M552 S0
          M552 S1 ; start network module (must have been configured first with M587)
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          ; --- Z Driver map ---
          ; ----+---- Z-Drives
          ; | 4 | 5 |
          ; | 3 | 6 |
          ; Front
          ; (lookking at the printer from the top)
          M569 P0 S1 ; A
          M569 P1 S1 ; B
          M569 P2 S0 ; physical drive 3 goes forwards using default driver timings
          M569 P3 S0 ; Z1
          M569 P4 S0 ; Z2
          M569 P5 S1 ; Z3
          M569 P6 S0 ; Z4
          M569 P124.0 S1 ; physical drive 124.0 goes forwards
          ; Motor mapping and steps per mm
          M584 X0 Y1 Z3:4:5:6 E124.0 ; set drive mapping
          ;M669 K5 X1:1:0:0 Y1:1:0:-1 Z0:0:1:0;
          ;M92 X80 Y80 Z400 ; Set XYZ steps per mm (1.8deg motors)
          M92 X126.00 Y126.00 Z400.00 ; Set XYZ steps per mm (0.9deg motors)
          M92 E665.00 ; set E steps per mm
          M350 Z16 I0 ; disable Z interpolation
          ; Drive currents
          M906 X1300 Y1300 Z1300 E500 ; XYZ and E current
          M906 I30 ; Idle current percentage
          M84 S120 ; Idle timeout
          M566 X900 Y900 Z60 E8000 ; Set maximum instantaneous speed changes (mm/min)
          M203 X18000 Y18000 Z3000 E15000 ; Set maximum speeds (mm/min)
          M201 X2000 Y2000 Z250 E1800 ; Set maximum accelerations (mm/s^2)
          M204 P1500 T2000 ; Set printing acceleration and travel accelerations
          M84 S30 ; Set idle timeout
          M208 X0 Y0 Z0 S1 ; S1 = set axes minimum
          M208 X320 Y340 Z300 S0 ; S0 = set axes maximum
          M574 X2 S1 P"124.io2.in" ; Map the X endstop to toolboard io2.in
          ;M574 X1 S1 P"124.io0.in"
          ;M574 X2 S1 P"xstop" ; X max active low endstop switch
          M574 Y2 S1 P"ystop" ; Y max active low endstop switch
          ;M574 Z1 S1 P"zstop"
          M574 Z0 P"nil" ; No Z endstop
          ;Filament sensor
          ;M591 D0 P7 C"e0stop" S1 R50:130 L7.0 E10
          ;M591 D1 P7 C"e1stop" S1 R50:130 L7.0 E10
          ; Accelerations and speed
          M98 P"/macros/print_scripts/speed_printing.g"
          ; Z-Probe (TAP) ;
          ;================================== ; Voron OptoTAP pcb 5V|sig|gnd on 124.io0
          M558 P8 C"^124.io0.in" H5 F600:120 T18000 A5 S0.01 ; set Z probe type to switch and the dive height + speeds
          G31 P500 X0 Y0 Z-0.875 ; set Z probe trigger value, offset and trigger height
          M671 X-65:-65:365:365 Y0:395:395:0 S20 ; Difine Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right)
          M557 X20:290 Y20:290 S25 ; Difine bed mesh grid (inductive probe, positions include the Y offset!)
          ;Bed heater dual thermistor setup
          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 A"Bed Pad" ; configure sensor 0 as thermistor on pin bedtemp (pad sensor)
          M308 S2 P"e1temp" Y"thermistor" T100000 B3950 A"Bed Plate" ; configure sensor 2 as thermistor on pin e1temp (plate sensor)
          M950 H0 C"bed" T2 Q10 ; create bed heater output on out0 and map it to sensor 2 (plate sensor). Set PWM frequency to 10Hz
          M140 P0 H0 ; Mark heater H0 as bed heater (for DWC)
          M143 H0 P1 T0 A2 S115 C0 ; Regulate (A2) bed heater (H0) to have pad sensor (T0) below 110°C. Use Heater monitor 1 for it
          M143 H0 P2 T0 A1 S125 C0 ; Shut off (A1) bed heater (H0) if pad sensor (T0) exceeds 120°C. Use Heater monitor 2 for it
          M143 H0 S120 ; Set bed heater max temperature to 120°C, use implict monitor 0 which is implicitly configured for heater fault
          M307 H0 B1 S0.2 ; Enable Bang Bang mode and set PWM to 70% to avoid warping
          ; T0 = HotEnd
          M308 S1 P"124.temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 on pin 124.temp0
          M950 H1 C"124.out0" T1 ; create nozzle heater output on 124.out0 and map it to sensor 1
          ;M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
          ;M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
          ;M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency
          ;M106 P0 S0 H-1 C"PartCooler" ; Name it "PartCooler"
          ; hotend_fan
          ;M950 F1 C"fan1" Q1000 ; create hotend_fan on pin fan1 and set its frequency
          ;M106 P1 S1.0 H1 T50 C"ToolFan" ; attach hotend fan to heater 1 and set
          ; controller_fan
          M308 S3 Y"drivers" A"DRIVERS" ; configure sensor 3 as temperature warning and overheat flags on the TMC2209 on BTT Octopus
          M308 S4 Y"mcu-temp" A"MCU" ; configure sensor 4 as on-chip MCU temperature sensor
          M950 F2 C"fan2" Q1000 ; create fan 2 on pin fan2 and set its frequency
          M106 P2 S255 H3:4 B0.1 T35 C"MCUCooler" ; set fan 2 value and Name it "MCUCooler"
          M950 F4 C"fan4"
          M106 P4 S0.7 H4 B0.8 T34:36
          M950 H3 C"nil" ; free up e3heat pin
          M950 F9 C"e3heat" T4
          M950 H9 C"e3heat" T4 Q100
          M106 P9 S255 H4 T36 C"MCUCooler" ; set fan 4 value and Name it "MCUCooler"
          ; exhaust_fan
          M950 H2 C"nil"
          M950 F10 C"e2heat" T10
          M950 H10 C"e2heat" T10 Q1000 ; create exhaust_fan on pin fan3 and set its frequency
          M106 P10 S255 H10 T39:55 C"ChamberFan"
          M106 P10 S1 H0 T50 ; Chamber filter fan, turn on when bed is hotter than 50C
          ;Extruder heat Fan
          ;M308 S5 P"e2temp" Y"thermistor" T100000 B3950 ; configure sensor 5 as thermistor on pin e5temp
          M950 F5 C"fan5" Q1000
          M106 P5 S1 H1 T150
          M106 P5 S0 H1 T50 ; Extruder heat Fan, turn on when hotend is hotter than 50C
          M563 P0 D0 H1 F0 S"Dragonfly" ; define tool 0
          G10 P0 X0 Y0 Z0 S0 R0 ; set tool 0 axis offsets
          ;Chamber sensor (DHT22)
          M308 S10 P"B.5" Y"dht22" A"Chbr Temp[C]"
          M308 S11 P"S10.1" Y"dhthumidity" A"Chbr Hum[%]"
          M308 S7 A"Fly-RRF-36" Y"mcu-temp" P"124.dummy" ; Sensor 7 Built in temp monitor in Fly-RRF-36
          M950 F1 C"fan1"
          M106 P1 H7 B0.8 T36
          ; Accelerometer
          M955 P124.0 I10
          ;LED strip RGB
          M950 C"124.rgbled" E0 T1 Q1000 ; create a RGB Neopixel LED strip on the Fly-RRF-36 LED port
          M98 P"/macros/LED/white.g" S{true}
          ;M150 R255 B225 U255 F1 ; white
          M98 P"/macros/LED/green.g" S{true}
          ;M150 U255 P220 S3 F1 ; green
          M98 P"/macros/LED/blue.g" S{true}
          ;M150 B255 P220 S3 F1 ; blue
          M98 P"/macros/LED/red.g" S{true}
          ;M150 R255 P220 S3 F1 ; red
          ;M950 C"neopixel" E0 T1 ; create a RGB Neopixel LED strip on the LED port
          ; Misc
          M912 P0 S-4 ; MCU temperature calibration (yours will be different)
          ;M572 D0 S0.075 ; Presure Advance
          M572 D0 S0.01 ; Presure Advance
          M592 D0 A0.015 B0.0012 L0.2 ; Non-linear extrusion
          M376 H10 ; Fade mesh out compensation over 10mm Z
          M552 S1
          ; paneldue --------------------------
          M575 P1 S1 B57600 ; activate paneldue
          ;M575 P1 S2 B57600
          M501 ; read config-override.g
          T0 ; select tool 0
          M150 X2
          T0 P0
            jay_s_uk @agz90
            @agz90 really, you fan assignments are the wrong way round. F0 should be the part cooling fan, F1 should be the hotend fan. Thats the traditional way to set it up so swap them round.
            This will then match the fan you have assigned to the tool using M563
            • agz90undefined
              agz90 @jay_s_uk
              @jay_s_uk
              I currently have a Fly-Super8Pro H723 board I'm experimenting with and my BTT Octopus Pro v1.0 F429 running on Voron 2.4.
              • agz90undefined
                agz90 @agz90
                @agz90
                I tried swapping them but then none of the fans start. On the board, the diode lights up, but no fan moves.
                • agz90undefined
                  agz90 @agz90
                  @agz90
                  and where to set the fans with M563
                  gloomyandyundefined 1 Reply Last reply Reply Quote 0
                  • gloomyandyundefined
                    gloomyandy @agz90
                    @agz90 I'd recommend spending some time studying the gcode dictionary here: https://docs.duet3d.com/en/User_manual/Reference/Gcodes and the general Duet RRF documentation for fans here: https://docs.duet3d.com/User_manual/Connecting_hardware/Fans_connecting you will need to adjust things a little for your board and printer but it isn't that hard to do.
                    You could also post your current config.g file and someone may be kind enough to try and work out what is wrong with it.
                    agz90undefined 1 Reply Last reply Reply Quote 1
                    • agz90undefined
                      agz90 @gloomyandy
                      @gloomyandy
                      Thanks
                      edspedundefined 1 Reply Last reply Reply Quote 0
                      • edspedundefined
                        edsped @agz90
                        @gloomyandy
                        Thanks
                        Not sure if it will help but here's a RRF-36 Config for one of my tools,
                        ;---------------------Tool 0 aka "AMY" With CAN Address 20.0 ------------------------------------------
                        ;Heater Thermistor
                        M308 S1 P"20.TEMP0" Y"thermistor" T100000 B4725 C7.06e-8 A"Amy"    ;"T1" Semtec Thermistor defined
                        ;M308 S6 P"20.temp1" Y"thermistor" A"Amy Fly RRF" T100000 B4092    ; Onboard temperature sensor
                        ; Cooling Fans
                        M950 F0	C"20.out1"                      ; Fan 0, part cooler fan on Tool 0
                        M106 P0 C"Amy"                          ; Set Fan Name
                        M950 F1 C"20.out2"                      ; Fan 1, hotend fan on Tool 0
                        M950 H1 C"20.out0" T1                   ; Heater 1 "H1" uses the Out0 pin and Temp0
                        M570 H1 P15 T20 R5                      ; An anomaly on "H1" must persist for 15 seconds, and must be greater or less than 20C from the setpoint, to raise a heater fault.
                        M143 H1 S280                            ; Maximum H1 (Extruder 1) heater temperature
                        M106 P1 S1.0 T45 H1  			        ; Tool 0 Hotend Fan to start cooling at 45C Monitoring Heater 1 (H1)
                        M563 P0 S"Amy" D0 H1 F0          	    ; Define tool 0 "AMY" using H1 heater, F0 cooling
                        ;G10 P0 X0.188 Y32.637 Z-0.345     	    ; Set tool 0 offset from the bed FOR INITIAL SETUP ONLY SEE VALUES IN CONFIG OVERRIDE
                        G10 P0 S0 R0                            ; Set tool 1 operating (S) and standby temperatures (R) (-273 = "off")
                        M572 D0 S0.04                           ; Set pressure advance on Extruder Drive 1
                        ;Turn on tool Lights
                        M950 E0 C"20.rgbled" T2 U2              ; Strip number, Pin ID, type, Max # of LED'S
                        ;M150 E0 U0 R0 B0 W255 S1 F1 P255        ; for RGBW LED Only
                        ;M150 E0 U0 R0 B0 W255 S1 F0 P255	    ; for RGBW LED Only
                        M955 P20.0 I52                          ; Enable accelerometer on Amy
                        ;---------------------End of Tool 0 aka "AMY"  -----------------------------------------------------------
